OK, So i have an atmega328(20 MHz I believe), How many times will
while(1)
//this peice of code
run in a second?
while(1)
run in a second?
It depends on your code!
To know it, use millis() to loop during a second and count how many times the loop was executed
Oh sweet i never knew about that function thanks!
Edit: So this code
unsigned long time_counted = 0;//the time variable
int loops = 0;
while(millis()<=1000)//we loop over
loops = loops + 1;//increments it
Serial.print("Time taken: ");
Serial.println(millis());
Serial.print("Loops: ");
Serial.println(loops);
delay(1000);//wait a second
Send me(via serial)
Time taken: 1011
Loops: -28425
why is it a negative number?
Edit2: Changed it to an unsigned long, and sent
Time taken: 12375
Loops: 338769
Thanks anyways...
The overhead of a "while (1)" loop is a single 2-cycle (ok, sometimes 3 cycles) machine instruction, so it takes less than 250 ns. There have been other discussions on optimization and speed. See in particular:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1230286016
ReCreate,
When you say 'millis() <= 1000', you are looping for less than one second. You are saying, "loop until one second since millis() started counting has passed." Since the millis() starts counting before setup() is called, you are getting a short count.
Try this:
unsigned long end_time;
end_time = millis() + 1000; // one second from now
while (millis() <= end_time)
You may see a few more loops that way.
Regards,
-Mike
