How i can write float to EEPROM
Hi guys i'm trying write a float to EEPROM
Of course EEPROM can only write int...So i really dont understand how i can write a float number ?
I read many topics here, but i still dont understand
Here a part of my code
float result;
float soma=0.5;
if(state==LOW) // Menu temperature set
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("T.A.");
lcd.setCursor(0, 1);
lcd.print(result);
readingpinaq = digitalRead(pinup);
readingpinfaq2 = digitalRead(pindown);
if(readingpinaq==HIGH)
result=result+soma;
EEPROM.write(addr, result); // at this part i want write this float result
if(result>=31)
result=31;
if(readingpinfaq2==HIGH)
result=result-soma;
if(result<=18)
result=18;
Help me
Tanks
This will make it a lot easier - Arduino Playground - EEPROMWriteAnything.
No, EEPROM stores bytes. The meaning of those bytes is program-dependent.
Think about an integer variable or a float variable as a sequence of sizeof(variable) bytes. Each single byte can be transferred from RAM to EEPROM or vice-versa. In fact, you write or read one byte at a time to/from EEPROM.
Let me try with a pseudo-code example:
becomes:
ramAddr = &result;
eepromAddr = addr;
for i = 0 to sizeof(result) do:
    b = value of byte at ramAddr + i
    eeprom.writebyte(eepromAddr + i, b)
done
I use the "EEPROMAnything.h" and work. But i will try your code tux, i need understand
Reply later
Tanks !
I use the following to write setup settings to EEPROM:
int NoElements = 3;
unsigned int setting_table[3][3] = {
 { 20, 20, 50},
 { 10, 0, 600},
 { 150, 20, 255},
int ReadSetup()
  for (int i = 0; i < NoElements; i++)
    byte h = EEPROM.read(2 * i);
    byte l = EEPROM.read((2 * i) + 1);
    setting_table[i][0] = word(h, l);
  return 0;
int WriteSetup()
    byte h = highByte(setting_table[i][0]);
    byte l = lowByte(setting_table[i][0]);
    EEPROM.write(2 * i, h);
    EEPROM.write((2 * i) + 1, l);
  return 0;
Haven't got time to adapt to your sketch but come back if you're stuck and I'll have a look at it later.
The EEPROM only accepts bytes while an integer is two bytes. Double or floats use four bytes, therefore use a "4" instead of the "2"s above and use something other than highByte/lowByte to break up the double into its four constituent bytes.
Had a second look and its a bit more complex. Try this:
#include <EEPROM.h>
float num1 = 63412;
float num2 = 0;
  delay(2000);
  EEPROM_Write(&num1, 1); // memory position tested as '1'. Memory position
  EEPROM_Read(&num2, 1); // starts at 0 and goes up to max depending on processor.
  Serial.println(num2, DEC);
void EEPROM_Write(float *num, int MemPos)
  byte ByteArray[4];
  memcpy(ByteArray, num, 4);
  for(int x = 0; x < 4; x++)
    EEPROM.write((MemPos * 4) + x, ByteArray[x]);
void EEPROM_Read(float *num, int MemPos)
  byte ByteArray[4];
    ByteArray[x] = EEPROM.read((MemPos * 4) + x);
  memcpy(num, ByteArray, 4);
Tanks lemming, works fine !
I will this post help another people
