How do I find an angle from its tangent?
Hi folks, I am trying to work out the compass heading from the X,Y and Z axis readings from a MicroMag3 sensor module. But the Arduino language only has a tan() function, and not a cotan() function. So how can I work out an angle (in radians or degrees), using just the tan() function?
I guess it's pretty simple, but it's many years since I did trigonometry at school!
Any helpful information would be appreciated!
which coordinate system do you want to use?
You can use the arctan function (atan) to calculate the angle. The formula for calculating the angle (θ) from the X and Y components is:
arctan
θ=arctan(
X
Y
This will give you the angle in radians. If you need the angle in degrees, you can convert it using the degrees() function in Arduino:
angle_degrees
degrees
angle_degrees=degrees(θ)
Hope this helps!
Long enough ago it seems to now confuse cotangent with inverse tangent.
a7
Hi Delta_G,
Thanks for that advice, but my Arduino language doesn't seem to recognise the atan() function. Do I have to include a math library?
Jim Rowe
Hi kaamdhandra,
Thanks for that advice -- much appreciated. But how do I find the arctan() and degrees() functions in the Arduino language? My copy doesn't seem to know about them, and the Arduino language reference doesn't seem to list them.
But thanks for pointing me in the right direction!
Jim Rowe
Post the code, using code tags, and forum members can point out the mistake.
Te library math.h has a the atan()-function
    The atan() function computes the principal value of the arc tangent
    of \a __x.  The returned value is in the range [-pi/2, pi/2] radians.
extern double atan(double __x) __ATTR_CONST__;
#define atanf	atan		/**< The alias for atan().	*/
    The atan2() function computes the principal value of the arc tangent
    of <em>__y / __x</em>, using the signs of both arguments to determine
    the quadrant of the return value.  The returned value is in the range
    [-pi, +pi] radians.
extern double atan2(double __y, double __x) __ATTR_CONST__;
best regards Stefan
You don't need to do anything but call it, I did a/o including any maths library. Arduino builds it in, just another case of bad or incomplete documentation.
float x = atan(-1.0);
will give x the value -0.785398, which Om sure you recognize as pi/4.
a7
  0  0.00  1.00  0.00
  60  0.87  0.50  60.00
  120  0.87  -0.50  120.00
  180  -0.00  -1.00  -180.00
  240  -0.87  -0.50  -120.00
  300  -0.87  0.50  -60.00
    for (int ang = 0; ang < 360; ang += 60)  {
        float  s = sin (ang * M_PI / 180);
        float  c = cos (ang * M_PI / 180);
        float  a = atan2(s, c) * 180 / M_PI;
        Serial.print ("  ");
        Serial.print (ang);
        Serial.print ("  ");
        Serial.print (s);
        Serial.print ("  ");
        Serial.print (c);
        Serial.print ("  ");
        Serial.print (a);
        Serial.println ();
Generally, pi/4 is positive.
variant with a little more explaining
// MACRO-START * MACRO-START * MACRO-START * MACRO-START * MACRO-START * MACRO-START *
// a detailed explanation how these macros work is given in this tutorial
// https://forum.arduino.cc/t/comfortable-serial-debug-output-short-to-write-fixed-text-name-and-content-of-any-variable-code-example/888298
#define dbg(myFixedText, variableName) \
  Serial.print( F(#myFixedText " "  #variableName"=") ); \
  Serial.println(variableName);
// MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END *
  Serial.println("Setup-Start");
  dbg("0",M_PI);
  for (int ang = 0; ang < 360; ang ++)  {
    float  sinus = sin (ang * M_PI / 180);
    float  cosinus = cos (ang * M_PI / 180);
    float  arctan_radiant = atan2(sinus, cosinus);
    float arctan_degree = arctan_radiant * 180 / M_PI;
    dbg("angle",ang);
    dbg("sin",sinus);
    dbg("cos",cosinus);
    dbg("atan2-rad",arctan_radiant);
    dbg("atan2-deg",arctan_degree);
    Serial.println ();
output
22:00:06.922 -> 00
22:00:06.922 ->
22:00:06.922 -> "angle" ang=12
22:00:06.922 -> "sin⸮Setup-Start
22:00:06.922 -> "0" M_PI=3.14
22:00:06.922 -> "angle" ang=0
22:00:06.922 -> "sin" sinus=0.00
22:00:06.922 -> "cos" cosinus=1.00
22:00:06.922 -> "atan2-rad" arctan_radiant=0.00
22:00:06.922 -> "atan2-deg" arctan_degree=0.00
22:00:06.922 ->
22:00:06.922 -> "sin" sinus=0.02
22:00:06.922 -> "atan2-rad" arctan_radiant=0.02
22:00:06.922 -> "atan2-deg" arctan_degree=1.00
22:00:06.922 ->
22:00:06.922 -> "angle" ang=2
22:00:06.922 -> "sin" sinus=0.03
22:00:06.922 -> "atan2-rad" arctan_radiant=0.03
22:00:06.922 -> "atan2-deg" arctan_degree=2.00
22:00:06.922 ->
22:00:06.922 -> "angle" ang=3
22:00:06.922 -> "sin" sinus=0.05
22:00:06.922 -> "atan2-rad" arctan_radiant=0.05
22:00:06.922 -> "atan2-deg" arctan_degree=3.00
22:00:06.922 ->
22:00:06.922 -> "angle" ang=4
22:00:06.969 -> "sin" sinus=0.07
22:00:06.969 -> "cos" cosinus=1.00
22:00:06.969 -> "atan2-rad" arctan_radiant=0.07
22:00:06.969 -> "atan2-deg" arctan_degree=4.00
22:00:06.969 ->
22:00:06.969 -> "angle" ang=5
22:00:06.969 -> "sin" sinus=0.09
22:00:06.969 -> "atan2-rad" arctan_radiant=0.09
22:00:06.969 -> "atan2-deg" arctan_degree=5.00
22:00:06.969 ->
22:00:06.969 -> "angle" ang=6
22:00:06.969 -> "sin" sinus=0.10
22:00:06.969 -> "cos" cosinus=0.99
22:00:06.969 -> "atan2-rad" arctan_radiant=0.10
22:00:06.969 -> "atan2-deg" arctan_degree=6.00
22:00:06.969 ->
22:00:06.969 -> "angle" ang=7
22:00:06.969 -> "sin" sinus=0.12
22:00:06.969 -> "atan2-rad" arctan_radiant=0.12
22:00:06.969 -> "atan2-deg" arctan_degree=7.00
22:00:06.969 ->
22:00:06.969 -> "angle" ang=8
22:00:06.969 -> "sin" sinus=0.14
22:00:07.016 -> "atan2-rad" arctan_radiant=0.14
22:00:07.016 -> "atan2-deg" arctan_degree=8.00
22:00:07.016 ->
22:00:07.016 -> "angle" ang=9
22:00:07.016 -> "sin" sinus=0.16
22:00:07.016 -> "cos" cosinus=0.99
22:00:07.016 -> "atan2-rad" arctan_radiant=0.16
22:00:07.016 -> "atan2-deg" arctan_degree=9.00
22:00:07.016 ->
22:00:07.016 -> "angle" ang=10
22:00:07.016 -> "sin" sinus=0.17
22:00:07.016 -> "cos" cosinus=0.98
22:00:07.016 -> "atan2-rad" arctan_radiant=0.17
22:00:07.016 -> "atan2-deg" arctan_degree=10.00
22:00:07.016 ->
22:00:07.016 -> "angle" ang=11
22:00:07.016 -> "sin" sinus=0.19
22:00:07.016 -> "atan2-rad" arctan_radiant=0.19
22:00:07.016 -> "atan2-deg" arctan_degree=11.00
22:00:07.016 ->
22:00:07.016 -> "angle" ang=12
22:00:07.016 -> "sin" sinus=0.21
22:00:07.016 -> "atan2-rad" arctan_radiant=0.21
22:00:07.064 -> "atan2-deg" arctan_degree=12.00
22:00:07.064 ->
22:00:07.064 -> "angle" ang=13
22:00:07.064 -> "sin" sinus=0.22
22:00:07.064 -> "cos" cosinus=0.97
22:00:07.064 -> "atan2-rad" arctan_radiant=0.23
22:00:07.064 -> "atan2-deg" arctan_degree=13.00
22:00:07.064 ->
22:00:07.064 -> "angle" ang=14
22:00:07.064 -> "sin" sinus=0.24
22:00:07.064 -> "atan2-rad" arctan_radiant=0.24
22:00:07.064 -> "atan2-deg" arctan_degree=14.00
22:00:07.064 ->
22:00:07.064 -> "angle" ang=15
22:00:07.064 -> "sin" sinus=0.26
22:00:07.064 -> "atan2-rad" arctan_radiant=0.26
22:00:07.064 -> "atan2-deg" arctan_degree=15.00
22:00:07.064 ->
22:00:07.064 -> "angle" ang=16
22:00:07.064 -> "sin" sinus=0.28
22:00:07.064 -> "cos" cosinus=0.96
22:00:07.064 -> "atan2-rad" arctan_radiant=0.28
22:00:07.064 -> "atan2-deg" arctan_degree=16.00
22:00:07.064 ->
22:00:07.064 -> "angle" ang=17
22:00:07.064 -> "sin" sinus=0.29
22:00:07.064 -> "atan2-rad" arctan_radiant=0.30
22:00:07.064 -> "atan2-deg" arctan_degree=17.00
22:00:07.064 ->
22:00:07.064 -> "angle" ang=18
22:00:07.064 -> "sin" sinus=0.31
22:00:07.064 -> "cos" cosinus=0.95
22:00:07.064 -> "atan2-rad" arctan_radiant=0.31
22:00:07.064 -> "atan2-deg" arctan_degree=18.00
22:00:07.064 ->
22:00:07.064 -> "angle" ang=19
22:00:07.064 -> "sin" sinus=0.33
22:00:07.064 -> "atan2-rad" arctan_radiant=0.33
22:00:07.064 -> "atan2-deg" arctan_degree=19.00
22:00:07.064 ->
22:00:07.064 -> "angle" ang=20
22:00:07.064 -> "sin" sinus=0.34
22:00:07.064 -> "cos" cosinus=0.94
22:00:07.064 -> "atan2-rad" arctan_radiant=0.35
22:00:07.064 -> "atan2-deg" arctan_degree=20.00
22:00:07.111 ->
22:00:07.111 -> "angle" ang=21
22:00:07.111 -> "sin" sinus=0.36
22:00:07.111 -> "cos" cosinus=0.93
22:00:07.111 -> "atan2-rad" arctan_radiant=0.37
22:00:07.111 -> "atan2-deg" arctan_degree=21.00
22:00:07.111 ->
22:00:07.111 -> "angle" ang=22
22:00:07.111 -> "sin" sinus=0.37
22:00:07.111 -> "atan2-rad" arctan_radiant=0.38
22:00:07.111 -> "atan2-deg" arctan_degree=22.00
22:00:07.111 ->
22:00:07.111 -> "angle" ang=23
22:00:07.111 -> "sin" sinus=0.39
22:00:07.111 -> "cos" cosinus=0.92
22:00:07.111 -> "atan2-rad" arctan_radiant=0.40
22:00:07.111 -> "atan2-deg" arctan_degree=23.00
22:00:07.111 ->
22:00:07.111 -> "angle" ang=24
22:00:07.111 -> "sin" sinus=0.41
22:00:07.111 -> "cos" cosinus=0.91
22:00:07.111 -> "atan2-rad" arctan_radiant=0.42
22:00:07.111 -> "atan2-deg" arctan_degree=24.00
22:00:07.111 ->
22:00:07.111 -> "angle" ang=25
22:00:07.158 -> "sin" sinus=0.42
22:00:07.158 -> "cos" cosinus=0.91
22:00:07.158 -> "atan2-rad" arctan_radiant=0.44
22:00:07.158 -> "atan2-deg" arctan_degree=25.00
22:00:07.158 ->
22:00:07.158 -> "angle" ang=26
22:00:07.158 -> "sin" sinus=0.44
22:00:07.158 -> "cos" cosinus=0.90
22:00:07.158 -> "atan2-rad" arctan_radiant=0.45
22:00:07.158 -> "atan2-deg" arctan_degree=26.00
22:00:07.158 ->
22:00:07.158 -> "angle" ang=27
22:00:07.158 -> "sin" sinus=0.45
22:00:07.158 -> "cos" cosinus=0.89
22:00:07.158 -> "atan2-rad" arctan_radiant=0.47
22:00:07.158 -> "atan2-deg" arctan_degree=27.00
22:00:07.158 ->
22:00:07.158 -> "angle" ang=28
22:00:07.158 -> "sin" sinus=0.47
22:00:07.158 -> "cos" cosinus=0.88
22:00:07.158 -> "atan2-rad" arctan_radiant=0.49
22:00:07.158 -> "atan2-deg" arctan_degree=28.00
22:00:07.158 ->
22:00:07.158 -> "angle" ang=29
22:00:07.158 -> "sin" sinus=0.48
22:00:07.158 -> "cos" cosinus=0.87
22:00:07.205 -> "atan2-rad" arctan_radiant=0.51
22:00:07.205 -> "atan2-deg" arctan_degree=29.00
22:00:07.205 ->
22:00:07.205 -> "angle" ang=30
22:00:07.205 -> "sin" sinus=0.50
22:00:07.205 -> "cos" cosinus=0.87
22:00:07.205 -> "atan2-rad" arctan_radiant=0.52
