How do I get my Arduino master to send motor steps data to my slave for it to move
Good day. I'm new to Arduino but I'm working on a project where I need to get my Arduino master to send step data to my slave for it to move in said direction, but even though the data sort of comes through serially, I can't get my motor to move. I have 2 pieces of code but I don't know where I'm going wrong or might have gone wrong. I was hoping to share an image too but it's not coming through. please forgive any mistakes.
// Wire Master Writer
#include <Wire.h>
  Wire.begin(); // join i2c bus (address optional for master)
byte x = 0;
char c;
  while(Serial.available()>0){
  c=Serial.read();
  Wire.beginTransmission(8); // transmit to device #8
  Wire.write(c);
  Wire.endTransmission();    // stop transmitting
  x;
// Wire Slave Receiver
#include <Wire.h>
#include <Stepper.h>
int stepsPerRevolution=360;
int motSpeed=10;
int StepsPerMillimeterX = 5.0;
int Loc_int;
Stepper stepper_X_axis (stepsPerRevolution,8,9,10,11);
  Wire.begin(8);                // join i2c bus with address #8
  Wire.onReceive(receiveEvent); // register event
  Serial.begin(9600);           // start serial for output
  stepper_X_axis.setSpeed(motSpeed);
  stepper_X_axis.step(stepsPerRevolution);
  delay(100);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany) {
   while (Wire.available()){
    char x = Wire.read();    // receive byte as an integer
    Serial.println(x);         // print the integer
    int Loc_Int =x ;
    Serial.println(Loc_Int);
    //stepper_X_axis.step(stepsPerRevolution);
  //delay(500);
A simulated or a real motor? Have you tried a simple sketch on SIM2 that only tests the motor?
thanks for the reply. its a simulated motor. I'm using proteus. i have simulated other sketched and tried to incorporate as much as i can as well.
1. Upload the simple sketches into Master and Slave to see that the Master can detect the presence of Slave and the Slave receives 7 (for example) from Master and shows on its Serial monitor. Do not forget to connect 2x4.7k pull-up resisters with signal wires of the I2C bus. Also, connect the GND-wire between the UNOs. The connection should be like Fig-1.
i2cunounox
Figure-1:
2. Master Sketch:
#include <Wire.h>
char y;
  Wire.begin();
  byte busStatus = Wire.endTransmission();
  if (busStatus != 0)
    Serial.print("Slave is not found.");
    while (1); //wait for ever
  Serial.println("Slave is found.");
  while (Serial.available() == 0)
    ;   //wait until data comes from SM1
  y = Serial.read();
  Wire.write(y);
3. Slave Sketch:
#include <Wire.h>
char y;
volatile bool flag = false;
  Wire.begin(8);
  if(flag == true)
    Serial.println(y);
    flag = false;
    y = Wire.read();    // receive byte as an integer
    flag = true;
4. Open Serial Monitor at the Master side with No line ending option.
5. Check that the message "Slave is found." has appeared on the OutputBox of the Serial Monitor (Fig-2).
Figure-2:
6. Open Serial Monitor for the Slave.
7. Enter 7 in the InputBox of the Serial Monitor of Master and then click on the Send button.
8. Check that 7 has appeared on SM2.
9. Now add your motor related codes with the above functional sketches.
This section is to TELL, not to ASK ,
Thread moved as requested.
