How do i connect a 12v 7ah battery to an arduino and l298, with what wires
Hello, this is my first time working with arduino, l298, motors, and batteries. I am wondering how I can connect cable from the battery to the arduino and l298 without overpowering them, overheating, or blowing them up, are there any cables that can directly do this, I would appreciate if anyone could tell me which cables I should use to flow the power from the battery to both the arduino and l298, thank you. It would be preferrable if the power could flow directly, and there is less wires, and no fusing, thank you
Please read and use the topic " How to get the best out of this forum".
sorry, i am not sure what you mean by that, could you please link the article? if anyone else sees this please do help as well
I answered that in your later post. Please do not double post.
The wire gauge will depend on how far away the motor is from the battery.
So what is the distance between them?
What battery set do You plan for?
Start with the battery. What provision does the battery have to connect cables to it? Does it have screw connectors?
Read the specification, it will not support a 7A motor.
The ancient L298 won't work well, or at all. It is intended only for very small, low current motors.
You will need a motor driver capable of handling the start/stall current for your motor, which is typically 5 to 10X the free running current. Pololu has the best selection of modern motor drivers.
For help, post a link to the motor product page.
@fair_de_ciencia ,
Your two or more topics on the same or similar subject have been merged.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
Thank you for posting the link, I will read the article now
The distance is probably no more than a foot
This is a graph of the wiring, what i am looking for in specific is the red and black wires coming out of the battery, all the other wires I have done research and sorted out. But i am just wondering does anyone know what type of wires could be used like the red and black wires coming out of the battery are used here? much thanks, arduino is the arduino uno rev3, and the l298 is the red board, the motor is dc motor not too powerful, the code is already figured out
Thanks for the article, it was helpful to understand the rules
That shows a stepping motor, not a brushed DC motor. The L298 won't work for most stepping motors, either. You need a current limiting stepper driver.
If you can't take the trouble to post a link to the product page or data sheet for the motor you actually have, you probably won't get any useful advice from this forum.
Then I would use AWG18