22:00:07.205 -> "atan2-deg" arctan_degree=30.00
22:00:07.205 ->
22:00:07.205 -> "angle" ang=31
22:00:07.205 -> "sin" sinus=0.52
22:00:07.205 -> "cos" cosinus=0.86
22:00:07.205 -> "atan2-rad" arctan_radiant=0.54
22:00:07.205 -> "atan2-deg" arctan_degree=31.00
22:00:07.205 ->
22:00:07.205 -> "angle" ang=32
22:00:07.205 -> "sin" sinus=0.53
22:00:07.205 -> "cos" cosinus=0.85
22:00:07.205 -> "atan2-rad" arctan_radiant=0.56
22:00:07.205 -> "atan2-deg" arctan_degree=32.00
22:00:07.205 ->
22:00:07.205 -> "angle" ang=33
22:00:07.205 -> "sin" sinus=0.54
22:00:07.205 -> "cos" cosinus=0.84
22:00:07.205 -> "atan2-rad" arctan_radiant=0.58
22:00:07.253 -> "atan2-deg" arctan_degree=33.00
22:00:07.253 ->
22:00:07.253 -> "angle" ang=34
22:00:07.253 -> "sin" sinus=0.56
22:00:07.253 -> "cos" cosinus=0.83
22:00:07.253 -> "atan2-rad" arctan_radiant=0.59
22:00:07.253 -> "atan2-deg" arctan_degree=34.00
22:00:07.253 ->
22:00:07.253 -> "angle" ang=35
22:00:07.253 -> "sin" sinus=0.57
22:00:07.253 -> "cos" cosinus=0.82
22:00:07.253 -> "atan2-rad" arctan_radiant=0.61
22:00:07.253 -> "atan2-deg" arctan_degree=35.00
22:00:07.253 ->
22:00:07.253 -> "angle" ang=36
22:00:07.253 -> "sin" sinus=0.59
22:00:07.253 -> "cos" cosinus=0.81
22:00:07.253 -> "atan2-rad" arctan_radiant=0.63
22:00:07.253 -> "atan2-deg" arctan_degree=36.00
22:00:07.253 ->
22:00:07.253 -> "angle" ang=37
22:00:07.253 -> "sin" sinus=0.60
22:00:07.253 -> "cos" cosinus=0.80
22:00:07.253 -> "atan2-rad" arctan_radiant=0.65
22:00:07.300 -> "atan2-deg" arctan_degree=37.00
22:00:07.300 ->
22:00:07.300 -> "angle" ang=38
22:00:07.300 -> "sin" sinus=0.62
22:00:07.300 -> "cos" cosinus=0.79
22:00:07.300 -> "atan2-rad" arctan_radiant=0.66
22:00:07.300 -> "atan2-deg" arctan_degree=38.00
22:00:07.300 ->
22:00:07.300 -> "angle" ang=39
22:00:07.300 -> "sin" sinus=0.63
22:00:07.300 -> "cos" cosinus=0.78
22:00:07.300 -> "atan2-rad" arctan_radiant=0.68
22:00:07.300 -> "atan2-deg" arctan_degree=39.00
22:00:07.300 ->
22:00:07.300 -> "angle" ang=40
22:00:07.300 -> "sin" sinus=0.64
22:00:07.300 -> "cos" cosinus=0.77
22:00:07.300 -> "atan2-rad" arctan_radiant=0.70
22:00:07.300 -> "atan2-deg" arctan_degree=40.00
22:00:07.300 ->
22:00:07.300 -> "angle" ang=41
22:00:07.300 -> "sin" sinus=0.66
22:00:07.300 -> "cos" cosinus=0.75
22:00:07.300 -> "atan2-rad" arctan_radiant=0.72
22:00:07.300 -> "atan2-deg" arctan_degree=41.00
22:00:07.347 ->
22:00:07.347 -> "angle" ang=42
22:00:07.347 -> "sin" sinus=0.67
22:00:07.347 -> "cos" cosinus=0.74
22:00:07.347 -> "atan2-rad" arctan_radiant=0.73
22:00:07.347 -> "atan2-deg" arctan_degree=42.00
22:00:07.347 ->
22:00:07.347 -> "angle" ang=43
22:00:07.347 -> "sin" sinus=0.68
22:00:07.347 -> "cos" cosinus=0.73
22:00:07.347 -> "atan2-rad" arctan_radiant=0.75
22:00:07.347 -> "atan2-deg" arctan_degree=43.00
22:00:07.347 ->
22:00:07.347 -> "angle" ang=44
22:00:07.347 -> "sin" sinus=0.69
22:00:07.347 -> "cos" cosinus=0.72
22:00:07.347 -> "atan2-rad" arctan_radiant=0.77
22:00:07.347 -> "atan2-deg" arctan_degree=44.00
22:00:07.347 ->
22:00:07.347 -> "angle" ang=45
22:00:07.347 -> "sin" sinus=0.71
22:00:07.347 -> "cos" cosinus=0.71
22:00:07.347 -> "atan2-rad" arctan_radiant=0.79
22:00:07.347 -> "atan2-deg" arctan_degree=45.00
22:00:07.347 ->
22:00:07.347 -> "angle" ang=46
22:00:07.394 -> "sin" sinus=0.72
22:00:07.394 -> "cos" cosinus=0.69
22:00:07.394 -> "atan2-rad" arctan_radiant=0.80
22:00:07.394 -> "atan2-deg" arctan_degree=46.00
22:00:07.394 ->
22:00:07.394 -> "angle" ang=47
22:00:07.394 -> "sin" sinus=0.73
22:00:07.394 -> "cos" cosinus=0.68
22:00:07.394 -> "atan2-rad" arctan_radiant=0.82
22:00:07.394 -> "atan2-deg" arctan_degree=47.00
22:00:07.394 ->
22:00:07.394 -> "angle" ang=48
22:00:07.394 -> "sin" sinus=0.74
22:00:07.394 -> "cos" cosinus=0.67
22:00:07.394 -> "atan2-rad" arctan_radiant=0.84
22:00:07.394 -> "atan2-deg" arctan_degree=48.00
22:00:07.394 ->
22:00:07.394 -> "angle" ang=49
22:00:07.394 -> "sin" sinus=0.75
22:00:07.394 -> "cos" cosinus=0.66
22:00:07.394 -> "atan2-rad" arctan_radiant=0.86
22:00:07.394 -> "atan2-deg" arctan_degree=49.00
22:00:07.394 ->
22:00:07.394 -> "angle" ang=50
22:00:07.394 -> "sin" sinus=0.77
22:00:07.394 -> "cos" cosinus=0.64
22:00:07.442 -> "atan2-rad" arctan_radiant=0.87
22:00:07.442 -> "atan2-deg" arctan_degree=50.00
22:00:07.442 ->
22:00:07.442 -> "angle" ang=51
22:00:07.442 -> "sin" sinus=0.78
22:00:07.442 -> "cos" cosinus=0.63
22:00:07.442 -> "atan2-rad" arctan_radiant=0.89
22:00:07.442 -> "atan2-deg" arctan_degree=51.00
22:00:07.442 ->
22:00:07.442 -> "angle" ang=52
22:00:07.442 -> "sin" sinus=0.79
22:00:07.442 -> "cos" cosinus=0.62
22:00:07.442 -> "atan2-rad" arctan_radiant=0.91
22:00:07.442 -> "atan2-deg" arctan_degree=52.00
22:00:07.442 ->
22:00:07.442 -> "angle" ang=53
22:00:07.442 -> "sin" sinus=0.80
22:00:07.442 -> "cos" cosinus=0.60
22:00:07.442 -> "atan2-rad" arctan_radiant=0.93
22:00:07.442 -> "atan2-deg" arctan_degree=53.00
22:00:07.442 ->
22:00:07.442 -> "angle" ang=54
22:00:07.442 -> "sin" sinus=0.81
22:00:07.442 -> "cos" cosinus=0.59
22:00:07.442 -> "atan2-rad" arctan_radiant=0.94
22:00:07.489 -> "atan2-deg" arctan_degree=54.00
22:00:07.489 ->
22:00:07.489 -> "angle" ang=55
22:00:07.489 -> "sin" sinus=0.82
22:00:07.489 -> "cos" cosinus=0.57
22:00:07.489 -> "atan2-rad" arctan_radiant=0.96
22:00:07.489 -> "atan2-deg" arctan_degree=55.00
22:00:07.489 ->
22:00:07.489 -> "angle" ang=56
22:00:07.489 -> "sin" sinus=0.83
22:00:07.489 -> "cos" cosinus=0.56
22:00:07.489 -> "atan2-rad" arctan_radiant=0.98
22:00:07.489 -> "atan2-deg" arctan_degree=56.00
22:00:07.489 ->
22:00:07.489 -> "angle" ang=57
22:00:07.489 -> "sin" sinus=0.84
22:00:07.489 -> "cos" cosinus=0.54
22:00:07.489 -> "atan2-rad" arctan_radiant=0.99
22:00:07.489 -> "atan2-deg" arctan_degree=57.00
22:00:07.489 ->
22:00:07.489 -> "angle" ang=58
22:00:07.489 -> "sin" sinus=0.85
22:00:07.489 -> "cos" cosinus=0.53
22:00:07.489 -> "atan2-rad" arctan_radiant=1.01
22:00:07.536 -> "atan2-deg" arctan_degree=58.00
22:00:07.536 ->
22:00:07.536 -> "angle" ang=59
22:00:07.536 -> "sin" sinus=0.86
22:00:07.536 -> "cos" cosinus=0.52
22:00:07.536 -> "atan2-rad" arctan_radiant=1.03
22:00:07.536 -> "atan2-deg" arctan_degree=59.00
22:00:07.536 ->
22:00:07.536 -> "angle" ang=60
22:00:07.536 -> "sin" sinus=0.87
22:00:07.536 -> "cos" cosinus=0.50
22:00:07.536 -> "atan2-rad" arctan_radiant=1.05
22:00:07.536 -> "atan2-deg" arctan_degree=60.00
22:00:07.536 ->
22:00:07.536 -> "angle" ang=61
22:00:07.536 -> "cos" cosinus=0.48
22:00:07.536 -> "atan2-rad" arctan_radiant=1.06
22:00:07.536 -> "atan2-deg" arctan_degree=61.00
22:00:07.536 ->
22:00:07.536 -> "angle" ang=62
22:00:07.536 -> "sin" sinus=0.88
22:00:07.536 -> "cos" cosinus=0.47
22:00:07.536 -> "atan2-rad" arctan_radiant=1.08
22:00:07.536 -> "atan2-deg" arctan_degree=62.00
22:00:07.583 ->
22:00:07.583 -> "angle" ang=63
22:00:07.583 -> "sin" sinus=0.89
22:00:07.583 -> "cos" cosinus=0.45
22:00:07.583 -> "atan2-rad" arctan_radiant=1.10
22:00:07.583 -> "atan2-deg" arctan_degree=63.00
22:00:07.583 ->
22:00:07.583 -> "angle" ang=64
22:00:07.583 -> "sin" sinus=0.90
22:00:07.583 -> "cos" cosinus=0.44
22:00:07.583 -> "atan2-rad" arctan_radiant=1.12
22:00:07.583 -> "atan2-deg" arctan_degree=64.00
22:00:07.583 ->
22:00:07.583 -> "angle" ang=65
22:00:07.583 -> "sin" sinus=0.91
22:00:07.583 -> "cos" cosinus=0.42
22:00:07.583 -> "atan2-rad" arctan_radiant=1.13
22:00:07.583 -> "atan2-deg" arctan_degree=65.00
22:00:07.583 ->
22:00:07.583 -> "angle" ang=66
22:00:07.583 -> "cos" cosinus=0.41
22:00:07.583 -> "atan2-rad" arctan_radiant=1.15
22:00:07.583 -> "atan2-deg" arctan_degree=66.00
22:00:07.583 ->
22:00:07.583 -> "angle" ang=67
22:00:07.631 -> "sin" sinus=0.92
22:00:07.631 -> "cos" cosinus=0.39
22:00:07.631 -> "atan2-rad" arctan_radiant=1.17
22:00:07.631 -> "atan2-deg" arctan_degree=67.00
22:00:07.631 ->
22:00:07.631 -> "angle" ang=68
22:00:07.631 -> "sin" sinus=0.93
22:00:07.631 -> "cos" cosinus=0.37
22:00:07.631 -> "atan2-rad" arctan_radiant=1.19
22:00:07.631 -> "atan2-deg" arctan_degree=68.00
22:00:07.631 ->
22:00:07.631 -> "angle" ang=69
22:00:07.631 -> "cos" cosinus=0.36
22:00:07.631 -> "atan2-rad" arctan_radiant=1.20
22:00:07.631 -> "atan2-deg" arctan_degree=69.00
22:00:07.631 ->
22:00:07.631 -> "angle" ang=70
22:00:07.631 -> "sin" sinus=0.94
22:00:07.631 -> "cos" cosinus=0.34
22:00:07.631 -> "atan2-rad" arctan_radiant=1.22
22:00:07.631 -> "atan2-deg" arctan_degree=70.00
22:00:07.631 ->
22:00:07.631 -> "angle" ang=71
22:00:07.631 -> "sin" sinus=0.95
22:00:07.631 -> "cos" cosinus=0.33
22:00:07.631 -> "atan2-rad" arctan_radiant=1.24
22:00:07.631 -> "atan2-deg" arctan_degree=71.00
22:00:07.631 ->
22:00:07.631 -> "angle" ang=72
22:00:07.631 -> "cos" cosinus=0.31
22:00:07.631 -> "atan2-rad" arctan_radiant=1.26
22:00:07.631 -> "atan2-deg" arctan_degree=72.00
22:00:07.631 ->
22:00:07.631 -> "angle" ang=73
22:00:07.631 -> "sin" sinus=0.96
22:00:07.631 -> "cos" cosinus=0.29
22:00:07.631 -> "atan2-rad" arctan_radiant=1.27
22:00:07.631 -> "atan2-deg" arctan_degree=73.00
22:00:07.631 ->
22:00:07.631 -> "angle" ang=74
22:00:07.631 -> "cos" cosinus=0.28
22:00:07.631 -> "atan2-rad" arctan_radiant=1.29
22:00:07.631 -> "atan2-deg" arctan_degree=74.00
22:00:07.631 ->
22:00:07.631 -> "angle" ang=75
22:00:07.631 -> "sin" sinus=0.97
22:00:07.631 -> "cos" cosinus=0.26
22:00:07.631 -> "atan2-rad" arctan_radiant=1.31
22:00:07.678 -> "atan2-deg" arctan_degree=75.00
22:00:07.678 ->
22:00:07.678 -> "angle" ang=76
22:00:07.678 -> "sin" sinus=0.97
22:00:07.678 -> "cos" cosinus=0.24
22:00:07.678 -> "atan2-rad" arctan_radiant=1.33
22:00:07.678 -> "atan2-deg" arctan_degree=76.00
22:00:07.678 ->
22:00:07.678 -> "angle" ang=77
22:00:07.678 -> "cos" cosinus=0.22
22:00:07.678 -> "atan2-rad" arctan_radiant=1.34
22:00:07.678 -> "atan2-deg" arctan_degree=77.00
22:00:07.678 ->
22:00:07.678 -> "angle" ang=78
22:00:07.678 -> "sin" sinus=0.98
22:00:07.678 -> "cos" cosinus=0.21
22:00:07.678 -> "atan2-rad" arctan_radiant=1.36
22:00:07.678 -> "atan2-deg" arctan_degree=78.00
22:00:07.678 ->
22:00:07.678 -> "angle" ang=79
