How do I save a radio.read to a value?
#include <SPI.h>
#include "RF24.h"
#include "nRF24L01.h"
#include <Servo.h>
Servo servo1;
Servo servo2;
RF24 radio(9,10);
const uint64_t pipe=0xE8E8F0F0E1LL;
int data[2];
servo1.attach(5);
servo2.attach(6);
radio.begin();
radio.openReadingPipe(1,pipe);
radio.startListening();
if(radio.available()){
bool done = false;
while (!done){
done = radio.read(data, sizeof(data));
servo1.write(data[0]);
servo2.write(data[1]);
Serial.println(data[0]);
Serial.println(data[1]);
delay(20);
i am getting error ..please fix error
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
The read() function does not return a value which is why you are getting an error
Try
The value returned by the read() will be put into the data array but may not be what you are expecting
Post the error message. Please edit your post to add code tags.
The error will be something along the lines of
void value not ignored as it ought to be
Can you correct the code and paste here only ..it will be great help
It would be a great help if you followed the instructions.
I don't have much knowledge about coding ..so please correct the code and forward it to me
Please read and follow the instructions in the "How to get the best out of this forum" post.
yes ..this is the error we are getting
The corrected line of code in in reply #3
still i am getting same error .
Post your revised sketch in a new reply
done = radio.read(data,sizeof(data));
Your WHOLE revised sketch
Note what I said in reply #2
Is that what you put in your revised sketch ?
#include <SPI.h>
#include "RF24.h"
#include <Servo.h>
Servo servo1;
Servo servo2;
RF24 radio(9,10);
int data[32];
servo1.attach(5);
servo2.attach(6);
radio.begin();
bool done = false;
while (!done){
delay(20);
Answer : no
You still used
Change it to
thanks now its working fine
You will never have knowledge about coding if you ask for ready-made answers instead of trying to solve the problem yourself.
And you still not using code tags although you were asked several times to read the forum rules.
You got there in the end
