const int rightmotorPin = 11;
const int leftmotorPin = 10;
const int centerirPin = 12;
const int rightirPin = 3;
const int leftirPin = 4;
const int trigPin = 2; //digital pin here
const int echoPin = A5; //analog pin here
int distance;
int time;
int distrange = 30;
int centerVal;
int rightVal;
int leftVal;
int PWMspeed = 90;
pinMode(rightmotorPin, OUTPUT);
pinMode(leftmotorPin, OUTPUT);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(centerirPin, INPUT);
pinMode(leftirPin, INPUT);
pinMode(rightirPin, INPUT);
int centerVal = digitalRead(centerirPin);
int rightVal = digitalRead(rightirPin);
int leftVal = digitalRead(leftirPin);
if((rightVal == 0) && (leftVal == 0)) { //IDEAL CASE
digitalWrite(rightmotorPin, PWMspeed);
digitalWrite(leftmotorPin, PWMspeed);
if((rightVal == 1) && (leftVal == 0)) { //TURN RIGHT
digitalWrite(rightmotorPin, LOW);
if((rightVal == 0) && (leftVal == 1)) { //TURN LEFT
digitalWrite(leftmotorPin, LOW);
if((rightVal == 1) && (leftVal == 1)) { //STOP
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
int time = pulseIn(echoPin, HIGH); //measure how much time echoPin was HIGH
int distance = time * 0.0343 / 2; //343 speed of soundin air time in microseconds hence 0.0343
if(distance < distrange) { //OBSTACLE AHEAD STOP
Serial.println(distance);
My button is wired currently so that on bottom right pin i have resistor and ground connection and top left pin i have the digital pin connection
i have tried this connection as well and still the same problem occurs
is it a problem with the resistor? what is preffered ohm resistance i should use?
I do not see a button referenced in your code. Would you show that, and also a drawing of how your button is attached to your Arduino? Last post said your pushbutton is resetting the USB port.
A good way to wire a button is from the Arduino pin, to the pushbutton, then from the pushbutton on a Normally Open contact to ground.
Then you define a button pin in your code:
int buttonPin = 3; // for example
Then you set the function of the button pin:
pinMode(buttonPin, INPUT_PULLUP); // buttonPin is normally HIGH with internal PULLUP resistor
Then, poll the button pin:
if (!digitalRead(buttonPin)); // buttonPin is LOW when pressed
You should see the button pin go from HIGH (not pressed) to LOW (pressed).
300ohm (220R...330R..) seems good for a button. You have a pulldown resistor, so your code is waiting for a HIGH.
I think i was using a 220 ohm resistor and shouldnt my button value always be HIGH as i set it as input_pullup and it should wait for a LOW?
Yes.... I read your post wrong. Sorry.
No problem ![]()
Also now what I want to do is once the button is pushed once the robot should run for 10 seconds and then stop for a certain amount of time (lets just say 5 seconds) and then run again for 10 seconds
similiar to how a train stops at different train stations is it possible to do that?
Using the timer your set up in Post #2, where you were counting 10 seconds, reset your timer and use a conditional "if()" to test for 5 seconds, and again for 10 seconds. Your "millis()" timeline can be imagined like this... all values are examples:
MILLIS
0000 - this is when you turned your Arduino on
0001 - 1 millisecond later
15377 - 15377 milliseconds later (15.377 seconds)
15378 - buttonPressed = millis() - this is when button was pressed and robot moves
25378 - millis() minus buttonPressed = 10000 which is your buttonInterval and stop robot moving
30378 - 5 seconds more (5000 millis()) - start the robot again (you can either start at buttonPressed and add 15000 or buttonInterval and add 5000). Maybe call it "stopDuration"
forever
You can see that you need to find the difference between "now" (millis(), a "zero" time) and when you started an event (buttonPressed for example) and compare that to any of your pre-defined intervals.
Understood, I shall write the code using this logic can i send it to you to make sure it is right
Yes, post your work here.