22:00:07.678 -> "cos" cosinus=0.19
22:00:07.678 -> "atan2-rad" arctan_radiant=1.38
22:00:07.725 -> "atan2-deg" arctan_degree=79.00
22:00:07.725 ->
22:00:07.725 -> "angle" ang=80
22:00:07.725 -> "sin" sinus=0.98
22:00:07.725 -> "cos" cosinus=0.17
22:00:07.725 -> "atan2-rad" arctan_radiant=1.40
22:00:07.725 -> "atan2-deg" arctan_degree=80.00
22:00:07.725 ->
22:00:07.725 -> "angle" ang=81
22:00:07.725 -> "sin" sinus=0.99
22:00:07.725 -> "cos" cosinus=0.16
22:00:07.725 -> "atan2-rad" arctan_radiant=1.41
22:00:07.725 -> "atan2-deg" arctan_degree=81.00
22:00:07.725 ->
22:00:07.725 -> "angle" ang=82
22:00:07.725 -> "cos" cosinus=0.14
22:00:07.725 -> "atan2-rad" arctan_radiant=1.43
22:00:07.725 -> "atan2-deg" arctan_degree=82.00
22:00:07.725 ->
22:00:07.725 -> "angle" ang=83
22:00:07.725 -> "cos" cosinus=0.12
22:00:07.725 -> "atan2-rad" arctan_radiant=1.45
22:00:07.725 -> "atan2-deg" arctan_degree=83.00
22:00:07.773 ->
22:00:07.773 -> "angle" ang=84
22:00:07.773 -> "sin" sinus=0.99
22:00:07.773 -> "cos" cosinus=0.10
22:00:07.773 -> "atan2-rad" arctan_radiant=1.47
22:00:07.773 -> "atan2-deg" arctan_degree=84.00
22:00:07.773 ->
22:00:07.773 -> "angle" ang=85
22:00:07.773 -> "sin" sinus=1.00
22:00:07.773 -> "cos" cosinus=0.09
22:00:07.773 -> "atan2-rad" arctan_radiant=1.48
22:00:07.773 -> "atan2-deg" arctan_degree=85.00
22:00:07.773 ->
22:00:07.773 -> "angle" ang=86
22:00:07.773 -> "cos" cosinus=0.07
22:00:07.773 -> "atan2-rad" arctan_radiant=1.50
22:00:07.773 -> "atan2-deg" arctan_degree=86.00
22:00:07.773 ->
22:00:07.773 -> "angle" ang=87
22:00:07.773 -> "cos" cosinus=0.05
22:00:07.773 -> "atan2-rad" arctan_radiant=1.52
22:00:07.773 -> "atan2-deg" arctan_degree=87.00
22:00:07.773 ->
22:00:07.773 -> "angle" ang=88
22:00:07.819 -> "sin" sinus=1.00
22:00:07.819 -> "cos" cosinus=0.03
22:00:07.819 -> "atan2-rad" arctan_radiant=1.54
22:00:07.819 -> "atan2-deg" arctan_degree=88.00
22:00:07.819 ->
22:00:07.819 -> "angle" ang=89
22:00:07.819 -> "cos" cosinus=0.02
22:00:07.819 -> "atan2-rad" arctan_radiant=1.55
22:00:07.819 -> "atan2-deg" arctan_degree=89.00
22:00:07.819 ->
22:00:07.819 -> "angle" ang=90
22:00:07.819 -> "cos" cosinus=-0.00
22:00:07.819 -> "atan2-rad" arctan_radiant=1.57
22:00:07.819 -> "atan2-deg" arctan_degree=90.00
22:00:07.819 ->
22:00:07.819 -> "angle" ang=91
22:00:07.819 -> "cos" cosinus=-0.02
22:00:07.819 -> "atan2-rad" arctan_radiant=1.59
22:00:07.819 -> "atan2-deg" arctan_degree=91.00
22:00:07.819 ->
22:00:07.819 -> "angle" ang=92
22:00:07.867 -> "cos" cosinus=-0.03
22:00:07.867 -> "atan2-rad" arctan_radiant=1.61
22:00:07.867 -> "atan2-deg" arctan_degree=92.00
22:00:07.867 ->
22:00:07.867 -> "angle" ang=93
22:00:07.867 -> "sin" sinus=1.00
22:00:07.867 -> "cos" cosinus=-0.05
22:00:07.867 -> "atan2-rad" arctan_radiant=1.62
22:00:07.867 -> "atan2-deg" arctan_degree=93.00
22:00:07.867 ->
22:00:07.867 -> "angle" ang=94
22:00:07.867 -> "cos" cosinus=-0.07
22:00:07.867 -> "atan2-rad" arctan_radiant=1.64
22:00:07.867 -> "atan2-deg" arctan_degree=94.00
22:00:07.867 ->
22:00:07.867 -> "angle" ang=95
22:00:07.867 -> "cos" cosinus=-0.09
22:00:07.867 -> "atan2-rad" arctan_radiant=1.66
22:00:07.867 -> "atan2-deg" arctan_degree=95.00
22:00:07.867 ->
22:00:07.867 -> "angle" ang=96
22:00:07.867 -> "sin" sinus=0.99
22:00:07.867 -> "cos" cosinus=-0.10
22:00:07.914 -> "atan2-rad" arctan_radiant=1.68
22:00:07.914 -> "atan2-deg" arctan_degree=96.00
22:00:07.914 ->
22:00:07.914 -> "angle" ang=97
22:00:07.914 -> "sin" sinus=0.99
22:00:07.914 -> "cos" cosinus=-0.12
22:00:07.914 -> "atan2-rad" arctan_radiant=1.69
22:00:07.914 -> "atan2-deg" arctan_degree=97.00
22:00:07.914 ->
22:00:07.914 -> "angle" ang=98
22:00:07.914 -> "cos" cosinus=-0.14
22:00:07.914 -> "atan2-rad" arctan_radiant=1.71
22:00:07.914 -> "atan2-deg" arctan_degree=98.00
22:00:07.914 ->
22:00:07.914 -> "angle" ang=99
22:00:07.914 -> "cos" cosinus=-0.16
22:00:07.914 -> "atan2-rad" arctan_radiant=1.73
22:00:07.914 -> "atan2-deg" arctan_degree=99.00
22:00:07.914 ->
22:00:07.914 -> "angle" ang=100
22:00:07.914 -> "sin" sinus=0.98
22:00:07.914 -> "cos" cosinus=-0.17
22:00:07.914 -> "atan2-rad" arctan_radiant=1.75
22:00:07.961 -> "atan2-deg" arctan_degree=100.00
22:00:07.961 ->
22:00:07.961 -> "angle" ang=101
22:00:07.961 -> "sin" sinus=0.98
22:00:07.961 -> "cos" cosinus=-0.19
22:00:07.961 -> "atan2-rad" arctan_radiant=1.76
22:00:07.961 -> "atan2-deg" arctan_degree=101.00
22:00:07.961 ->
22:00:07.961 -> "angle" ang=102
22:00:07.961 -> "cos" cosinus=-0.21
22:00:07.961 -> "atan2-rad" arctan_radiant=1.78
22:00:07.961 -> "atan2-deg" arctan_degree=102.00
22:00:07.961 ->
22:00:07.961 -> "angle" ang=103
22:00:07.961 -> "sin" sinus=0.97
22:00:07.961 -> "cos" cosinus=-0.22
22:00:07.961 -> "atan2-rad" arctan_radiant=1.80
22:00:07.961 -> "atan2-deg" arctan_degree=103.00
22:00:07.961 ->
22:00:07.961 -> "angle" ang=104
22:00:07.961 -> "cos" cosinus=-0.24
22:00:07.961 -> "atan2-rad" arctan_radiant=1.82
22:00:08.008 -> "atan2-deg" arctan_degree=104.00
22:00:08.008 ->
22:00:08.008 -> "angle" ang=105
22:00:08.008 -> "sin" sinus=0.97
22:00:08.008 -> "cos" cosinus=-0.26
22:00:08.008 -> "atan2-rad" arctan_radiant=1.83
22:00:08.008 -> "atan2-deg" arctan_degree=105.00
22:00:08.008 ->
22:00:08.008 -> "angle" ang=106
22:00:08.008 -> "sin" sinus=0.96
22:00:08.008 -> "cos" cosinus=-0.28
22:00:08.008 -> "atan2-rad" arctan_radiant=1.85
22:00:08.008 -> "atan2-deg" arctan_degree=106.00
22:00:08.008 ->
22:00:08.008 -> "angle" ang=107
22:00:08.008 -> "cos" cosinus=-0.29
22:00:08.008 -> "atan2-rad" arctan_radiant=1.87
22:00:08.008 -> "atan2-deg" arctan_degree=107.00
22:00:08.008 ->
22:00:08.008 -> "angle" ang=108
22:00:08.008 -> "sin" sinus=0.95
22:00:08.008 -> "cos" cosinus=-0.31
22:00:08.008 -> "atan2-rad" arctan_radiant=1.88
22:00:08.008 -> "atan2-deg" arctan_degree=108.00
22:00:08.056 ->
22:00:08.056 -> "angle" ang=109
22:00:08.056 -> "sin" sinus=0.95
22:00:08.056 -> "cos" cosinus=-0.33
22:00:08.056 -> "atan2-rad" arctan_radiant=1.90
22:00:08.056 -> "atan2-deg" arctan_degree=109.00
22:00:08.056 ->
22:00:08.056 -> "angle" ang=110
22:00:08.056 -> "sin" sinus=0.94
22:00:08.056 -> "cos" cosinus=-0.34
22:00:08.056 -> "atan2-rad" arctan_radiant=1.92
22:00:08.056 -> "atan2-deg" arctan_degree=110.00
22:00:08.056 ->
22:00:08.056 -> "angle" ang=111
22:00:08.056 -> "sin" sinus=0.93
22:00:08.056 -> "cos" cosinus=-0.36
22:00:08.056 -> "atan2-rad" arctan_radiant=1.94
22:00:08.056 -> "atan2-deg" arctan_degree=111.00
22:00:08.056 ->
22:00:08.056 -> "angle" ang=112
22:00:08.056 -> "cos" cosinus=-0.37
22:00:08.056 -> "atan2-rad" arctan_radiant=1.95
22:00:08.056 -> "atan2-deg" arctan_degree=112.00
22:00:08.103 ->
22:00:08.103 -> "angle" ang=113
22:00:08.103 -> "sin" sinus=0.92
22:00:08.103 -> "cos" cosinus=-0.39
22:00:08.103 -> "atan2-rad" arctan_radiant=1.97
22:00:08.103 -> "atan2-deg" arctan_degree=113.00
22:00:08.103 ->
22:00:08.103 -> "angle" ang=114
22:00:08.103 -> "sin" sinus=0.91
22:00:08.103 -> "cos" cosinus=-0.41
22:00:08.103 -> "atan2-rad" arctan_radiant=1.99
22:00:08.103 -> "atan2-deg" arctan_degree=114.00
22:00:08.103 ->
22:00:08.103 -> "angle" ang=115
22:00:08.103 -> "cos" cosinus=-0.42
22:00:08.103 -> "atan2-rad" arctan_radiant=2.01
22:00:08.103 -> "atan2-deg" arctan_degree=115.00
22:00:08.103 ->
22:00:08.103 -> "angle" ang=116
22:00:08.103 -> "sin" sinus=0.90
22:00:08.103 -> "cos" cosinus=-0.44
22:00:08.103 -> "atan2-rad" arctan_radiant=2.02
22:00:08.103 -> "atan2-deg" arctan_degree=116.00
22:00:08.150 ->
22:00:08.150 -> "angle" ang=117
22:00:08.150 -> "sin" sinus=0.89
22:00:08.150 -> "cos" cosinus=-0.45
22:00:08.150 -> "atan2-rad" arctan_radiant=2.04
22:00:08.150 -> "atan2-deg" arctan_degree=117.00
22:00:08.150 ->
22:00:08.150 -> "angle" ang=118
22:00:08.150 -> "sin" sinus=0.88
22:00:08.150 -> "cos" cosinus=-0.47
22:00:08.150 -> "atan2-rad" arctan_radiant=2.06
22:00:08.150 -> "atan2-deg" arctan_degree=118.00
22:00:08.150 ->
22:00:08.150 -> "angle" ang=119
22:00:08.150 -> "sin" sinus=0.87
22:00:08.150 -> "cos" cosinus=-0.48
22:00:08.150 -> "atan2-rad" arctan_radiant=2.08
22:00:08.150 -> "atan2-deg" arctan_degree=119.00
22:00:08.150 ->
22:00:08.150 -> "angle" ang=120
22:00:08.150 -> "cos" cosinus=-0.50
22:00:08.150 -> "atan2-rad" arctan_radiant=2.09
22:00:08.150 -> "atan2-deg" arctan_degree=120.00
22:00:08.150 ->
22:00:08.150 -> "angle" ang=121
22:00:08.196 -> "sin" sinus=0.86
22:00:08.196 -> "cos" cosinus=-0.52
22:00:08.196 -> "atan2-rad" arctan_radiant=2.11
22:00:08.196 -> "atan2-deg" arctan_degree=121.00
22:00:08.196 ->
22:00:08.196 -> "angle" ang=122
22:00:08.196 -> "sin" sinus=0.85
22:00:08.196 -> "cos" cosinus=-0.53
22:00:08.196 -> "atan2-rad" arctan_radiant=2.13
22:00:08.196 -> "atan2-deg" arctan_degree=122.00
22:00:08.196 ->
22:00:08.196 -> "angle" ang=123
22:00:08.196 -> "sin" sinus=0.84
22:00:08.196 -> "cos" cosinus=-0.54
22:00:08.196 -> "atan2-rad" arctan_radiant=2.15
22:00:08.196 -> "atan2-deg" arctan_degree=123.00
22:00:08.196 ->
22:00:08.196 -> "angle" ang=124
22:00:08.196 -> "sin" sinus=0.83
22:00:08.196 -> "cos" cosinus=-0.56
22:00:08.196 -> "atan2-rad" arctan_radiant=2.16
22:00:08.196 -> "atan2-deg" arctan_degree=124.00
22:00:08.196 ->
22:00:08.196 -> "angle" ang=125
22:00:08.196 -> "sin" sinus=0.82
22:00:08.196 -> "cos" cosinus=-0.57
22:00:08.196 -> "atan2-rad" arctan_radiant=2.18
22:00:08.196 -> "atan2-deg" arctan_degree=125.00
22:00:08.196 ->
22:00:08.196 -> "angle" ang=126
22:00:08.196 -> "sin" sinus=0.81
22:00:08.196 -> "cos" cosinus=-0.59
22:00:08.196 -> "atan2-rad" arctan_radiant=2.20
22:00:08.196 -> "atan2-deg" arctan_degree=126.00
22:00:08.196 ->
22:00:08.196 -> "angle" ang=127
22:00:08.196 -> "sin" sinus=0.80
22:00:08.196 -> "cos" cosinus=-0.60
22:00:08.196 -> "atan2-rad" arctan_radiant=2.22
22:00:08.196 -> "atan2-deg" arctan_degree=127.00
22:00:08.196 ->
22:00:08.196 -> "angle" ang=128
22:00:08.196 -> "sin" sinus=0.79
22:00:08.196 -> "cos" cosinus=-0.62
22:00:08.196 -> "atan2-rad" arctan_radiant=2.23
22:00:08.196 -> "atan2-deg" arctan_degree=128.00
22:00:08.196 ->
22:00:08.196 -> "angle" ang=129
22:00:08.196 -> "sin" sinus=0.78
