I'm currently working on an Arduino project and I'm facing some errors during the compilation of my code. I'm not sure how to debug these errors and resolve them. Could someone please provide me with guidance on how to effectively debug Arduino code and identify the root cause of these compilation errors? Additionally, any tips or best practices for resolving common Arduino code errors would be highly appreciated. Thank you in advance for your assistance!
Start with with first error reported by the compiler.
If you are not yet confident in programming, then take small steps and give the programme to the compiler to check. The compiler will be happy about it.
of course you can ask in the forum too.
The Arduino-IDE can be adjusted to write different amounts of compiler-messages into the compiler-log.
Here is a tutorial how to adjust the compiler to write the maximum into the compiler-log and how to post this compiler-log into a posting in a way that makes it easy for other users to crawl through all the text.
not all but a lot of errors can be found by searching for ": error:"
as code-section
: error:
in words because each character is important:
a double-point a space the word "error"
if you just search for "error" without the double-point-space you will find a lot of lines in the compiler-log that are not relevant
second is
: fatal error:
double-point space "fatal"
@the community:
there are some traps that are hard to find for newcomers:
example
if ( myfunction(myparameter) {
missing the second closing parenthesis ")"
if ( myfunction(myparameter) ) {
often leads to "not declared"-errors because the missing closing parenthesis says to the the compiler take all the following code as parameters of the function instead as their own functions.
Is there somewhere a list with such hard to find syntax-errors?
@genieeee This advice might sound obvious, but there is an important reason for it.
The compiler reads the code from top to bottom. Errors at the top can cause the compiler to believe there are some errors later in the code that are not really there, because if one of those earlier errors got fixed, it's possible some of the later errors would "evaporate". So if you dive in to fixing one of the "errors" in the middle of the code somewhere, it might be a waste of time.
Sometimes the compiler errors are hard to untangle, even starting with the first may be a red herring.
You can use the IDE Autoformat tool. This can be a big help for finding missing or misplaced { braces }.
The IDE will also help you see or find extra parentheses and some things like that.
It is best to develop in steps and not get so far ahead in the code that you are not able to focus your error finding efforts to the code you have been working on.
