Is there any chance I can open it back?
No, you should make a new pull request.
But first you should delete your release, and your tag, then make a new release.
well, I didn't send the version to them, I referenced the homepage. If I'm going to delete the version, do you mind if I share it with the same version again?
The version is mentioned in library.properties.
Same version again should be fine, yes.
for security purposes i am doing 1.0.1, both from 1.00.
anyway,i should set library.properties to 1.0.1 to be safe. and I don't publish the same version just so i don't have a problem. (1.0.1)
Yes, correct
I think it's done now no error
Pull request successfully merged and closed
Your submission has now been accepted! Thanks for your contribution to the Arduino Library Manager index.
The library(s) will be available for installation via Library Manager within a day's time.
You can check the logs from the Library Manager indexer for your library(s) here:
http://downloads.arduino.cc/libraries/logs/github.com/abcdaaaaaaaaa/MQSpaceData.h/
Advice for first library builders:
After doing the fork step, in another tab
GitHub - arduino/library-registry: The Arduino Library Manager Registry open this link and create a pull request from here, you will receive a pull request button (click after you fork yourself) (don't do extra operations on your own fork) pull request from this link: https: Create //github.com/arduino/library-registry and don't start these operations without adding relases (version)