Note this is the code for the first part where i press the button once and the robot runs for 10 seconds i am still working on the second one where it runs, stops and runs again
Also i added more line following functions and changed the structure of the code to better incoorporate the distance sensor if condition
const int rightmotorPin = 10;
const int leftmotorPin = 11;
const int rightirPin = 5;
const int leftirPin = 6;
const int buttonPin = 3;
int distance;
int time;
int centerVal;
int rightVal;
int leftVal;
int buttonState;
const byte PWMspeed = 50;
unsigned long trackTime = 10 * 1000 //10 seconds
unsigned long buttonPressed = 0;
pinMode(buttonPin, INPUT_PULLUP); //ALWAYS HIGH
int distance = time * 0.0343 / 2; //343 speed of sound in air time in microseconds hence 0.0343
int centerVal = digitalRead(centerirPin); //1 white 0 black
int rightVal = digitalRead(rightirPin); //0 IS WHITE AND 1 IS BLACK
int leftVal = digitalRead(leftirPin); //0 IS WHITE AND 1 IS BLACK
if(buttonState == 0) {
buttonPressed = millis(); //NOTES DOWN THE TIMEEEEEEEEEEE WHEN THE BUTTON WAS PRESSED AND STORES IT IN THE BUTTONPRESSED VARIABLE
delay(150); //debounce button press
if(millis() - buttonPressed < trackTime) { //IF THE TIME RIGHT NOW - TIME WHEN BUTTON WAS PRESSED IS LESS THAN 10 SECONDS THEN FOLLOW LINE
if(distance < 20) { //OBSTACLE AHEAD STOP
digitalWrite(rightmotorPin, 0);
digitalWrite(leftmotorPin, 0);
if((leftVal == 0) && (centerVal == 0) && (rightVal == 0)) { //IDEAL CASE
else if((leftVal == 0) && (centerVal == 1) && (rightVal == 1)) { //RIGHT SENSOR ON LINE
else if((leftVal == 1) && (centerVal == 1) && (rightVal == 0)) { //LEFT SENSOR ON LINE
else if((leftVal == 1) && (centerVal == 0) && (rightVal == 1)) { //STOP ALL BLACK DETECTED
else if((leftVal == 0) && (centerVal == 1) && (rightVal == 0)) { // ALL WHITE
else if((leftVal == 1) && (centerVal == 0) && (rightVal == 0)) { //LEFT AND CENTER SENSOR SENSOR ON LINE
else if((leftVal == 0) && (centerVal == 0) && (rightVal == 1)) { //RIGHT AND CENTER SENSOR ON LINE
else if((leftVal == 1) && (centerVal == 1) && (rightVal == 1)) { //RIGHT AND LEFT SENSOR BLACK CENTER SENSOR WHITE
else { //IF NONE OF OTHER CONDITIONS
This line needs a semi-colon after the 1000: (I put one in)
unsigned long trackTime = 10 * 1000; //10 seconds
Is your button is read as "pressed" all the time?
Here is your project in a simulation... you can see the sim keeps "rolling" at any SR04 distance. The "IR" devices are simple switches in the simulation. I put notes in the comments at the top that might help identify what needs to be addressed.
https://wokwi.com/projects/370699668648464385
Leaving files here for wokwi...
sketch.ino
// https://forum.arduino.cc/t/how-do-i-get-line-following-robot-to-run-for-10-seconds-when-button-is-pushed/1146946/
// https://wokwi.com/projects/370699668648464385
// 1. Motors stop at distance < 20 if motor is on or within 10 seconds of button press
// 2. If button is pressed with distancd < 20 motors will not run, timer will count to 10
// 3. If distance > 20 and button is pressed, line follower motors run
// 4. After button is pressed, motors stop after 10 seconds
// 5. After button is pressed and Left/Center/Right IR is ON, corresponding motor stops
#define DEBUG 1 // 0 = packed debug string, 1 = long debug string
// pins
// ultrasonic sensor (sonar)
int distance;
int time;
// IR line follower
int centerVal;
int rightVal;
int leftVal;
// button detection
int buttonState = 0; // set after button is pressed to make motors run. reset to 0 after trackTime
unsigned long buttonPressed = 0; // holds time button was pressed
int startMotorButton;
// timer
unsigned long trackTime = 10 * 1000; //10 seconds << this line needed a semicolon ;
unsigned long previousMillis = 0; // campare with millis() for event interval
Serial.begin(115200); // 115200 is much faster than 9600
pingSONAR(); // HCSR04 distance finder
lineSense(); // IR line sensors
checkButton(); // for motor start
if (buttonState) { // only run the motors after a button press
lineFollow();
if (DEBUG)
debugLong (buttonState, distance, leftVal, centerVal, rightVal, buttonPressed);
debugShort (buttonState, distance, leftVal, centerVal, rightVal, buttonPressed);
// User Defined Functions
void checkButton() {
startMotorButton = digitalRead(buttonPin); // need to read the button pin...