22:00:08.244 -> "cos" cosinus=-0.63
22:00:08.244 -> "atan2-rad" arctan_radiant=2.25
22:00:08.244 -> "atan2-deg" arctan_degree=129.00
22:00:08.244 ->
22:00:08.244 -> "angle" ang=130
22:00:08.244 -> "sin" sinus=0.77
22:00:08.244 -> "cos" cosinus=-0.64
22:00:08.244 -> "atan2-rad" arctan_radiant=2.27
22:00:08.244 -> "atan2-deg" arctan_degree=130.00
22:00:08.244 ->
22:00:08.244 -> "angle" ang=131
22:00:08.244 -> "sin" sinus=0.75
22:00:08.244 -> "cos" cosinus=-0.66
22:00:08.244 -> "atan2-rad" arctan_radiant=2.29
22:00:08.244 -> "atan2-deg" arctan_degree=131.00
22:00:08.244 ->
22:00:08.244 -> "angle" ang=132
22:00:08.244 -> "sin" sinus=0.74
22:00:08.244 -> "cos" cosinus=-0.67
22:00:08.244 -> "atan2-rad" arctan_radiant=2.30
22:00:08.244 -> "atan2-deg" arctan_degree=132.00
22:00:08.244 ->
22:00:08.244 -> "angle" ang=133
22:00:08.244 -> "sin" sinus=0.73
22:00:08.244 -> "cos" cosinus=-0.68
22:00:08.291 -> "atan2-rad" arctan_radiant=2.32
22:00:08.291 -> "atan2-deg" arctan_degree=133.00
22:00:08.291 ->
22:00:08.291 -> "angle" ang=134
22:00:08.291 -> "sin" sinus=0.72
22:00:08.291 -> "cos" cosinus=-0.69
22:00:08.291 -> "atan2-rad" arctan_radiant=2.34
22:00:08.291 -> "atan2-deg" arctan_degree=134.00
22:00:08.291 ->
22:00:08.291 -> "angle" ang=135
22:00:08.291 -> "sin" sinus=0.71
22:00:08.291 -> "cos" cosinus=-0.71
22:00:08.291 -> "atan2-rad" arctan_radiant=2.36
22:00:08.291 -> "atan2-deg" arctan_degree=135.00
22:00:08.291 ->
22:00:08.291 -> "angle" ang=136
22:00:08.291 -> "sin" sinus=0.69
22:00:08.291 -> "cos" cosinus=-0.72
22:00:08.291 -> "atan2-rad" arctan_radiant=2.37
22:00:08.291 -> "atan2-deg" arctan_degree=136.00
22:00:08.291 ->
22:00:08.291 -> "angle" ang=137
22:00:08.291 -> "sin" sinus=0.68
22:00:08.291 -> "cos" cosinus=-0.73
22:00:08.338 -> "atan2-rad" arctan_radiant=2.39
22:00:08.338 -> "atan2-deg" arctan_degree=137.00
22:00:08.338 ->
22:00:08.338 -> "angle" ang=138
22:00:08.338 -> "sin" sinus=0.67
22:00:08.338 -> "cos" cosinus=-0.74
22:00:08.338 -> "atan2-rad" arctan_radiant=2.41
22:00:08.338 -> "atan2-deg" arctan_degree=138.00
22:00:08.338 ->
22:00:08.338 -> "angle" ang=139
22:00:08.338 -> "sin" sinus=0.66
22:00:08.338 -> "cos" cosinus=-0.75
22:00:08.338 -> "atan2-rad" arctan_radiant=2.43
22:00:08.338 -> "atan2-deg" arctan_degree=139.00
22:00:08.338 ->
22:00:08.338 -> "angle" ang=140
22:00:08.338 -> "sin" sinus=0.64
22:00:08.338 -> "cos" cosinus=-0.77
22:00:08.338 -> "atan2-rad" arctan_radiant=2.44
22:00:08.338 -> "atan2-deg" arctan_degree=140.00
22:00:08.338 ->
22:00:08.338 -> "angle" ang=141
22:00:08.338 -> "sin" sinus=0.63
22:00:08.338 -> "cos" cosinus=-0.78
22:00:08.338 -> "atan2-rad" arctan_radiant=2.46
22:00:08.385 -> "atan2-deg" arctan_degree=141.00
22:00:08.385 ->
22:00:08.385 -> "angle" ang=142
22:00:08.385 -> "sin" sinus=0.62
22:00:08.385 -> "cos" cosinus=-0.79
22:00:08.385 -> "atan2-rad" arctan_radiant=2.48
22:00:08.385 -> "atan2-deg" arctan_degree=142.00
22:00:08.385 ->
22:00:08.385 -> "angle" ang=143
22:00:08.385 -> "sin" sinus=0.60
22:00:08.385 -> "cos" cosinus=-0.80
22:00:08.385 -> "atan2-rad" arctan_radiant=2.50
22:00:08.385 -> "atan2-deg" arctan_degree=143.00
22:00:08.385 ->
22:00:08.385 -> "angle" ang=144
22:00:08.385 -> "sin" sinus=0.59
22:00:08.385 -> "cos" cosinus=-0.81
22:00:08.385 -> "atan2-rad" arctan_radiant=2.51
22:00:08.385 -> "atan2-deg" arctan_degree=144.00
22:00:08.385 ->
22:00:08.385 -> "angle" ang=145
22:00:08.385 -> "sin" sinus=0.57
22:00:08.385 -> "cos" cosinus=-0.82
22:00:08.385 -> "atan2-rad" arctan_radiant=2.53
22:00:08.432 -> "atan2-deg" arctan_degree=145.00
22:00:08.432 ->
22:00:08.432 -> "angle" ang=146
22:00:08.432 -> "sin" sinus=0.56
22:00:08.432 -> "cos" cosinus=-0.83
22:00:08.432 -> "atan2-rad" arctan_radiant=2.55
22:00:08.432 -> "atan2-deg" arctan_degree=146.00
22:00:08.432 ->
22:00:08.432 -> "angle" ang=147
22:00:08.432 -> "sin" sinus=0.54
22:00:08.432 -> "cos" cosinus=-0.84
22:00:08.432 -> "atan2-rad" arctan_radiant=2.57
22:00:08.432 -> "atan2-deg" arctan_degree=147.00
22:00:08.432 ->
22:00:08.432 -> "angle" ang=148
22:00:08.432 -> "sin" sinus=0.53
22:00:08.432 -> "cos" cosinus=-0.85
22:00:08.432 -> "atan2-rad" arctan_radiant=2.58
22:00:08.432 -> "atan2-deg" arctan_degree=148.00
22:00:08.432 ->
22:00:08.432 -> "angle" ang=149
22:00:08.432 -> "sin" sinus=0.52
22:00:08.432 -> "cos" cosinus=-0.86
22:00:08.432 -> "atan2-rad" arctan_radiant=2.60
22:00:08.479 -> "atan2-deg" arctan_degree=149.00
22:00:08.479 ->
22:00:08.479 -> "angle" ang=150
22:00:08.479 -> "sin" sinus=0.50
22:00:08.479 -> "cos" cosinus=-0.87
22:00:08.479 -> "atan2-rad" arctan_radiant=2.62
22:00:08.479 -> "atan2-deg" arctan_degree=150.00
22:00:08.479 ->
22:00:08.479 -> "angle" ang=151
22:00:08.479 -> "sin" sinus=0.48
22:00:08.479 -> "atan2-rad" arctan_radiant=2.64
22:00:08.479 -> "atan2-deg" arctan_degree=151.00
22:00:08.479 ->
22:00:08.479 -> "angle" ang=152
22:00:08.479 -> "sin" sinus=0.47
22:00:08.479 -> "cos" cosinus=-0.88
22:00:08.479 -> "atan2-rad" arctan_radiant=2.65
22:00:08.479 -> "atan2-deg" arctan_degree=152.00
22:00:08.479 ->
22:00:08.479 -> "angle" ang=153
22:00:08.479 -> "sin" sinus=0.45
22:00:08.479 -> "cos" cosinus=-0.89
22:00:08.479 -> "atan2-rad" arctan_radiant=2.67
22:00:08.479 -> "atan2-deg" arctan_degree=153.00
22:00:08.527 ->
22:00:08.527 -> "angle" ang=154
22:00:08.527 -> "sin" sinus=0.44
22:00:08.527 -> "cos" cosinus=-0.90
22:00:08.527 -> "atan2-rad" arctan_radiant=2.69
22:00:08.527 -> "atan2-deg" arctan_degree=154.00
22:00:08.527 ->
22:00:08.527 -> "angle" ang=155
22:00:08.527 -> "sin" sinus=0.42
22:00:08.527 -> "cos" cosinus=-0.91
22:00:08.527 -> "atan2-rad" arctan_radiant=2.71
22:00:08.527 -> "atan2-deg" arctan_degree=155.00
22:00:08.527 ->
22:00:08.527 -> "angle" ang=156
22:00:08.527 -> "sin" sinus=0.41
22:00:08.527 -> "atan2-rad" arctan_radiant=2.72
22:00:08.527 -> "atan2-deg" arctan_degree=156.00
22:00:08.527 ->
22:00:08.527 -> "angle" ang=157
22:00:08.527 -> "sin" sinus=0.39
22:00:08.527 -> "cos" cosinus=-0.92
22:00:08.527 -> "atan2-rad" arctan_radiant=2.74
22:00:08.527 -> "atan2-deg" arctan_degree=157.00
22:00:08.574 ->
22:00:08.574 -> "angle" ang=158
22:00:08.574 -> "sin" sinus=0.37
22:00:08.574 -> "cos" cosinus=-0.93
22:00:08.574 -> "atan2-rad" arctan_radiant=2.76
22:00:08.574 -> "atan2-deg" arctan_degree=158.00
22:00:08.574 ->
22:00:08.574 -> "angle" ang=159
22:00:08.574 -> "sin" sinus=0.36
22:00:08.574 -> "atan2-rad" arctan_radiant=2.78
22:00:08.574 -> "atan2-deg" arctan_degree=159.00
22:00:08.574 ->
22:00:08.574 -> "angle" ang=160
22:00:08.574 -> "sin" sinus=0.34
22:00:08.574 -> "cos" cosinus=-0.94
22:00:08.574 -> "atan2-rad" arctan_radiant=2.79
22:00:08.574 -> "atan2-deg" arctan_degree=160.00
22:00:08.574 ->
22:00:08.574 -> "angle" ang=161
22:00:08.574 -> "sin" sinus=0.33
22:00:08.574 -> "cos" cosinus=-0.95
22:00:08.574 -> "atan2-rad" arctan_radiant=2.81
22:00:08.574 -> "atan2-deg" arctan_degree=161.00
22:00:08.574 ->
22:00:08.621 -> "angle" ang=162
22:00:08.621 -> "sin" sinus=0.31
22:00:08.621 -> "cos" cosinus=-0.95
22:00:08.621 -> "atan2-rad" arctan_radiant=2.83
22:00:08.621 -> "atan2-deg" arctan_degree=162.00
22:00:08.621 ->
22:00:08.621 -> "angle" ang=163
22:00:08.621 -> "sin" sinus=0.29
22:00:08.621 -> "cos" cosinus=-0.96
22:00:08.621 -> "atan2-rad" arctan_radiant=2.84
22:00:08.621 -> "atan2-deg" arctan_degree=163.00
22:00:08.621 ->
22:00:08.621 -> "angle" ang=164
22:00:08.621 -> "sin" sinus=0.28
22:00:08.621 -> "atan2-rad" arctan_radiant=2.86
22:00:08.621 -> "atan2-deg" arctan_degree=164.00
22:00:08.621 ->
22:00:08.621 -> "angle" ang=165
22:00:08.621 -> "sin" sinus=0.26
22:00:08.621 -> "cos" cosinus=-0.97
22:00:08.621 -> "atan2-rad" arctan_radiant=2.88
22:00:08.621 -> "atan2-deg" arctan_degree=165.00
22:00:08.621 ->
22:00:08.621 -> "angle" ang=166
22:00:08.669 -> "sin" sinus=0.24
22:00:08.669 -> "cos" cosinus=-0.97
22:00:08.669 -> "atan2-rad" arctan_radiant=2.90
22:00:08.669 -> "atan2-deg" arctan_degree=166.00
22:00:08.669 ->
22:00:08.669 -> "angle" ang=167
22:00:08.669 -> "sin" sinus=0.22
22:00:08.669 -> "atan2-rad" arctan_radiant=2.91
22:00:08.669 -> "atan2-deg" arctan_degree=167.00
22:00:08.669 ->
22:00:08.669 -> "angle" ang=168
22:00:08.669 -> "sin" sinus=0.21
22:00:08.669 -> "cos" cosinus=-0.98
22:00:08.669 -> "atan2-rad" arctan_radiant=2.93
22:00:08.669 -> "atan2-deg" arctan_degree=168.00
22:00:08.669 ->
22:00:08.669 -> "angle" ang=169
22:00:08.669 -> "sin" sinus=0.19
22:00:08.669 -> "atan2-rad" arctan_radiant=2.95
22:00:08.669 -> "atan2-deg" arctan_degree=169.00
22:00:08.669 ->
22:00:08.669 -> "angle" ang=170
22:00:08.669 -> "sin" sinus=0.17
22:00:08.715 -> "cos" cosinus=-0.98
22:00:08.715 -> "atan2-rad" arctan_radiant=2.97
22:00:08.715 -> "atan2-deg" arctan_degree=170.00
22:00:08.715 ->
22:00:08.715 -> "angle" ang=171
22:00:08.715 -> "sin" sinus=0.16
22:00:08.715 -> "cos" cosinus=-0.99
22:00:08.715 -> "atan2-rad" arctan_radiant=2.98
22:00:08.715 -> "atan2-deg" arctan_degree=171.00
22:00:08.715 ->
22:00:08.715 -> "angle" ang=172
22:00:08.715 -> "sin" sinus=0.14
22:00:08.715 -> "atan2-rad" arctan_radiant=3.00
22:00:08.715 -> "atan2-deg" arctan_degree=172.00
22:00:08.715 ->
22:00:08.715 -> "angle" ang=173
22:00:08.715 -> "sin" sinus=0.12
22:00:08.715 -> "atan2-rad" arctan_radiant=3.02
22:00:08.715 -> "atan2-deg" arctan_degree=173.00
22:00:08.715 ->
22:00:08.715 -> "angle" ang=174
22:00:08.715 -> "sin" sinus=0.10
22:00:08.715 -> "atan2-rad" arctan_radiant=3.04
22:00:08.715 -> "atan2-deg" arctan_degree=174.00
22:00:08.715 ->
22:00:08.715 -> "angle" ang=175
22:00:08.715 -> "sin" sinus=0.09
22:00:08.715 -> "cos" cosinus=-1.00
22:00:08.715 -> "atan2-rad" arctan_radiant=3.05
22:00:08.715 -> "atan2-deg" arctan_degree=175.00
22:00:08.715 ->
22:00:08.715 -> "angle" ang=176
22:00:08.715 -> "sin" sinus=0.07
22:00:08.715 -> "atan2-rad" arctan_radiant=3.07
22:00:08.715 -> "atan2-deg" arctan_degree=176.00
22:00:08.715 ->
22:00:08.715 -> "angle" ang=177
22:00:08.715 -> "sin" sinus=0.05
22:00:08.715 -> "atan2-rad" arctan_radiant=3.09
22:00:08.715 -> "atan2-deg" arctan_degree=177.00
22:00:08.715 ->
