I'm working on a cool clock display using the TVout library. So far it's going pretty good with the built-in fonts.
I mocked up what I want the interface to look like. Eventually it'll end up on a small 4:3 5" CRT.
Something like this...
The problem is, there's only a few fonts that come with the library. The font for the time needs to be bigger. The largest font in the library is 8x8. What I really need is probably 16x16, or maybe bigger. I've even lowered the resolution to 90x90. (Any lower and the AM/PM in the time wraps to the next line.)
There's a small blurb over at the TVout website that says you make fonts like this:
Fixed width fonts: The first 3 bytes must contain the width, height, and first defined character followed by the font definitions. For example the following is the header and first 2 characters from the 4x6 font definition.
4,6,32,
//space
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b01000000,
0b01000000,
0b01000000,
0b00000000,
0b01000000,
0b00000000,There must be a full definition for each character; in this case the width of 4 fits into a single byte and the height of 6 means there needs to 6 bytes per character. Since 32 is the first printing character for this font set anything before character 32 will be ignored.
Variable width fonts: These fonts are defined by having a width of 0, height, and first defined character. An example of a variable width font with a height of 6 and the first printing character being a space.
0,6,32,
//space
2,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
3,
0b01000000,
0b01000000,
0b01000000,
0b00000000,
0b01000000,
0b00000000,
But it's not making any sense to me. How do you generate the "0b00000000, 0b00000000, 0b00000000, etc...." for each character?
Does anyone know how to generate the "code"?