if (startMotorButton == 0) { // 0 (button pressed), 1 (not pressed)
buttonPressed = millis(); //NOTES DOWN THE TIMEEEEEEEEEEE WHEN THE BUTTON WAS PRESSED AND STORES IT IN THE buttonPressed VARIABLE
buttonState = 1; // button was pressed... need to clear buttonState after 10 seconds
void lineSense() {
centerVal = digitalRead(centerirPin); // 1 white 0 black
rightVal = digitalRead(rightirPin); // 0 IS WHITE AND 1 IS BLACK
leftVal = digitalRead(leftirPin); // 0 IS WHITE AND 1 IS BLACK
void pingSONAR() {
digitalWrite(trigPin, LOW); // force trigger low for clean high
digitalWrite(trigPin, LOW); // force trigger low for clean echo
void lineFollow() {
if (millis() - buttonPressed < trackTime) { //IF THE TIME RIGHT NOW MINUS TIME WHEN BUTTON WAS PRESSED IS LESS THAN 10 SECONDS THEN FOLLOW LINE
if (distance < 20) { //OBSTACLE AHEAD STOP
} else { // DISTANCE > 20, NO OBSTACLE, CONTINUE LINE FOLLOWING
if ((leftVal == 0) && (centerVal == 0) && (rightVal == 0)) { //IDEAL CASE
else if ((leftVal == 0) && (centerVal == 1) && (rightVal == 1)) { //RIGHT SENSOR ON LINE
else if ((leftVal == 1) && (centerVal == 1) && (rightVal == 0)) { //LEFT SENSOR ON LINE
else if ((leftVal == 1) && (centerVal == 0) && (rightVal == 1)) { //STOP ALL BLACK DETECTED
else if ((leftVal == 0) && (centerVal == 1) && (rightVal == 0)) { // ALL WHITE
else if ((leftVal == 1) && (centerVal == 0) && (rightVal == 0)) { //LEFT AND CENTER SENSOR SENSOR ON LINE
else if ((leftVal == 0) && (centerVal == 0) && (rightVal == 1)) { //RIGHT AND CENTER SENSOR ON LINE
else if ((leftVal == 1) && (centerVal == 1) && (rightVal == 1)) { //RIGHT AND LEFT SENSOR BLACK CENTER SENSOR WHITE
else { // after 10 seconds
// clear buttonState to stop motors
buttonState = 0;
// stop motors
void debugShort(int buttonState, int distance, int leftVal, int centerVal, int rightVal, unsigned long buttonPressed) {
if (millis() - previousMillis > 1000 ) { // one second printout interval
previousMillis = millis(); // set timer to current millis for next event
Serial.print("Time:");
if (((millis() - buttonPressed) / 1000) < 100) Serial.print("0"); // zero pad for Serial presentation
if (((millis() - buttonPressed) / 1000) < 10) Serial.print("0"); // zero pad for Serial presentation
Serial.print((millis() - buttonPressed) / 1000);
if (distance < 20) Serial.print("(distance:"); // lower case indicating LESS THAN
else Serial.print("(DISTANCE:"); // upper case indicating GREATER THAN
if (distance < 100) Serial.print("0"); // zero pad for Serial presentation
if (distance < 10) Serial.print("0"); // zero pad for Serial presentation
Serial.print(distance);
Serial.print(" BLCRLR:");
Serial.print(buttonState);
Serial.print(leftVal);
Serial.print(centerVal);
Serial.print(rightVal);
Serial.print(digitalRead(leftmotorPin));
Serial.print(digitalRead(rightmotorPin));
void debugLong(int buttonState, int distance, int leftVal, int centerVal, int rightVal, unsigned long buttonPressed) {
Serial.print(" (Motor:");
if (digitalRead(leftmotorPin)) Serial.print("LEFT.");
else Serial.print("left.");
if (digitalRead(rightmotorPin)) Serial.print(" RIGHT.");
else Serial.print(" right.");
