Hey, i'm planning on building my own little weather station with my arduino, but my main concern is how i can make it survive rain and moist in the rain, because we all know electronics and water don't mix
i'm planning to equip the weatherstation with a atmospheric pressure sensor, and if that is gonna work i can't put it in a water proof container, because then it wouldn't be able to messure the correct atmospheric pressure :S
And the temprature sensor is a small circuit board, and again that can't be mixed with water or air moist :S
Well, an important thing to remember is that rain usually falls downwards, and pressure sensors often have a tube coupler that allows them to be mounted in a dry place, but have the measuring part exposed to ambient pressure.
Choosing sensors more apt for the purpose is probably a good start. Here's a good alternative for a weatherproof digital temperature sensor (3.0 to 5V).
You want to look for a 'conformal coating', these are materials like lacquer that you paint on or spry to stop condensing humidity causing you problems.
They are not cheap, a selection can be seen here:-
If you're worried about moisture reaching the sensing element, isolate it with a U-tube, with a non-hygroscopic oil in the bend.
This will prevent any airborne contaminents (except those present when you connected the tube!) from reaching the sensor.