22:00:08.715 -> "angle" ang=178
22:00:08.715 -> "sin" sinus=0.03
22:00:08.763 -> "atan2-rad" arctan_radiant=3.11
22:00:08.763 -> "atan2-deg" arctan_degree=178.00
22:00:08.763 ->
22:00:08.763 -> "angle" ang=179
22:00:08.763 -> "sin" sinus=0.02
22:00:08.763 -> "cos" cosinus=-1.00
22:00:08.763 -> "atan2-rad" arctan_radiant=3.12
22:00:08.763 -> "atan2-deg" arctan_degree=179.00
22:00:08.763 ->
22:00:08.763 -> "angle" ang=180
22:00:08.763 -> "sin" sinus=-0.00
22:00:08.763 -> "atan2-rad" arctan_radiant=-3.14
22:00:08.763 -> "atan2-deg" arctan_degree=-180.00
22:00:08.763 ->
22:00:08.763 -> "angle" ang=181
22:00:08.763 -> "sin" sinus=-0.02
22:00:08.763 -> "atan2-rad" arctan_radiant=-3.12
22:00:08.763 -> "atan2-deg" arctan_degree=-179.00
22:00:08.763 ->
22:00:08.763 -> "angle" ang=182
22:00:08.763 -> "sin" sinus=-0.03
22:00:08.810 -> "atan2-rad" arctan_radiant=-3.11
22:00:08.810 -> "atan2-deg" arctan_degree=-178.00
22:00:08.810 ->
22:00:08.810 -> "angle" ang=183
22:00:08.810 -> "sin" sinus=-0.05
22:00:08.810 -> "cos" cosinus=-1.00
22:00:08.810 -> "atan2-rad" arctan_radiant=-3.09
22:00:08.810 -> "atan2-deg" arctan_degree=-177.00
22:00:08.810 ->
22:00:08.810 -> "angle" ang=184
22:00:08.810 -> "sin" sinus=-0.07
22:00:08.810 -> "atan2-rad" arctan_radiant=-3.07
22:00:08.810 -> "atan2-deg" arctan_degree=-176.00
22:00:08.810 ->
22:00:08.810 -> "angle" ang=185
22:00:08.810 -> "sin" sinus=-0.09
22:00:08.810 -> "atan2-rad" arctan_radiant=-3.05
22:00:08.810 -> "atan2-deg" arctan_degree=-175.00
22:00:08.810 ->
22:00:08.810 -> "angle" ang=186
22:00:08.810 -> "sin" sinus=-0.10
22:00:08.810 -> "cos" cosinus=-0.99
22:00:08.858 -> "atan2-rad" arctan_radiant=-3.04
22:00:08.858 -> "atan2-deg" arctan_degree=-174.00
22:00:08.858 ->
22:00:08.858 -> "angle" ang=187
22:00:08.858 -> "sin" sinus=-0.12
22:00:08.858 -> "cos" cosinus=-0.99
22:00:08.858 -> "atan2-rad" arctan_radiant=-3.02
22:00:08.858 -> "atan2-deg" arctan_degree=-173.00
22:00:08.858 ->
22:00:08.858 -> "angle" ang=188
22:00:08.858 -> "sin" sinus=-0.14
22:00:08.858 -> "atan2-rad" arctan_radiant=-3.00
22:00:08.858 -> "atan2-deg" arctan_degree=-172.00
22:00:08.858 ->
22:00:08.858 -> "angle" ang=189
22:00:08.858 -> "sin" sinus=-0.16
22:00:08.858 -> "atan2-rad" arctan_radiant=-2.98
22:00:08.858 -> "atan2-deg" arctan_degree=-171.00
22:00:08.858 ->
22:00:08.858 -> "angle" ang=190
22:00:08.858 -> "sin" sinus=-0.17
22:00:08.858 -> "cos" cosinus=-0.98
22:00:08.904 -> "atan2-rad" arctan_radiant=-2.97
22:00:08.904 -> "atan2-deg" arctan_degree=-170.00
22:00:08.904 ->
22:00:08.904 -> "angle" ang=191
22:00:08.904 -> "sin" sinus=-0.19
22:00:08.904 -> "cos" cosinus=-0.98
22:00:08.904 -> "atan2-rad" arctan_radiant=-2.95
22:00:08.904 -> "atan2-deg" arctan_degree=-169.00
22:00:08.904 ->
22:00:08.904 -> "angle" ang=192
22:00:08.904 -> "sin" sinus=-0.21
22:00:08.904 -> "atan2-rad" arctan_radiant=-2.93
22:00:08.904 -> "atan2-deg" arctan_degree=-168.00
22:00:08.904 ->
22:00:08.904 -> "angle" ang=193
22:00:08.904 -> "sin" sinus=-0.22
22:00:08.904 -> "cos" cosinus=-0.97
22:00:08.904 -> "atan2-rad" arctan_radiant=-2.91
22:00:08.904 -> "atan2-deg" arctan_degree=-167.00
22:00:08.904 ->
22:00:08.904 -> "angle" ang=194
22:00:08.904 -> "sin" sinus=-0.24
22:00:08.952 -> "atan2-rad" arctan_radiant=-2.90
22:00:08.952 -> "atan2-deg" arctan_degree=-166.00
22:00:08.952 ->
22:00:08.952 -> "angle" ang=195
22:00:08.952 -> "sin" sinus=-0.26
22:00:08.952 -> "cos" cosinus=-0.97
22:00:08.952 -> "atan2-rad" arctan_radiant=-2.88
22:00:08.952 -> "atan2-deg" arctan_degree=-165.00
22:00:08.952 ->
22:00:08.952 -> "angle" ang=196
22:00:08.952 -> "sin" sinus=-0.28
22:00:08.952 -> "cos" cosinus=-0.96
22:00:08.952 -> "atan2-rad" arctan_radiant=-2.86
22:00:08.952 -> "atan2-deg" arctan_degree=-164.00
22:00:08.952 ->
22:00:08.952 -> "angle" ang=197
22:00:08.952 -> "sin" sinus=-0.29
22:00:08.952 -> "atan2-rad" arctan_radiant=-2.84
22:00:08.952 -> "atan2-deg" arctan_degree=-163.00
22:00:08.952 ->
22:00:08.952 -> "angle" ang=198
22:00:08.952 -> "sin" sinus=-0.31
22:00:08.952 -> "cos" cosinus=-0.95
22:00:08.999 -> "atan2-rad" arctan_radiant=-2.83
22:00:08.999 -> "atan2-deg" arctan_degree=-162.00
22:00:08.999 ->
22:00:08.999 -> "angle" ang=199
22:00:08.999 -> "sin" sinus=-0.33
22:00:08.999 -> "cos" cosinus=-0.95
22:00:08.999 -> "atan2-rad" arctan_radiant=-2.81
22:00:08.999 -> "atan2-deg" arctan_degree=-161.00
22:00:08.999 ->
22:00:08.999 -> "angle" ang=200
22:00:08.999 -> "sin" sinus=-0.34
22:00:08.999 -> "cos" cosinus=-0.94
22:00:08.999 -> "atan2-rad" arctan_radiant=-2.79
22:00:08.999 -> "atan2-deg" arctan_degree=-160.00
22:00:08.999 ->
22:00:08.999 -> "angle" ang=201
22:00:08.999 -> "sin" sinus=-0.36
22:00:08.999 -> "cos" cosinus=-0.93
22:00:08.999 -> "atan2-rad" arctan_radiant=-2.78
22:00:08.999 -> "atan2-deg" arctan_degree=-159.00
22:00:08.999 ->
22:00:08.999 -> "angle" ang=202
22:00:08.999 -> "sin" sinus=-0.37
22:00:09.046 -> "atan2-rad" arctan_radiant=-2.76
22:00:09.046 -> "atan2-deg" arctan_degree=-158.00
22:00:09.046 ->
22:00:09.046 -> "angle" ang=203
22:00:09.046 -> "sin" sinus=-0.39
22:00:09.046 -> "cos" cosinus=-0.92
22:00:09.046 -> "atan2-rad" arctan_radiant=-2.74
22:00:09.046 -> "atan2-deg" arctan_degree=-157.00
22:00:09.046 ->
22:00:09.046 -> "angle" ang=204
22:00:09.046 -> "sin" sinus=-0.41
22:00:09.046 -> "cos" cosinus=-0.91
22:00:09.046 -> "atan2-rad" arctan_radiant=-2.72
22:00:09.046 -> "atan2-deg" arctan_degree=-156.00
22:00:09.046 ->
22:00:09.046 -> "angle" ang=205
22:00:09.046 -> "sin" sinus=-0.42
22:00:09.046 -> "atan2-rad" arctan_radiant=-2.71
22:00:09.046 -> "atan2-deg" arctan_degree=-155.00
22:00:09.046 ->
22:00:09.046 -> "angle" ang=206
22:00:09.046 -> "sin" sinus=-0.44
22:00:09.046 -> "cos" cosinus=-0.90
22:00:09.093 -> "atan2-rad" arctan_radiant=-2.69
22:00:09.093 -> "atan2-deg" arctan_degree=-154.00
22:00:09.093 ->
22:00:09.093 -> "angle" ang=207
22:00:09.093 -> "sin" sinus=-0.45
22:00:09.093 -> "cos" cosinus=-0.89
22:00:09.093 -> "atan2-rad" arctan_radiant=-2.67
22:00:09.093 -> "atan2-deg" arctan_degree=-153.00
22:00:09.093 ->
22:00:09.093 -> "angle" ang=208
22:00:09.093 -> "sin" sinus=-0.47
22:00:09.093 -> "cos" cosinus=-0.88
22:00:09.093 -> "atan2-rad" arctan_radiant=-2.65
22:00:09.093 -> "atan2-deg" arctan_degree=-152.00
22:00:09.093 ->
22:00:09.093 -> "angle" ang=209
22:00:09.093 -> "sin" sinus=-0.48
22:00:09.093 -> "cos" cosinus=-0.87
22:00:09.093 -> "atan2-rad" arctan_radiant=-2.64
22:00:09.093 -> "atan2-deg" arctan_degree=-151.00
22:00:09.093 ->
22:00:09.093 -> "angle" ang=210
22:00:09.093 -> "sin" sinus=-0.50
22:00:09.141 -> "atan2-rad" arctan_radiant=-2.62
22:00:09.141 -> "atan2-deg" arctan_degree=-150.00
22:00:09.141 ->
22:00:09.141 -> "angle" ang=211
22:00:09.141 -> "sin" sinus=-0.52
22:00:09.141 -> "cos" cosinus=-0.86
22:00:09.141 -> "atan2-rad" arctan_radiant=-2.60
22:00:09.141 -> "atan2-deg" arctan_degree=-149.00
22:00:09.141 ->
22:00:09.141 -> "angle" ang=212
22:00:09.141 -> "sin" sinus=-0.53
22:00:09.141 -> "cos" cosinus=-0.85
22:00:09.141 -> "atan2-rad" arctan_radiant=-2.58
22:00:09.141 -> "atan2-deg" arctan_degree=-148.00
22:00:09.141 ->
22:00:09.141 -> "angle" ang=213
22:00:09.141 -> "sin" sinus=-0.54
22:00:09.141 -> "cos" cosinus=-0.84
22:00:09.141 -> "atan2-rad" arctan_radiant=-2.57
22:00:09.141 -> "atan2-deg" arctan_degree=-147.00
22:00:09.141 ->
22:00:09.141 -> "angle" ang=214
22:00:09.141 -> "sin" sinus=-0.56
22:00:09.141 -> "cos" cosinus=-0.83
22:00:09.188 -> "atan2-rad" arctan_radiant=-2.55
22:00:09.188 -> "atan2-deg" arctan_degree=-146.00
22:00:09.188 ->
22:00:09.188 -> "angle" ang=215
22:00:09.188 -> "sin" sinus=-0.57
22:00:09.188 -> "cos" cosinus=-0.82
22:00:09.188 -> "atan2-rad" arctan_radiant=-2.53
22:00:09.188 -> "atan2-deg" arctan_degree=-145.00
22:00:09.188 ->
22:00:09.188 -> "angle" ang=216
22:00:09.188 -> "sin" sinus=-0.59
22:00:09.188 -> "cos" cosinus=-0.81
22:00:09.188 -> "atan2-rad" arctan_radiant=-2.51
22:00:09.188 -> "atan2-deg" arctan_degree=-144.00
22:00:09.188 ->
22:00:09.188 -> "angle" ang=217
22:00:09.188 -> "sin" sinus=-0.60
22:00:09.188 -> "cos" cosinus=-0.80
22:00:09.188 -> "atan2-rad" arctan_radiant=-2.50
22:00:09.188 -> "atan2-deg" arctan_degree=-143.00
22:00:09.188 ->
22:00:09.188 -> "angle" ang=218
22:00:09.188 -> "sin" sinus=-0.62
22:00:09.188 -> "cos" cosinus=-0.79
22:00:09.236 -> "atan2-rad" arctan_radiant=-2.48
22:00:09.236 -> "atan2-deg" arctan_degree=-142.00
22:00:09.236 ->
22:00:09.236 -> "angle" ang=219
22:00:09.236 -> "sin" sinus=-0.63
22:00:09.236 -> "cos" cosinus=-0.78
22:00:09.236 -> "atan2-rad" arctan_radiant=-2.46
22:00:09.236 -> "atan2-deg" arctan_degree=-141.00
22:00:09.236 ->
22:00:09.236 -> "angle" ang=220
22:00:09.236 -> "sin" sinus=-0.64
22:00:09.236 -> "cos" cosinus=-0.77
22:00:09.236 -> "atan2-rad" arctan_radiant=-2.44
22:00:09.236 -> "atan2-deg" arctan_degree=-140.00
22:00:09.236 ->
22:00:09.236 -> "angle" ang=221
22:00:09.236 -> "sin" sinus=-0.66
22:00:09.236 -> "cos" cosinus=-0.75
22:00:09.236 -> "atan2-rad" arctan_radiant=-2.43
22:00:09.236 -> "atan2-deg" arctan_degree=-139.00
22:00:09.236 ->
22:00:09.236 -> "angle" ang=222
22:00:09.236 -> "sin" sinus=-0.67
22:00:09.236 -> "cos" cosinus=-0.74
22:00:09.283 -> "atan2-rad" arctan_radiant=-2.41
22:00:09.283 -> "atan2-deg" arctan_degree=-138.00
22:00:09.283 ->
22:00:09.283 -> "angle" ang=223
22:00:09.283 -> "sin" sinus=-0.68
22:00:09.283 -> "cos" cosinus=-0.73
22:00:09.283 -> "atan2-rad" arctan_radiant=-2.39
22:00:09.283 -> "atan2-deg" arctan_degree=-137.00
22:00:09.283 ->
22:00:09.283 -> "angle" ang=224
22:00:09.283 -> "sin" sinus=-0.69
22:00:09.283 -> "cos" cosinus=-0.72
22:00:09.283 -> "atan2-rad" arctan_radiant=-2.37
22:00:09.283 -> "atan2-deg" arctan_degree=-136.00
22:00:09.283 ->
22:00:09.283 -> "angle" ang=225
22:00:09.283 -> "sin" sinus=-0.71
22:00:09.283 -> "cos" cosinus=-0.71
22:00:09.283 -> "atan2-rad" arctan_radiant=-2.36
22:00:09.283 -> "atan2-deg" arctan_degree=-135.00
22:00:09.283 ->
22:00:09.283 -> "angle" ang=226
22:00:09.283 -> "sin" sinus=-0.72
22:00:09.283 -> "cos" cosinus=-0.69
22:00:09.283 -> "atan2-rad" arctan_radiant=-2.34