if (!buttonState) Serial.print(" time."); // lower case means motor not on
else Serial.print(" TIME."); // upper case means motor is on
if (!buttonState)
Serial.print("000) ");
else {
Serial.print(") ");
Serial.print(")");
if (!buttonState) Serial.print(" (buttonState:");
else Serial.print(" (BUTTONSTATE:");
Serial.print(") (IR:");
if (leftVal) Serial.print("LEFT.");
if (centerVal) Serial.print(" CENTER.");
else Serial.print(" center.");
if (rightVal) Serial.print(" RIGHT.");
Serial.print(")");
diagram.json
"version": 1,
"author": "Anonymous maker",
"editor": "wokwi",
"parts": [
{ "type": "wokwi-arduino-nano", "id": "nano", "top": 0, "left": 0, "attrs": {} },
"type": "wokwi-led",
"id": "led1",
"top": -205.46,
"left": 163,
"attrs": { "color": "red", "label": "RIGHT MOTOR" }
"id": "led2",
"top": -198.53,
"left": -56.07,
"attrs": { "color": "red", "label": "LEFT MOTOR" }
"type": "wokwi-text",
"id": "text1",
"top": -181.92,
"left": -131.96,
"attrs": { "text": "LEFT IR" }
{ "type": "wokwi-vcc", "id": "vcc1", "top": -320.97, "left": -162.13, "attrs": {} },
{ "type": "wokwi-gnd", "id": "gnd1", "top": -20.41, "left": -154.72, "attrs": {} },
"id": "text2",
"top": -184.31,
"left": 8.3,
"attrs": { "text": "CENTER IR" }
"id": "text3",
"top": -186.05,
"left": 215.23,
"attrs": { "text": "RIGHT IR" }
"type": "wokwi-resistor",
"id": "r1",
"top": -106.73,
"left": -87.42,
"rotate": 90,
"attrs": { "value": "1000" }
"id": "r2",
"top": -106.87,
"left": 133.86,
"rotate": 90,
"type": "wokwi-hc-sr04",
"id": "ultrasonic1",
"top": -319.7,
"left": -19.3,
"attrs": { "distance": "63" }
"type": "wokwi-pushbutton",
"id": "btn1",
"top": -287.93,
"left": 182.8,
"attrs": { "color": "green", "label": "START LINE FOLLOW" }
{ "type": "wokwi-slide-switch", "id": "sw1", "top": -161.6, "left": -116.9, "attrs": {} },
{ "type": "wokwi-slide-switch", "id": "sw2", "top": -162.67, "left": 36.03, "attrs": {} },
{ "type": "wokwi-slide-switch", "id": "sw3", "top": -167.07, "left": 236.96, "attrs": {} }
"connections": [
[ "nano:10", "led1:A", "green", [ "v-15.57", "h169.43", "v-152.69" ] ],
[ "led2:A", "nano:11", "green", [ "h17.4", "v148.43", "h72.3" ] ],
[ "led2:C", "r1:1", "green", [ "h-16.3", "v26.06" ] ],
[ "gnd1:GND", "r1:2", "black", [ "v-10.86", "h99.68" ] ],
[ "led1:C", "r2:1", "green", [ "h-15.24", "v32.59" ] ],
[ "gnd1:GND", "r2:2", "black", [ "v-10.67", "h320.14" ] ],
[ "vcc1:VCC", "ultrasonic1:VCC", "red", [ "v78.33", "h201.03" ] ],
[ "nano:2", "ultrasonic1:TRIG", "green", [ "v-208.73", "h-53.7" ] ],
"ultrasonic1:ECHO",
"nano:A5",
"green",
[ "v15.27", "h62.5", "v190", "h48.67", "v94.67", "h-76" ]
[ "gnd1:GND", "ultrasonic1:GND", "black", [ "v-10.86", "h289.02", "v-186", "h-62.67" ] ],
[ "nano:3", "btn1:1.l", "green", [ "v-190.73", "h56.4", "v-93.33" ] ],
[ "nano:GND.2", "btn1:2.l", "black", [ "v-203.4", "h47.2", "v-56" ] ],
[ "nano:6", "sw1:2", "green", [ "v-79.2", "h-177.8" ] ],
[ "nano:5", "sw3:2", "green", [ "v-77.2", "h166.6" ] ],
[ "nano:12", "sw2:2", "green", [ "v-86.53", "h33.8" ] ],
[ "gnd1:GND", "sw1:1", "black", [ "v-97.99", "h32.68" ] ],
[ "gnd1:GND", "sw2:1", "black", [ "v-10.65", "h182.68" ] ],
