int red = 7;
int yellow = 4;
int green = 2;
int botaoInc = 8;
int botaoFim = 6;
int buttonState = 0;
int buttonState2 = 0;
pinMode(red, OUTPUT);
pinMode(yellow, OUTPUT);
pinMode(green, OUTPUT);
pinMode(botaoInc, INPUT);
pinMode(botaoFim, INPUT);
buttonState = digitalRead(botaoInc);
buttonState2 = digitalRead(botaoFim);
while ( buttonState == HIGH && buttonState2 == LOW) {
// Verde on, por 10 segundos, vermelho off e amarelo off
digitalWrite(green, HIGH);
digitalWrite(yellow, LOW);
digitalWrite(red, LOW);
delay(2000);
if (buttonState2 == HIGH) {
// Verde off, vermelho off, amarela on por 2s
digitalWrite(green, LOW);
digitalWrite(yellow, HIGH);
delay(2000);
// Vermelho on por 5 segundos, verde e amarelo off
digitalWrite(red, HIGH);
delay(2000);
this traffic lights project has two buttons, 1 to start and other to Stop in any moment.
I try everything that I know in other languages.
J-M-L
March 23, 2022, 7:15pm
2
don't use delay, use a state machine with button events and millis() to handle time
For extra information and examples on using millis() look at Using millis() for timing. A beginners guide and Several things at the same time
PS: you are not updating the conditions in your while() loop so this is an infinite loop..
Looks like you need an Interrupt
The Arduino programming language Reference, organized into Functions, Variable and Constant, and Structure keywords.
PaulRB
March 23, 2022, 7:26pm
4
igorcassimiro:
delay(2000);
This is the problem. What that means is "do nothing for 2 seconds, even if a button is pressed". The delays have to go!
The code you have now is like riding a bicycle with stabilisers ("training wheels"). Time to take that next step and up your coding skill level.
J-M-L
March 23, 2022, 7:32pm
6
this meets the requirement of "stops immediately the loop with a Button " so could be considered but that won't achieve what the real question is - as OP likely wants to break out of his while() loop and continue the loop() and keep processing the traffic light. Not just be stuck in an ISR.
So probably not the answer. State machine + millis is much better
igorcassimiro:
delay(2000);
igorcassimiro:
delay(2000);
igorcassimiro:
delay(2000);
With 6 seconds where the CPU can be doing nothing, stopping immediately the loop with a button is not possible with a Uno and using delay(). Instead use a State Machine and millis() for timing.
Use the search to find out more info on state machine and millis().
Look in File|Examples|02.Digital|BlinkWithoutDelay of your Arduino IDE.
kolaha
March 23, 2022, 7:52pm
8
const byte red = 7;
const byte yellow = 4;
const byte green = 2;
const byte botaoInc = 8;
const byte botaoFim = 6;
static bool isRun = true;
static unsigned long Timer = 0;
while (!isRun )
if ( digitalRead(botaoInc) == HIGH)isRun = true;
while ( isRun) {
Timer = millis();
while (millis() - Timer < 2000UL)
if ( digitalRead(botaoFim == HIGH))isRun = false;
if (!isRun) break;
Timer = millis();
if (!isRun) break;
Timer = millis();
if (!isRun) break;
Works partially. but the loop stops even i dont press the button
int red = 7;
int yellow = 4;
int green = 2;
int botaoInc = 8;
int botaoFim = 6;
while (buttonState == HIGH && buttonState2 == LOW) {
changeLights();
if (digitalRead(botaoFim == HIGH)) {
// Método para controle das leds;
void changeLights() {
for (long int i = 0; i < 20000; i++) {
if (digitalRead(botaoFim) == HIGH) {
return;
return;
return;
This isn’t doing what you think.
You didn’t see that syntax anywhere.
Review digitalRead() .
a7
works now
int red = 7;
int yellow = 4;
int green = 2;
int botaoInc = 8;
int botaoFim = 6;
while (buttonState == HIGH) {
changeLights();
for (long int i = 0; i < 250000; i++) {
return;
for (long int i = 0; i < 60000; i++) {
return;
for (long int i = 0; i < 100000; i++) {
return;
Very clever…
return;
but you could do those like the below and get a bit better control over how long that “delay” is.
for (int i = 0; i < 1000; i++) {
delay(1);
return;
You could also put that logic into a custom function, since it is just the same code repeated.
Try or don’t. If you try and fail or succeed, tell us about it.
a7
