Hi, @taeminshin0708
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
analogWrite does not actually output an analog level, it outputs a PWM wave, the duty cycle from 0 to 100% represented by values from 0 to 255.
AnalogRead on a UNO has values 0 to 1023.
So your code just samples and converts to a PWM waveform.
You also will have to make sure you have a sampling rate high enough to get a proper waveform at your highest audio frequency.
The UNO may not be fast enough to do much processing anyway.
What is your electronics, programming, arduino, hardware experience?
Tom...