[ "gnd1:GND", "sw3:1", "black", [ "v-10.85", "h387.98" ] ],
[ "vcc1:VCC", "sw1:3", "red", [ "v242.53", "h61.13" ] ],
[ "sw1:3", "sw2:3", "red", [ "v78.54", "h152.93" ] ],
[ "sw2:3", "sw3:3", "red", [ "v76.94", "h200.93" ] ]
"dependencies": {}
Hey, credit to you for what you've done so far!
This doesn't change the code but might make it easier to read whic can save debug time;
if (distance < 20) //OBSTACLE AHEAD STOP
if ((leftVal == 0) && (centerVal == 0) && (rightVal == 0)) //IDEAL CASE
else if ((leftVal == 0) && (centerVal == 1) && (rightVal == 1)) //RIGHT SENSOR ON LINE
else if ((leftVal == 1) && (centerVal == 1) && (rightVal == 0)) //LEFT SENSOR ON LINE
Lining up braces vertically makes it way easier/faster to check and to see structures out of sa hill of text. It's more to do with how much attention you spend just finding braces in brick-code. I dunno about you but I have a limited supply of that and when it runs out (feel tired) then stubbornly continuing to work is how to write bugs.
Get the line follower to work first. I see nothing that will block the time part.
I would like to get you to add a button handler without trying to integrate that into the line-follower code. The follower will be fine with stop and go on a flag variable == 0 or 1 from code in void loop() that is not the follower but runs along with it.
It should be a big step towards how to write smaller, less complicated sketches.
Wow this simulator helps a ton with testing but for me the right and left led are turned off whenever the distance value goes below 20 yes and my button value is always high
However, when I press start in sim the code is autoatically running regardless of the button press I shall modify the code and upload it here on this forum reply please check if it is right.
The line follower works and thank you for the advice about the curly braces alignment I am adapted to using the before format with the braces aligned in a different way.
Adding an indent level every time.... put the braces where they work for you but you can ladder if-else logic straight down the page. I use white space to make structure easier to see. My eyes are old but I started doing these things when I wrote 1000's of lines of code (with libraries added, 20,000 to 35,000 where I wrote maybe 8000). Cutting out time to hunt through structures led me to write as open to view as possible.
I will drag out a button handler that runs in loop() with non-blocking code so you don't have to tackle button bouncing this week. The stop/go part will show how to use it.
Right now I'm winding down, messing with code like this is asking for bugs.
I put some notes in the top of the simulation... observations that might help... including the points you mentioned in post #35.
If you do not want the motors to run as soon as the simulation starts, putting the entire code inside the "if button" condition is your first step.
There may be some initializing when starting after a stop. Does the line follower save previous conditions/states or is it always "in the moment"?
Line follower as a function would make loop() easier to read.
I think it doesnt save the previous condition.