22:00:09.283 -> "atan2-deg" arctan_degree=-134.00
22:00:09.283 ->
22:00:09.283 -> "angle" ang=227
22:00:09.283 -> "sin" sinus=-0.73
22:00:09.283 -> "cos" cosinus=-0.68
22:00:09.283 -> "atan2-rad" arctan_radiant=-2.32
22:00:09.283 -> "atan2-deg" arctan_degree=-133.00
22:00:09.283 ->
22:00:09.283 -> "angle" ang=228
22:00:09.283 -> "sin" sinus=-0.74
22:00:09.283 -> "cos" cosinus=-0.67
22:00:09.283 -> "atan2-rad" arctan_radiant=-2.30
22:00:09.283 -> "atan2-deg" arctan_degree=-132.00
22:00:09.283 ->
22:00:09.283 -> "angle" ang=229
22:00:09.283 -> "sin" sinus=-0.75
22:00:09.283 -> "cos" cosinus=-0.66
22:00:09.283 -> "atan2-rad" arctan_radiant=-2.29
22:00:09.283 -> "atan2-deg" arctan_degree=-131.00
22:00:09.283 ->
22:00:09.283 -> "angle" ang=230
22:00:09.283 -> "sin" sinus=-0.77
22:00:09.283 -> "cos" cosinus=-0.64
22:00:09.330 -> "atan2-rad" arctan_radiant=-2.27
22:00:09.330 -> "atan2-deg" arctan_degree=-130.00
22:00:09.330 ->
22:00:09.330 -> "angle" ang=231
22:00:09.330 -> "sin" sinus=-0.78
22:00:09.330 -> "cos" cosinus=-0.63
22:00:09.330 -> "atan2-rad" arctan_radiant=-2.25
22:00:09.330 -> "atan2-deg" arctan_degree=-129.00
22:00:09.330 ->
22:00:09.330 -> "angle" ang=232
22:00:09.330 -> "sin" sinus=-0.79
22:00:09.330 -> "cos" cosinus=-0.62
22:00:09.330 -> "atan2-rad" arctan_radiant=-2.23
22:00:09.330 -> "atan2-deg" arctan_degree=-128.00
22:00:09.330 ->
22:00:09.330 -> "angle" ang=233
22:00:09.330 -> "sin" sinus=-0.80
22:00:09.330 -> "cos" cosinus=-0.60
22:00:09.330 -> "atan2-rad" arctan_radiant=-2.22
22:00:09.330 -> "atan2-deg" arctan_degree=-127.00
22:00:09.330 ->
22:00:09.330 -> "angle" ang=234
22:00:09.330 -> "sin" sinus=-0.81
22:00:09.330 -> "cos" cosinus=-0.59
22:00:09.377 -> "atan2-rad" arctan_radiant=-2.20
22:00:09.377 -> "atan2-deg" arctan_degree=-126.00
22:00:09.377 ->
22:00:09.377 -> "angle" ang=235
22:00:09.377 -> "sin" sinus=-0.82
22:00:09.377 -> "cos" cosinus=-0.57
22:00:09.377 -> "atan2-rad" arctan_radiant=-2.18
22:00:09.377 -> "atan2-deg" arctan_degree=-125.00
22:00:09.377 ->
22:00:09.377 -> "angle" ang=236
22:00:09.377 -> "sin" sinus=-0.83
22:00:09.377 -> "cos" cosinus=-0.56
22:00:09.377 -> "atan2-rad" arctan_radiant=-2.16
22:00:09.377 -> "atan2-deg" arctan_degree=-124.00
22:00:09.377 ->
22:00:09.377 -> "angle" ang=237
22:00:09.377 -> "sin" sinus=-0.84
22:00:09.377 -> "cos" cosinus=-0.54
22:00:09.377 -> "atan2-rad" arctan_radiant=-2.15
22:00:09.377 -> "atan2-deg" arctan_degree=-123.00
22:00:09.377 ->
22:00:09.377 -> "angle" ang=238
22:00:09.377 -> "sin" sinus=-0.85
22:00:09.377 -> "cos" cosinus=-0.53
22:00:09.424 -> "atan2-rad" arctan_radiant=-2.13
22:00:09.424 -> "atan2-deg" arctan_degree=-122.00
22:00:09.424 ->
22:00:09.424 -> "angle" ang=239
22:00:09.424 -> "sin" sinus=-0.86
22:00:09.424 -> "cos" cosinus=-0.52
22:00:09.424 -> "atan2-rad" arctan_radiant=-2.11
22:00:09.424 -> "atan2-deg" arctan_degree=-121.00
22:00:09.424 ->
22:00:09.424 -> "angle" ang=240
22:00:09.424 -> "sin" sinus=-0.87
22:00:09.424 -> "cos" cosinus=-0.50
22:00:09.424 -> "atan2-rad" arctan_radiant=-2.09
22:00:09.424 -> "atan2-deg" arctan_degree=-120.00
22:00:09.424 ->
22:00:09.424 -> "angle" ang=241
22:00:09.424 -> "cos" cosinus=-0.48
22:00:09.424 -> "atan2-rad" arctan_radiant=-2.08
22:00:09.424 -> "atan2-deg" arctan_degree=-119.00
22:00:09.424 ->
22:00:09.424 -> "angle" ang=242
22:00:09.424 -> "sin" sinus=-0.88
22:00:09.424 -> "cos" cosinus=-0.47
22:00:09.472 -> "atan2-rad" arctan_radiant=-2.06
22:00:09.472 -> "atan2-deg" arctan_degree=-118.00
22:00:09.472 ->
22:00:09.472 -> "angle" ang=243
22:00:09.472 -> "sin" sinus=-0.89
22:00:09.472 -> "cos" cosinus=-0.45
22:00:09.472 -> "atan2-rad" arctan_radiant=-2.04
22:00:09.472 -> "atan2-deg" arctan_degree=-117.00
22:00:09.472 ->
22:00:09.472 -> "angle" ang=244
22:00:09.472 -> "sin" sinus=-0.90
22:00:09.472 -> "cos" cosinus=-0.44
22:00:09.472 -> "atan2-rad" arctan_radiant=-2.02
22:00:09.472 -> "atan2-deg" arctan_degree=-116.00
22:00:09.472 ->
22:00:09.472 -> "angle" ang=245
22:00:09.472 -> "sin" sinus=-0.91
22:00:09.472 -> "cos" cosinus=-0.42
22:00:09.472 -> "atan2-rad" arctan_radiant=-2.01
22:00:09.472 -> "atan2-deg" arctan_degree=-115.00
22:00:09.472 ->
22:00:09.472 -> "angle" ang=246
22:00:09.472 -> "cos" cosinus=-0.41
22:00:09.519 -> "atan2-rad" arctan_radiant=-1.99
22:00:09.519 -> "atan2-deg" arctan_degree=-114.00
22:00:09.519 ->
22:00:09.519 -> "angle" ang=247
22:00:09.519 -> "sin" sinus=-0.92
22:00:09.519 -> "cos" cosinus=-0.39
22:00:09.519 -> "atan2-rad" arctan_radiant=-1.97
22:00:09.519 -> "atan2-deg" arctan_degree=-113.00
22:00:09.519 ->
22:00:09.519 -> "angle" ang=248
22:00:09.519 -> "sin" sinus=-0.93
22:00:09.519 -> "cos" cosinus=-0.37
22:00:09.519 -> "atan2-rad" arctan_radiant=-1.95
22:00:09.519 -> "atan2-deg" arctan_degree=-112.00
22:00:09.519 ->
22:00:09.519 -> "angle" ang=249
22:00:09.519 -> "cos" cosinus=-0.36
22:00:09.519 -> "atan2-rad" arctan_radiant=-1.94
22:00:09.519 -> "atan2-deg" arctan_degree=-111.00
22:00:09.519 ->
22:00:09.519 -> "angle" ang=250
22:00:09.519 -> "sin" sinus=-0.94
22:00:09.519 -> "cos" cosinus=-0.34
22:00:09.566 -> "atan2-rad" arctan_radiant=-1.92
22:00:09.566 -> "atan2-deg" arctan_degree=-110.00
22:00:09.566 ->
22:00:09.566 -> "angle" ang=251
22:00:09.566 -> "sin" sinus=-0.95
22:00:09.566 -> "cos" cosinus=-0.33
22:00:09.566 -> "atan2-rad" arctan_radiant=-1.90
22:00:09.566 -> "atan2-deg" arctan_degree=-109.00
22:00:09.566 ->
22:00:09.566 -> "angle" ang=252
22:00:09.566 -> "cos" cosinus=-0.31
22:00:09.566 -> "atan2-rad" arctan_radiant=-1.88
22:00:09.566 -> "atan2-deg" arctan_degree=-108.00
22:00:09.566 ->
22:00:09.566 -> "angle" ang=253
22:00:09.566 -> "sin" sinus=-0.96
22:00:09.566 -> "cos" cosinus=-0.29
22:00:09.566 -> "atan2-rad" arctan_radiant=-1.87
22:00:09.566 -> "atan2-deg" arctan_degree=-107.00
22:00:09.566 ->
22:00:09.566 -> "angle" ang=254
22:00:09.566 -> "cos" cosinus=-0.28
22:00:09.613 -> "atan2-rad" arctan_radiant=-1.85
22:00:09.613 -> "atan2-deg" arctan_degree=-106.00
22:00:09.613 ->
22:00:09.613 -> "angle" ang=255
22:00:09.613 -> "sin" sinus=-0.97
22:00:09.613 -> "cos" cosinus=-0.26
22:00:09.613 -> "atan2-rad" arctan_radiant=-1.83
22:00:09.613 -> "atan2-deg" arctan_degree=-105.00
22:00:09.613 ->
22:00:09.613 -> "angle" ang=256
22:00:09.613 -> "cos" cosinus=-0.24
22:00:09.613 -> "atan2-rad" arctan_radiant=-1.82
22:00:09.613 -> "atan2-deg" arctan_degree=-104.00
22:00:09.613 ->
22:00:09.613 -> "angle" ang=257
22:00:09.613 -> "cos" cosinus=-0.22
22:00:09.613 -> "atan2-rad" arctan_radiant=-1.80
22:00:09.613 -> "atan2-deg" arctan_degree=-103.00
22:00:09.613 ->
22:00:09.613 -> "angle" ang=258
22:00:09.613 -> "sin" sinus=-0.98
22:00:09.613 -> "cos" cosinus=-0.21
22:00:09.661 -> "atan2-rad" arctan_radiant=-1.78
22:00:09.661 -> "atan2-deg" arctan_degree=-102.00
22:00:09.661 ->
22:00:09.661 -> "angle" ang=259
22:00:09.661 -> "sin" sinus=-0.98
22:00:09.661 -> "cos" cosinus=-0.19
22:00:09.661 -> "atan2-rad" arctan_radiant=-1.76
22:00:09.661 -> "atan2-deg" arctan_degree=-101.00
22:00:09.661 ->
22:00:09.661 -> "angle" ang=260
22:00:09.661 -> "cos" cosinus=-0.17
22:00:09.661 -> "atan2-rad" arctan_radiant=-1.75
22:00:09.661 -> "atan2-deg" arctan_degree=-100.00
22:00:09.661 ->
22:00:09.661 -> "angle" ang=261
22:00:09.661 -> "sin" sinus=-0.99
22:00:09.661 -> "cos" cosinus=-0.16
22:00:09.661 -> "atan2-rad" arctan_radiant=-1.73
22:00:09.661 -> "atan2-deg" arctan_degree=-99.00
22:00:09.661 ->
22:00:09.661 -> "angle" ang=262
22:00:09.661 -> "cos" cosinus=-0.14
22:00:09.707 -> "atan2-rad" arctan_radiant=-1.71
22:00:09.707 -> "atan2-deg" arctan_degree=-98.00
22:00:09.707 ->
22:00:09.707 -> "angle" ang=263
22:00:09.707 -> "sin" sinus=-0.99
22:00:09.707 -> "cos" cosinus=-0.12
22:00:09.707 -> "atan2-rad" arctan_radiant=-1.69
22:00:09.707 -> "atan2-deg" arctan_degree=-97.00
22:00:09.707 ->
22:00:09.707 -> "angle" ang=264
22:00:09.707 -> "cos" cosinus=-0.10
22:00:09.707 -> "atan2-rad" arctan_radiant=-1.68
22:00:09.707 -> "atan2-deg" arctan_degree=-96.00
22:00:09.707 ->
22:00:09.707 -> "angle" ang=265
22:00:09.707 -> "sin" sinus=-1.00
22:00:09.707 -> "cos" cosinus=-0.09
22:00:09.707 -> "atan2-rad" arctan_radiant=-1.66
22:00:09.707 -> "atan2-deg" arctan_degree=-95.00
22:00:09.707 ->
22:00:09.707 -> "angle" ang=266
22:00:09.707 -> "cos" cosinus=-0.07
22:00:09.707 -> "atan2-rad" arctan_radiant=-1.64
22:00:09.756 -> "atan2-deg" arctan_degree=-94.00
22:00:09.756 ->
22:00:09.756 -> "angle" ang=267
22:00:09.756 -> "sin" sinus=-1.00
22:00:09.756 -> "cos" cosinus=-0.05
22:00:09.756 -> "atan2-rad" arctan_radiant=-1.62
22:00:09.756 -> "atan2-deg" arctan_degree=-93.00
22:00:09.756 ->
22:00:09.756 -> "angle" ang=268
22:00:09.756 -> "cos" cosinus=-0.03
22:00:09.756 -> "atan2-rad" arctan_radiant=-1.61
22:00:09.756 -> "atan2-deg" arctan_degree=-92.00
22:00:09.756 ->
22:00:09.756 -> "angle" ang=269
22:00:09.756 -> "cos" cosinus=-0.02
22:00:09.756 -> "atan2-rad" arctan_radiant=-1.59
22:00:09.756 -> "atan2-deg" arctan_degree=-91.00
22:00:09.756 ->
22:00:09.756 -> "angle" ang=270
22:00:09.756 -> "cos" cosinus=0.00
22:00:09.756 -> "atan2-rad" arctan_radiant=-1.57
22:00:09.802 -> "atan2-deg" arctan_degree=-90.00
22:00:09.802 ->
22:00:09.802 -> "angle" ang=271
22:00:09.802 -> "sin" sinus=-1.00
22:00:09.802 -> "cos" cosinus=0.02
22:00:09.802 -> "atan2-rad" arctan_radiant=-1.55
22:00:09.802 -> "atan2-deg" arctan_degree=-89.00
22:00:09.802 ->
22:00:09.802 -> "angle" ang=272
22:00:09.802 -> "cos" cosinus=0.03
22:00:09.802 -> "atan2-rad" arctan_radiant=-1.54
22:00:09.802 -> "atan2-deg" arctan_degree=-88.00
22:00:09.802 ->
22:00:09.802 -> "angle" ang=273
22:00:09.802 -> "cos" cosinus=0.05
22:00:09.802 -> "atan2-rad" arctan_radiant=-1.52
22:00:09.802 -> "atan2-deg" arctan_degree=-87.00
22:00:09.802 ->
22:00:09.802 -> "angle" ang=274
22:00:09.802 -> "cos" cosinus=0.07
22:00:09.802 -> "atan2-rad" arctan_radiant=-1.50
22:00:09.802 -> "atan2-deg" arctan_degree=-86.00
22:00:09.802 ->
22:00:09.802 -> "angle" ang=275
22:00:09.802 -> "cos" cosinus=0.09
22:00:09.802 -> "atan2-rad" arctan_radiant=-1.48
22:00:09.802 -> "atan2-deg" arctan_degree=-85.00
