How can i make it so only the yellow led comes on when both buttons are pushed and not all three led's?
int greenLed = 9; // set pin 9 to a variable
int yellowLed = 10; // set pin 10 to a variable
int redLed = 11; // set pin 11 to a variable
int buttonA = 4; // set pin 4 to a variable
int buttonB = 2; // set pin 2 to a variable
void setup ()
  pinMode (greenLed, OUTPUT); // set Green LED pin to an output
  pinMode (yellowLed, OUTPUT); // set yellow LED pin to an output
  pinMode (redLed, OUTPUT); // set red LED pin to an output
  pinMode (buttonA, INPUT_PULLUP); // set buttoA to an pullup intput
  pinMode (buttonB, INPUT_PULLUP); // set buttonB to an pullup input
  if (digitalRead(buttonA) == LOW) {
    analogWrite(greenLed, 50); // Turn on Green LED Dim setting
  else {
   digitalWrite(greenLed, LOW); // Turn off Green LED
  if (digitalRead(buttonB) == LOW) {
   analogWrite(redLed, 200); // Turn on Red LED Med setting
  else {
   digitalWrite(redLed, LOW); // Turn off Red LED
  if (digitalRead(buttonA) == LOW && digitalRead(buttonB) == LOW) { // if BOTH the switches read LOW
    // statements
   analogWrite(yellowLed, 250); // Turn on Yellow LED Brightnes setting
  else {
     digitalWrite(yellowLed, LOW); // Turn off yellow LED
When you detect both switches are pushed, turn OFF the red and green LEDs.
Example
if (digitalRead(buttonA) == LOW && digitalRead(buttonB) )
if (digitalRead(buttonB) == LOW && digitalRead(buttonA) ) {
if (digitalRead(buttonA) == LOW && digitalRead(buttonB) == LOW ) {
Please edit your post, select all code and click the </> button to apply so-called code tags and next save your post. It makes it easier to read, easier to copy and prevents the forum software from incorrect interpretation of the code.
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advise on) your project :wink: See About the Installation & Troubleshooting category.
The problem with your current code, other than you not posting it correctly is that your conditions are not mutually exclusive.
If you think about the 2 buttons, there are 4 possibilities:
  • Only A pressed
  • Only B pressed
  • A & B pressed
  • None pressed
Currently when both are pressed all 3 of your if statements are true. And while you could reset the RED & GREEN LEDs if A & B are both are pressed, at the top of the next loop you will turn them on again.
So you are best to construct an IF statement that keeps these 4 situations separate.
If (A pressed) && (Not B pressed)
  turn GREEN ON
  turn RED OFF
  turn YELLOW OFF
else if (A Not pressed) && (B Pressed)
  turn GREEN OFF
  turn RED ON
  turn YELLOW OFF
else if (A pressed) && (B Pressed)
  turn GREEN OFF
  turn RED OFF
  turn YELLOW ON
  turn GREEN OFF
  turn RED OFF
  turn YELLOW OFF
I did this but the yellow led did not come on.
void setup ()
  if (digitalRead(buttonA) == LOW && digitalRead(buttonB) ) {
  else {
  else {
  if (digitalRead(buttonA) == LOW && (buttonB) == LOW) {
    analogWrite(yellowLed, 200); // Turn on Yellow LED Brightnes setting
Apart from these errors...
I don't think you read my post...#4
You would make life easier for yourself if you have single If statement, and set/unset all the LEDs for each option.
