Hello all,
How many IC "MAX7219" can connected as cascaded ?
Thanks.
Hello all,
Thanks.
25000
This is important answer for my question, I have a lot looking for this information !!
Thanks a lot.
I went to Youtube and typed
arduino max7219 chain
into the search bar.
Chain there refers to daisy chain, how signal passes from one unit to the next. Wire it and power it, the number of units possible is a large number like enough to cover a big wall!
One video had a can't-do that looks like a too-little-power problem and the rest do something but don't say how many units can be chained.
I have a problem knowing if max7219 is the driver chip or the chip and 8x8 RGB led block where you know what you are using.
How many pixels and how bright they get is part of how much power you need. Some of those videos show how they done it, with wiring and code.
Oh, too much!, I have 10 line, every line will show 7-Segments , 8 digits or 10 or 3 , total digits are 60 ,
Thank you for this information .
Actually there is no limit
There are max7219 7 segment display videos but they are "buy this product" with a max7219 on the back and how to use that rather than how-to DIY your own display.
Would be glad to see the calculation.
see post #7
Post #7 does not show the calculation in favor of 25000.
Look closer
The datasheet doesn't give any indication as to the limit on the number of devices that can be cascaded together.
There's a maximum clock speed that the device will accept. That would then become a trade off between the update rate across the whole cascade and number of devices cascaded. More devices = slower update of the "display" as a whole .
My calculation based on IOH of ATmega328P and IIH of MAX7219 tells that a maximum number of 20,000 chips can be cascaded.
However, practically, the number would be much lower consideing the capacitances of the connecting wires.
but he is not using a 328 so your calculations are wrong.
Is my calculation right considering OP's Controller as ATmega328P?
What type of Controller/MCU the OP is using?
see post #7
@jim-p
Do you to mean that there would be no need of any intelligence device like an MCU to program MAX7219?
No. I mean there is no limit to how many devices can be cascaded (connected in series using din and dout)
What kind of Controller/Device is there to drive DIN-pin of the MAX7219?
