#include <Geometry.h>
#include <Wire.h> //Include WIre library for using I2C
#include <MPU6050_light.h>
MPU6050 mpu(Wire) ;
int16_t MPU;
const int MPU_addr=0x68; //I2C MPU6050 Address
int16_t axis_X,axis_Y,axis_Z;
int minVal=265;
int maxVal=402;
double x;
double y;
double z;
Wire.begin(); //Begins I2C communication
Wire.beginTransmission(MPU_addr); //Begins Transmission with MPU6050
Wire.write(0x6B); //Puts MPU6050 in Sleep Mode
Wire.write(0); //Puts MPU6050 in power mode
Wire.endTransmission(true); //Ends Trasmission
Wire.beginTransmission(MPU_addr); //Begins I2C transmission
Wire.write(0x3B); //Start with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true); //Request 14 Registers from MPU6050
int xAng = map(axis_X,minVal,maxVal, 0 ,360);
int yAng = map(axis_Y,minVal,maxVal, 0 ,360);
int zAng = map(axis_Z,minVal,maxVal, 0 ,360);
x= RAD_TO_DEG * (atan2(-yAng, -zAng)+PI); //Formula to calculate x values in degree
y= RAD_TO_DEG * (atan2(-zAng, -xAng)+PI); //Formula to calculate y values in degree
Serial.print(x= RAD_TO_DEG * (atan2(-yAng, -zAng)+PI));
Serial.print(";");
mpu.dmpGetQuaternion(&q,fifoBuffer);
mpu.dmpGetEuler(euler, &q);
Serial.print("euler\t");
Serial.print(euler[0] * 180/M_PI);
Serial.print("\t");
Serial.print(euler[1] * 180/M_PI);
Serial.print("\t");
Serial.println(euler[2] * 180/M_PI);
'Arduino: 1.8.13 (Windows 7), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
C:\Users--------\sketch_may23a\sketch_may23a.ino: In function 'void loop()':
sketch_may23a:53:5: error: 'class MPU6050' has no member named 'dmpGetQuaternion'
sketch_may23a:53:23: error: 'q' was not declared in this scope
sketch_may23a:53:25: error: 'fifoBuffer' was not declared in this scope
sketch_may23a:55:5: error: 'class MPU6050' has no member named 'dmpGetEuler'
sketch_may23a:55:17: error: 'euler' was not declared in this scope
C:\Users-------\sketch_may23a\sketch_may23a.ino:55:17: note: suggested alternative: 'extern'
extern
exit status 1
