How can I Multitask with an Adafruit LED strip?
I have an project for School and I am nearly at the end. We have to light up 2 normal LEDs and one LED should Blink at the same time. At this Point I did not have any Problems until I wanted to combine this with an Adafruit LED strip. Now I have no clue why I cant let them glow at the same Time. Any help or advice?
//START
#ifdef __AVR__
#include <avr/power.h>
#endif
#define LED_PIN(SCL, OUTPUT)
#define LED_COUNT 60
Adafruit_NeoPixel strip(60, SCL,NEO_GRB + NEO_KHZ800);
const int ledPin =  13;
int ledState = LOW;
long previousMillis = 0;
long interval = 475;
  pinMode(ledPin, OUTPUT);
  #if defined(__AVR_ATtiny85) && (F_CPU == 16000000)
  clock_prescale_set(clock_div_1);
#endif
  strip.begin();
  strip.show();
  strip.setBrightness(50);
  pinMode(12, OUTPUT);
  pinMode(11, OUTPUT);
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    if (ledState == LOW)
      ledState = HIGH;
      ledState = LOW;
    digitalWrite(ledPin, ledState);
  colorWipe(strip.Color(255,   0,   0),50);
  colorWipe(strip.Color(255, 100,   0),50);
  colorWipe(strip.Color(  0, 255,   0),50);
  rainbow(40);
  digitalWrite(11, HIGH);
  digitalWrite(12, HIGH);
void rainbow(int wait) {
  for(long firstPixelHue =0; firstPixelHue < 5*65536; firstPixelHue += 256) {
    strip.rainbow(firstPixelHue);
    strip.show();
void colorWipe(uint32_t color, int wait) {
  for(int i=0; i<strip.numPixels(); i++) {
    strip.setPixelColor(i, color);
    strip.show();
//ENDE
After strip.show() was a delay(wait)
I'm using a Arduino UNO
What kind of Arduino are you using?
Always show us a good schematic of your proposed circuit. Show us a good image of your ‘actual’ wiring.
Give links to components.
You have to rewrite the Neopexel effects so they are non blocking. That is so the code returns to look at the button every half second or so. This is normally a bit advanced for most users although I have posted examples showing how it is done many times.
Non blocking code
However there is now a simpler way by using a commutable delay you can cancel at the touch of a button.
Commutable Delay
you mixed up your "LED Blinking" and your effect calls on the strip
check the closing } ...of
just handle the blink LED within the {} and let the other code run outside of that if.
