Hi all,
I'm looking to update a system that used turns of a cable and converts it into a speed. I wasn tto replace the cable with a stepper motor and drive the stepper motor.
My question is how fast ast the stepper motors? I never see the quoted rpms. I dont need that high rpm, but just wanted to check before buying one..
There are links on that page to places to buy the two kinds of chips needed to drive stepper motors. Follow the links and read the data sheets for the two kinds of chips. Figure out how much current each chip can supply, at what voltage. Then, choose a motor that needs less than that current at that voltage.
Or, save yourself a lot of grief, and buy a pre-designed motor driver shield/board, and get a motor that fits within that board's specs.
Once you have selected a motor, read it's data sheet to figure out how many steps per revolution. The driver data sheet will tell you how many steps/half steps/quarter steps per second the driver can manage. You use that and the steps per revolution to determine the maximum speed.
Of course, you can work backwards if you know what RPM you need.
Sounds like a Harley speedometer used up to the late 80s.
Top RPM is generally not a factor with a stepper motor. Stepper motors are use for precise positioning, not speed. However, 200 steps per revolution times 50 revolutions is only 10000 steps per minute, in single step mode, or 166 steps per second, which is very slow.
So, yes, 50 rpm is quite easy to achieve. Much higher speeds are possible, in single step mode, if 1.8 degree steps are satisfactory. If finer resolution is required, half, quarter, and eighth stepping is possible (0.9, 0.45, and 0.225 degrees per step). The tradeoff is that you won't be able to step as fast, since each step takes time.
Even at 1/8th stepping, 500 RPM should be possible - depending on voltage, current, and load, of course.
At low rpm it needs to be quite acruate to stop needle jumping ont eh speedo.
You should be able to find a setting (half, quarter, etc.) that balances the need for speed with the need for accuracy. The speedometer itself should have some mechanism for preventing needle flicker. If not, the key is to smoothly step the motor - constant interval between steps. The stepper library manages this for you.
I'm not yet convinced that the positional accuracy of a stepper motor is what you need. Perhaps just a regular electric motor that you can control the speed of is what you need.
all the DC motors ive ever used havnt been use to know what rpm they are turning at.
I dont want to have a 2 curcit like signal conditioning. Wher ei use another hall effect sensor to check what speed the motor is doing. I thought that using a stepping motor was a easy way of being able to set a rpm.
It would be. What, exactly, are you trying to do? Use a motor to make a speedometer move, yes. But, for what purpose? Calibration? Just to run up mileage? Visual effects?
Im replacing the cable that usally drives the speedo.
Doing this for several reasons. At the moment I do data logging on the car using the arduino, but the speedo has always been slightly incorrect and i've had enough of it. its about 10% too optimistic because tyre size has changed so hoping to correct that with a small bit of code and a motor
Ie the motor will be connected to the speedo to drive it from data im collecting from the car.
If you know that the speedometer is incorrect, and are already collecting information to know how fast the car is going, an LCD screen to show what you think the car's speed is would seem simpler to implement, to me.
Physically connecting the stepper to the speedo could be an issue. But, the stepper motor you referenced will step smoother, in single step mode, than a physically twisted cable will, and will be plenty fast enough.
Just had an idea. What about hard drive motors? THey spin up to 7200rpm and are 4 pole stepper (I think) I have one in a box of parts.
Is there any reason that wont work? Are they non-standard steppers?
But with a DC motor how can i know what rpm im setting?
Will it respond in a linear manor if i use PWM
is bushless bifferent? (i have little idea baout this i thought it was a stepper too but for higher rpm.)
You use an encoder, and a P/PI/PID/PD loop controll and adjust the rpm.
A brushless engine requires an ESC because it is in fact a 3 phase engine and it is rare the ESC that gives you rpm out and you dont have any clue how to design one to have precise rpm controll.
