How can I measure the current of a normal 12v dc motor?
You can put a very low ohm resistor in series with the motor power feed and measure the voltage drop across it. Knowing the voltage and the resistance you can calculate the current. There are also hall sensors that will measure the current. Not knowing what motor you are using nor the circuit this is a best guess.
