then it passes to me
I understood my mistake, after creating it myself, I have to "pull request" to them again.
My meta file is missing
It says this because your folder structure is wrong.
Look at the folder structure for this example:
All the files are in the root of the github repo.
With your repo, it is different: the root of your github repo has a folder called MQSpaceData
Your library.properties file appears to be incorrect.
One issue I see: you need to give an email address
maintainer=Cristian Maglie <c.maglie@example.com>
but bot said All checks have passed
i uploaded again, i deleted MQSpaceData file
No need for screenshots, I can see your pull request on my computer too.
I can see this also.
The information from github here is misleading. The automated checks have finished, but your submission was not accepted.
The "submission fail" has run. The "merge" has not.
Edit your library.properties file; It is wrong.
Add an email for maintainer.
The full information for writing library.properties is here, but it is not a short page to read.
Please also remove the space after equals in library.properties.
Change every "= " into "=".
I don't know if this is important.
I edited it again and now after I refresh the library.pro.. in version 1.0.0 again, should I request it again?
I already asked github to check for you again, but it failed again for library.properties
I am not sure of the problem.
Maybe your sentence
and paragraph
is too long? Could you try to make them only a few words each?
but the bot ticked maybe it was uploaded if there is no direct comparison i will try to shorten it
yes the problem is in the paragraph because when i shortened the text it turned red the problem is because the paragraph is too long i will try again now
I ran the check again for you and it failed. I will use the arduino-lint tool to determine the problem for you.
now i changed
i added category
category deleted while shortening the paragraph
Previously, the paragraph was too long, so it slipped into the category.
Wait.. you may have to make a new release..
Sorry for that, I should have realized.
You do not need to attach a zip to the release. It is created automatically.
Changing the attached zip will not be enough. You need to delete this release and create a new one.
I wish I had known that there was no need to close the topic for her to check it all again, that I would just have to text him