22:00:09.802 ->
22:00:09.802 -> "angle" ang=276
22:00:09.802 -> "sin" sinus=-0.99
22:00:09.802 -> "cos" cosinus=0.10
22:00:09.802 -> "atan2-rad" arctan_radiant=-1.47
22:00:09.802 -> "atan2-deg" arctan_degree=-84.00
22:00:09.802 ->
22:00:09.802 -> "angle" ang=277
22:00:09.802 -> "cos" cosinus=0.12
22:00:09.802 -> "atan2-rad" arctan_radiant=-1.45
22:00:09.802 -> "atan2-deg" arctan_degree=-83.00
22:00:09.802 ->
22:00:09.802 -> "angle" ang=278
22:00:09.802 -> "cos" cosinus=0.14
22:00:09.802 -> "atan2-rad" arctan_radiant=-1.43
22:00:09.850 -> "atan2-deg" arctan_degree=-82.00
22:00:09.850 ->
22:00:09.850 -> "angle" ang=279
22:00:09.850 -> "sin" sinus=-0.99
22:00:09.850 -> "cos" cosinus=0.16
22:00:09.850 -> "atan2-rad" arctan_radiant=-1.41
22:00:09.850 -> "atan2-deg" arctan_degree=-81.00
22:00:09.850 ->
22:00:09.850 -> "angle" ang=280
22:00:09.850 -> "sin" sinus=-0.98
22:00:09.850 -> "cos" cosinus=0.17
22:00:09.850 -> "atan2-rad" arctan_radiant=-1.40
22:00:09.850 -> "atan2-deg" arctan_degree=-80.00
22:00:09.850 ->
22:00:09.850 -> "angle" ang=281
22:00:09.850 -> "cos" cosinus=0.19
22:00:09.850 -> "atan2-rad" arctan_radiant=-1.38
22:00:09.850 -> "atan2-deg" arctan_degree=-79.00
22:00:09.850 ->
22:00:09.850 -> "angle" ang=282
22:00:09.850 -> "cos" cosinus=0.21
22:00:09.850 -> "atan2-rad" arctan_radiant=-1.36
22:00:09.897 -> "atan2-deg" arctan_degree=-78.00
22:00:09.897 ->
22:00:09.897 -> "angle" ang=283
22:00:09.897 -> "sin" sinus=-0.97
22:00:09.897 -> "cos" cosinus=0.22
22:00:09.897 -> "atan2-rad" arctan_radiant=-1.34
22:00:09.897 -> "atan2-deg" arctan_degree=-77.00
22:00:09.897 ->
22:00:09.897 -> "angle" ang=284
22:00:09.897 -> "cos" cosinus=0.24
22:00:09.897 -> "atan2-rad" arctan_radiant=-1.33
22:00:09.897 -> "atan2-deg" arctan_degree=-76.00
22:00:09.897 ->
22:00:09.897 -> "angle" ang=285
22:00:09.897 -> "cos" cosinus=0.26
22:00:09.897 -> "atan2-rad" arctan_radiant=-1.31
22:00:09.897 -> "atan2-deg" arctan_degree=-75.00
22:00:09.897 ->
22:00:09.897 -> "angle" ang=286
22:00:09.897 -> "sin" sinus=-0.96
22:00:09.897 -> "cos" cosinus=0.28
22:00:09.897 -> "atan2-rad" arctan_radiant=-1.29
22:00:09.897 -> "atan2-deg" arctan_degree=-74.00
22:00:09.944 ->
22:00:09.944 -> "angle" ang=287
22:00:09.944 -> "sin" sinus=-0.96
22:00:09.944 -> "cos" cosinus=0.29
22:00:09.944 -> "atan2-rad" arctan_radiant=-1.27
22:00:09.944 -> "atan2-deg" arctan_degree=-73.00
22:00:09.944 ->
22:00:09.944 -> "angle" ang=288
22:00:09.944 -> "sin" sinus=-0.95
22:00:09.944 -> "cos" cosinus=0.31
22:00:09.944 -> "atan2-rad" arctan_radiant=-1.26
22:00:09.944 -> "atan2-deg" arctan_degree=-72.00
22:00:09.944 ->
22:00:09.944 -> "angle" ang=289
22:00:09.944 -> "cos" cosinus=0.33
22:00:09.944 -> "atan2-rad" arctan_radiant=-1.24
22:00:09.944 -> "atan2-deg" arctan_degree=-71.00
22:00:09.944 ->
22:00:09.944 -> "angle" ang=290
22:00:09.944 -> "sin" sinus=-0.94
22:00:09.944 -> "cos" cosinus=0.34
22:00:09.944 -> "atan2-rad" arctan_radiant=-1.22
22:00:09.944 -> "atan2-deg" arctan_degree=-70.00
22:00:09.991 ->
22:00:09.991 -> "angle" ang=291
22:00:09.991 -> "sin" sinus=-0.93
22:00:09.991 -> "cos" cosinus=0.36
22:00:09.991 -> "atan2-rad" arctan_radiant=-1.20
22:00:09.991 -> "atan2-deg" arctan_degree=-69.00
22:00:09.991 ->
22:00:09.991 -> "angle" ang=292
22:00:09.991 -> "cos" cosinus=0.37
22:00:09.991 -> "atan2-rad" arctan_radiant=-1.19
22:00:09.991 -> "atan2-deg" arctan_degree=-68.00
22:00:09.991 ->
22:00:09.991 -> "angle" ang=293
22:00:09.991 -> "sin" sinus=-0.92
22:00:09.991 -> "cos" cosinus=0.39
22:00:09.991 -> "atan2-rad" arctan_radiant=-1.17
22:00:09.991 -> "atan2-deg" arctan_degree=-67.00
22:00:09.991 ->
22:00:09.991 -> "angle" ang=294
22:00:09.991 -> "sin" sinus=-0.91
22:00:09.991 -> "cos" cosinus=0.41
22:00:09.991 -> "atan2-rad" arctan_radiant=-1.15
22:00:09.991 -> "atan2-deg" arctan_degree=-66.00
22:00:10.039 ->
22:00:10.039 -> "angle" ang=295
22:00:10.039 -> "sin" sinus=-0.91
22:00:10.039 -> "cos" cosinus=0.42
22:00:10.039 -> "atan2-rad" arctan_radiant=-1.13
22:00:10.039 -> "atan2-deg" arctan_degree=-65.00
22:00:10.039 ->
22:00:10.039 -> "angle" ang=296
22:00:10.039 -> "sin" sinus=-0.90
22:00:10.039 -> "cos" cosinus=0.44
22:00:10.039 -> "atan2-rad" arctan_radiant=-1.12
22:00:10.039 -> "atan2-deg" arctan_degree=-64.00
22:00:10.039 ->
22:00:10.039 -> "angle" ang=297
22:00:10.039 -> "sin" sinus=-0.89
22:00:10.039 -> "cos" cosinus=0.45
22:00:10.039 -> "atan2-rad" arctan_radiant=-1.10
22:00:10.039 -> "atan2-deg" arctan_degree=-63.00
22:00:10.039 ->
22:00:10.039 -> "angle" ang=298
22:00:10.039 -> "sin" sinus=-0.88
22:00:10.039 -> "cos" cosinus=0.47
22:00:10.039 -> "atan2-rad" arctan_radiant=-1.08
22:00:10.039 -> "atan2-deg" arctan_degree=-62.00
22:00:10.086 ->
22:00:10.086 -> "angle" ang=299
22:00:10.086 -> "sin" sinus=-0.87
22:00:10.086 -> "cos" cosinus=0.48
22:00:10.086 -> "atan2-rad" arctan_radiant=-1.06
22:00:10.086 -> "atan2-deg" arctan_degree=-61.00
22:00:10.086 ->
22:00:10.086 -> "angle" ang=300
22:00:10.086 -> "cos" cosinus=0.50
22:00:10.086 -> "atan2-rad" arctan_radiant=-1.05
22:00:10.086 -> "atan2-deg" arctan_degree=-60.00
22:00:10.086 ->
22:00:10.086 -> "angle" ang=301
22:00:10.086 -> "sin" sinus=-0.86
22:00:10.086 -> "cos" cosinus=0.52
22:00:10.086 -> "atan2-rad" arctan_radiant=-1.03
22:00:10.086 -> "atan2-deg" arctan_degree=-59.00
22:00:10.086 ->
22:00:10.086 -> "angle" ang=302
22:00:10.086 -> "sin" sinus=-0.85
22:00:10.086 -> "cos" cosinus=0.53
22:00:10.086 -> "atan2-rad" arctan_radiant=-1.01
22:00:10.086 -> "atan2-deg" arctan_degree=-58.00
22:00:10.086 ->
22:00:10.086 -> "angle" ang=303
22:00:10.134 -> "sin" sinus=-0.84
22:00:10.134 -> "cos" cosinus=0.54
22:00:10.134 -> "atan2-rad" arctan_radiant=-0.99
22:00:10.134 -> "atan2-deg" arctan_degree=-57.00
22:00:10.134 ->
22:00:10.134 -> "angle" ang=304
22:00:10.134 -> "sin" sinus=-0.83
22:00:10.134 -> "cos" cosinus=0.56
22:00:10.134 -> "atan2-rad" arctan_radiant=-0.98
22:00:10.134 -> "atan2-deg" arctan_degree=-56.00
22:00:10.134 ->
22:00:10.134 -> "angle" ang=305
22:00:10.134 -> "sin" sinus=-0.82
22:00:10.134 -> "cos" cosinus=0.57
22:00:10.134 -> "atan2-rad" arctan_radiant=-0.96
22:00:10.134 -> "atan2-deg" arctan_degree=-55.00
22:00:10.134 ->
22:00:10.134 -> "angle" ang=306
22:00:10.134 -> "sin" sinus=-0.81
22:00:10.134 -> "cos" cosinus=0.59
22:00:10.134 -> "atan2-rad" arctan_radiant=-0.94
22:00:10.134 -> "atan2-deg" arctan_degree=-54.00
22:00:10.134 ->
22:00:10.134 -> "angle" ang=307
22:00:10.181 -> "sin" sinus=-0.80
22:00:10.181 -> "cos" cosinus=0.60
22:00:10.181 -> "atan2-rad" arctan_radiant=-0.93
22:00:10.181 -> "atan2-deg" arctan_degree=-53.00
22:00:10.181 ->
22:00:10.181 -> "angle" ang=308
22:00:10.181 -> "sin" sinus=-0.79
22:00:10.181 -> "cos" cosinus=0.62
22:00:10.181 -> "atan2-rad" arctan_radiant=-0.91
22:00:10.181 -> "atan2-deg" arctan_degree=-52.00
22:00:10.181 ->
22:00:10.181 -> "angle" ang=309
22:00:10.181 -> "sin" sinus=-0.78
22:00:10.181 -> "cos" cosinus=0.63
22:00:10.181 -> "atan2-rad" arctan_radiant=-0.89
22:00:10.181 -> "atan2-deg" arctan_degree=-51.00
22:00:10.181 ->
22:00:10.181 -> "angle" ang=310
22:00:10.181 -> "sin" sinus=-0.77
22:00:10.181 -> "cos" cosinus=0.64
22:00:10.181 -> "atan2-rad" arctan_radiant=-0.87
22:00:10.181 -> "atan2-deg" arctan_degree=-50.00
22:00:10.181 ->
22:00:10.181 -> "angle" ang=311
22:00:10.227 -> "sin" sinus=-0.75
22:00:10.227 -> "cos" cosinus=0.66
22:00:10.227 -> "atan2-rad" arctan_radiant=-0.86
22:00:10.227 -> "atan2-deg" arctan_degree=-49.00
22:00:10.227 ->
22:00:10.227 -> "angle" ang=312
22:00:10.227 -> "sin" sinus=-0.74
22:00:10.227 -> "cos" cosinus=0.67
22:00:10.227 -> "atan2-rad" arctan_radiant=-0.84
22:00:10.227 -> "atan2-deg" arctan_degree=-48.00
22:00:10.227 ->
22:00:10.227 -> "angle" ang=313
22:00:10.227 -> "sin" sinus=-0.73
22:00:10.227 -> "cos" cosinus=0.68
22:00:10.227 -> "atan2-rad" arctan_radiant=-0.82
22:00:10.227 -> "atan2-deg" arctan_degree=-47.00
22:00:10.227 ->
22:00:10.227 -> "angle" ang=314
22:00:10.227 -> "sin" sinus=-0.72
22:00:10.227 -> "cos" cosinus=0.69
22:00:10.227 -> "atan2-rad" arctan_radiant=-0.80
22:00:10.227 -> "atan2-deg" arctan_degree=-46.00
22:00:10.227 ->
22:00:10.227 -> "angle" ang=315
22:00:10.227 -> "sin" sinus=-0.71
22:00:10.275 -> "cos" cosinus=0.71
22:00:10.275 -> "atan2-rad" arctan_radiant=-0.79
22:00:10.275 -> "atan2-deg" arctan_degree=-45.00
22:00:10.275 ->
22:00:10.275 -> "angle" ang=316
22:00:10.275 -> "sin" sinus=-0.69
22:00:10.275 -> "cos" cosinus=0.72
22:00:10.275 -> "atan2-rad" arctan_radiant=-0.77
22:00:10.275 -> "atan2-deg" arctan_degree=-44.00
22:00:10.275 ->
22:00:10.275 -> "angle" ang=317
22:00:10.275 -> "sin" sinus=-0.68
22:00:10.275 -> "cos" cosinus=0.73
22:00:10.275 -> "atan2-rad" arctan_radiant=-0.75
22:00:10.275 -> "atan2-deg" arctan_degree=-43.00
22:00:10.275 ->
22:00:10.275 -> "angle" ang=318
22:00:10.275 -> "sin" sinus=-0.67
22:00:10.275 -> "cos" cosinus=0.74
22:00:10.275 -> "atan2-rad" arctan_radiant=-0.73
22:00:10.275 -> "atan2-deg" arctan_degree=-42.00
22:00:10.275 ->
22:00:10.275 -> "angle" ang=319
22:00:10.275 -> "sin" sinus=-0.66
22:00:10.322 -> "cos" cosinus=0.75
22:00:10.322 -> "atan2-rad" arctan_radiant=-0.72
22:00:10.322 -> "atan2-deg" arctan_degree=-41.00
22:00:10.322 ->
22:00:10.322 -> "angle" ang=320
22:00:10.322 -> "sin" sinus=-0.64
22:00:10.322 -> "cos" cosinus=0.77
22:00:10.322 -> "atan2-rad" arctan_radiant=-0.70
22:00:10.322 -> "atan2-deg" arctan_degree=-40.00
22:00:10.322 ->
22:00:10.322 -> "angle" ang=321
22:00:10.322 -> "sin" sinus=-0.63
22:00:10.322 -> "cos" cosinus=0.78
22:00:10.322 -> "atan2-rad" arctan_radiant=-0.68
22:00:10.322 -> "atan2-deg" arctan_degree=-39.00
22:00:10.322 ->
22:00:10.322 -> "angle" ang=322
22:00:10.322 -> "sin" sinus=-0.62
22:00:10.322 -> "cos" cosinus=0.79
22:00:10.322 -> "atan2-rad" arctan_radiant=-0.66
22:00:10.322 -> "atan2-deg" arctan_degree=-38.00
22:00:10.322 ->
22:00:10.322 -> "angle" ang=323
22:00:10.322 -> "sin" sinus=-0.60
22:00:10.322 -> "cos" cosinus=0.80
22:00:10.370 -> "atan2-rad" arctan_radiant=-0.65
22:00:10.370 -> "atan2-deg" arctan_degree=-37.00
22:00:10.370 ->
22:00:10.370 -> "angle" ang=324
22:00:10.370 -> "sin" sinus=-0.59
22:00:10.370 -> "cos" cosinus=0.81
22:00:10.370 -> "atan2-rad" arctan_radiant=-0.63
22:00:10.370 -> "atan2-deg" arctan_degree=-36.00
22:00:10.370 ->
22:00:10.370 -> "angle" ang=325
22:00:10.370 -> "sin" sinus=-0.57
22:00:10.370 -> "cos" cosinus=0.82
22:00:10.370 -> "atan2-rad" arctan_radiant=-0.61
22:00:10.370 -> "atan2-deg" arctan_degree=-35.00
22:00:10.370 ->
22:00:10.370 -> "angle" ang=326
22:00:10.370 -> "sin" sinus=-0.56
22:00:10.370 -> "cos" cosinus=0.83
22:00:10.370 -> "atan2-rad" arctan_radiant=-0.59
22:00:10.370 -> "atan2-deg" arctan_degree=-34.00
22:00:10.370 ->
22:00:10.370 -> "angle" ang=327
22:00:10.370 -> "sin" sinus=-0.54
22:00:10.370 -> "cos" cosinus=0.84
22:00:10.370 -> "atan2-rad" arctan_radiant=-0.58
22:00:10.370 -> "atan2-deg" arctan_degree=-33.00
22:00:10.370 ->
22:00:10.370 -> "angle" ang=328
22:00:10.370 -> "sin" sinus=-0.53
22:00:10.370 -> "cos" cosinus=0.85
22:00:10.370 -> "atan2-rad" arctan_radiant=-0.56
22:00:10.370 -> "atan2-deg" arctan_degree=-32.00
22:00:10.370 ->
22:00:10.370 -> "angle" ang=329
22:00:10.370 -> "sin" sinus=-0.52
22:00:10.370 -> "cos" cosinus=0.86
22:00:10.370 -> "atan2-rad" arctan_radiant=-0.54
22:00:10.370 -> "atan2-deg" arctan_degree=-31.00
22:00:10.370 ->
22:00:10.370 -> "angle" ang=330
22:00:10.370 -> "sin" sinus=-0.50
22:00:10.370 -> "cos" cosinus=0.87
22:00:10.370 -> "atan2-rad" arctan_radiant=-0.52
22:00:10.370 -> "atan2-deg" arctan_degree=-30.00
22:00:10.370 ->
22:00:10.370 -> "angle" ang=331
22:00:10.370 -> "sin" sinus=-0.48
22:00:10.370 -> "atan2-rad" arctan_radiant=-0.51
22:00:10.417 -> "atan2-deg" arctan_degree=-29.00
22:00:10.417 ->
22:00:10.417 -> "angle" ang=332
22:00:10.417 -> "sin" sinus=-0.47
22:00:10.417 -> "cos" cosinus=0.88
22:00:10.417 -> "atan2-rad" arctan_radiant=-0.49
22:00:10.417 -> "atan2-deg" arctan_degree=-28.00
22:00:10.417 ->
22:00:10.417 -> "angle" ang=333
22:00:10.417 -> "sin" sinus=-0.45
22:00:10.417 -> "cos" cosinus=0.89
22:00:10.417 -> "atan2-rad" arctan_radiant=-0.47
22:00:10.417 -> "atan2-deg" arctan_degree=-27.00
22:00:10.417 ->
22:00:10.417 -> "angle" ang=334
22:00:10.417 -> "sin" sinus=-0.44
22:00:10.417 -> "cos" cosinus=0.90
22:00:10.417 -> "atan2-rad" arctan_radiant=-0.45
22:00:10.417 -> "atan2-deg" arctan_degree=-26.00
22:00:10.417 ->
22:00:10.417 -> "angle" ang=335
22:00:10.417 -> "sin" sinus=-0.42
22:00:10.417 -> "cos" cosinus=0.91
22:00:10.417 -> "atan2-rad" arctan_radiant=-0.44
22:00:10.464 -> "atan2-deg" arctan_degree=-25.00
22:00:10.464 ->
22:00:10.464 -> "angle" ang=336
22:00:10.464 -> "sin" sinus=-0.41
22:00:10.464 -> "cos" cosinus=0.91
22:00:10.464 -> "atan2-rad" arctan_radiant=-0.42
22:00:10.464 -> "atan2-deg" arctan_degree=-24.00
22:00:10.464 ->
22:00:10.464 -> "angle" ang=337
22:00:10.464 -> "sin" sinus=-0.39
22:00:10.464 -> "cos" cosinus=0.92
22:00:10.464 -> "atan2-rad" arctan_radiant=-0.40
22:00:10.464 -> "atan2-deg" arctan_degree=-23.00
22:00:10.464 ->
22:00:10.464 -> "angle" ang=338
22:00:10.464 -> "sin" sinus=-0.37
22:00:10.464 -> "cos" cosinus=0.93
22:00:10.464 -> "atan2-rad" arctan_radiant=-0.38
22:00:10.464 -> "atan2-deg" arctan_degree=-22.00
22:00:10.464 ->
22:00:10.464 -> "angle" ang=339
22:00:10.464 -> "sin" sinus=-0.36
22:00:10.464 -> "atan2-rad" arctan_radiant=-0.37
22:00:10.511 -> "atan2-deg" arctan_degree=-21.00
22:00:10.511 ->
22:00:10.511 -> "angle" ang=340
22:00:10.511 -> "sin" sinus=-0.34
22:00:10.511 -> "cos" cosinus=0.94
22:00:10.511 -> "atan2-rad" arctan_radiant=-0.35
22:00:10.511 -> "atan2-deg" arctan_degree=-20.00
22:00:10.511 ->
22:00:10.511 -> "angle" ang=341
22:00:10.511 -> "sin" sinus=-0.33
22:00:10.511 -> "cos" cosinus=0.95
22:00:10.511 -> "atan2-rad" arctan_radiant=-0.33
22:00:10.511 -> "atan2-deg" arctan_degree=-19.00
22:00:10.511 ->
22:00:10.511 -> "angle" ang=342
22:00:10.511 -> "sin" sinus=-0.31
22:00:10.511 -> "atan2-rad" arctan_radiant=-0.31
22:00:10.511 -> "atan2-deg" arctan_degree=-18.00
22:00:10.511 ->
22:00:10.511 -> "angle" ang=343
22:00:10.511 -> "sin" sinus=-0.29
22:00:10.511 -> "cos" cosinus=0.96
22:00:10.511 -> "atan2-rad" arctan_radiant=-0.30
22:00:10.559 -> "atan2-deg" arctan_degree=-17.00
22:00:10.559 ->
22:00:10.559 -> "angle" ang=344
22:00:10.559 -> "sin" sinus=-0.28
22:00:10.559 -> "cos" cosinus=0.96
22:00:10.559 -> "atan2-rad" arctan_radiant=-0.28
22:00:10.559 -> "atan2-deg" arctan_degree=-16.00
22:00:10.559 ->
22:00:10.559 -> "angle" ang=345
22:00:10.559 -> "sin" sinus=-0.26
22:00:10.559 -> "cos" cosinus=0.97
22:00:10.559 -> "atan2-rad" arctan_radiant=-0.26
22:00:10.559 -> "atan2-deg" arctan_degree=-15.00
22:00:10.559 ->
22:00:10.559 -> "angle" ang=346
22:00:10.559 -> "sin" sinus=-0.24
22:00:10.559 -> "atan2-rad" arctan_radiant=-0.24
22:00:10.559 -> "atan2-deg" arctan_degree=-14.00
22:00:10.559 ->
22:00:10.559 -> "angle" ang=347
22:00:10.559 -> "sin" sinus=-0.22
22:00:10.559 -> "atan2-rad" arctan_radiant=-0.23
22:00:10.606 -> "atan2-deg" arctan_degree=-13.00
22:00:10.606 ->
22:00:10.606 -> "angle" ang=348
22:00:10.606 -> "sin" sinus=-0.21
22:00:10.606 -> "cos" cosinus=0.98
22:00:10.606 -> "atan2-rad" arctan_radiant=-0.21
22:00:10.606 -> "atan2-deg" arctan_degree=-12.00
22:00:10.606 ->
22:00:10.606 -> "angle" ang=349
22:00:10.606 -> "sin" sinus=-0.19
22:00:10.606 -> "atan2-rad" arctan_radiant=-0.19
22:00:10.606 -> "atan2-deg" arctan_degree=-11.00
22:00:10.606 ->
22:00:10.606 -> "angle" ang=350
22:00:10.606 -> "sin" sinus=-0.17
22:00:10.606 -> "atan2-rad" arctan_radiant=-0.17
22:00:10.606 -> "atan2-deg" arctan_degree=-10.00
22:00:10.606 ->
22:00:10.606 -> "angle" ang=351
22:00:10.606 -> "sin" sinus=-0.16
22:00:10.606 -> "cos" cosinus=0.99
22:00:10.606 -> "atan2-rad" arctan_radiant=-0.16
22:00:10.606 -> "atan2-deg" arctan_degree=-9.00
22:00:10.654 ->
22:00:10.654 -> "angle" ang=352
22:00:10.654 -> "sin" sinus=-0.14
22:00:10.654 -> "cos" cosinus=0.99
22:00:10.654 -> "atan2-rad" arctan_radiant=-0.14
22:00:10.654 -> "atan2-deg" arctan_degree=-8.00
22:00:10.654 ->
22:00:10.654 -> "angle" ang=353
22:00:10.654 -> "sin" sinus=-0.12
22:00:10.654 -> "atan2-rad" arctan_radiant=-0.12
22:00:10.654 -> "atan2-deg" arctan_degree=-7.00
22:00:10.654 ->
22:00:10.654 -> "angle" ang=354
22:00:10.654 -> "sin" sinus=-0.10
22:00:10.654 -> "atan2-rad" arctan_radiant=-0.10
22:00:10.654 -> "atan2-deg" arctan_degree=-6.00
22:00:10.654 ->
22:00:10.654 -> "angle" ang=355
22:00:10.654 -> "sin" sinus=-0.09
22:00:10.654 -> "cos" cosinus=1.00
22:00:10.654 -> "atan2-rad" arctan_radiant=-0.09
22:00:10.654 -> "atan2-deg" arctan_degree=-5.00
22:00:10.701 ->
22:00:10.701 -> "angle" ang=356
22:00:10.701 -> "sin" sinus=-0.07
22:00:10.701 -> "cos" cosinus=1.00
22:00:10.701 -> "atan2-rad" arctan_radiant=-0.07
22:00:10.701 -> "atan2-deg" arctan_degree=-4.00
22:00:10.701 ->
22:00:10.701 -> "angle" ang=357
22:00:10.701 -> "sin" sinus=-0.05
22:00:10.701 -> "atan2-rad" arctan_radiant=-0.05
22:00:10.701 -> "atan2-deg" arctan_degree=-3.00
22:00:10.701 ->
22:00:10.701 -> "angle" ang=358
22:00:10.701 -> "sin" sinus=-0.03
22:00:10.701 -> "atan2-rad" arctan_radiant=-0.03
22:00:10.701 -> "atan2-deg" arctan_degree=-2.00
22:00:10.701 ->
22:00:10.701 -> "angle" ang=359
22:00:10.701 -> "sin" sinus=-0.02
22:00:10.701 -> "atan2-rad" arctan_radiant=-0.02
22:00:10.701 -> "atan2-deg" arctan_degree=-1.00
22:00:10.701 ->
Thank you StefanL38. Wouldn't it be nice if they added things like this into the Arduino Language Reference?
Jim Rowe
Hi alto777, Yes, I agree -- wouldn't it be good if the documentation was more complete?
Jim Rowe
As it turns out, atan() and atan2() are part of the standard C / C++ math libraries. So, extensive information about them is only a Google search away. As you're finding out, the Arduino Reference is not that great (IMO). I typically only find it (somewhat) useful for information on Arduino-specific functions.
The problem is that documenting all of the standard C libraries that Arduino supports would:
  1. Result in a massive document that would be as confusing to some users as it would be useful to others.
  2. Duplicate documentation that already exists, when it's not really necessary.
(it WOULD be nice if the Arduino Docs were better at pointing users to the additional documentation. For example, avr-libc is described here. The 75-odd math functions are documented here.
If you get a chance atan2() is often preferable to atan() because it can handle all possible quadrants and avoids the ambiguity of the sign, providing a complete two-dimensional angle solution.
It needs an x and y though
That’s not really a shock. Arduino does not offer a programming language but really an IDE and an API. So it feels natural they document their stuff and leave the language to the language documentation.
It seems they did document a few concepts like scope which is probably due to common cause of issues with newbies but they should not embark in a full C++ explanation. (Would be great if they mentioned somewhere that sprintf does not support %f on 8 bits arduinos).
Cool. And all the the other modules are here:
https://www.nongnu.org/avr-libc/user-manual/modules.html
I didn't know there was a time_t in AVR:
#include <time.h>  // https://www.nongnu.org/avr-libc/user-manual/modules.html
time_t now = 0;
  now = millis();
  report();
void report(void) {
  time_t interval = 500;
  static time_t last = 0;
  if (now - last >= interval) {
    last = now;
// or
//    while ( now - last >= interval ) {
//      last += interval; // catch up
    Serial.println(now);
Typing #include <time.h> is better then typing unsigned long twice.
Or even once.
time_t is part of the standard C++ library, it's defined as an Arithmetic type capable of representing times. the underlying type is not defined by the standard.
as the doc states
Although not defined, this is almost always an integral value holding the number of seconds (not counting leap seconds) since 00:00, Jan 1 1970 UTC, corresponding to POSIX time.
So It's more meant to deal with usual time functions rather than the value of millis() or micros()
