this is code i found on the internet, here the guy uses the delay function and then comments that delaying 3 ms makes the loop have 250 Hz, how is this true? 1000/3 ms = 333.33 Hz, this means that he assumes that the other bits of code lines and the function call take 1 ms so that (3 ms + 1 ms = 4 ms) and 1000/4 ms will give him = 250 Hz, if this is the case, how did he know that ? i'm asking because this last part is very critical in calculating the gyroscope's angle, the number of Hz value will later be used for calculating dt, and dt will later be multiplied by every angular velocity reading from the gyroscope.
Wire.begin(); //Start I2C as master
setup_mpu_6050_registers(); //Setup the registers of the MPU-6050
for (int cal_int = 0; cal_int < 1000 ; cal_int ++){ //Read the raw acc and gyro data from the MPU-6050 for 1000 times
read_mpu_6050_data();
gyro_x_cal += gyro_x; //Add the gyro x offset to the gyro_x_cal variable
gyro_y_cal += gyro_y; //Add the gyro y offset to the gyro_y_cal variable
gyro_z_cal += gyro_z; //Add the gyro z offset to the gyro_z_cal variable
delay(3); //Delay 3us to have 250Hz for-loop
//THIS IS A DEMO SOFTWARE JUST FOR EXPERIMENT PURPOER IN A NONCOMERTIAL ACTIVITY
//Version: 1.0 (AUG, 2016)
//Gyro - Arduino UNO R3
//VCC - 5V
//GND - GND
//SDA - A4
//SCL - A5
//INT - port-2
#include <Wire.h>
//Declaring some global variables
int gyro_x, gyro_y, gyro_z;
long gyro_x_cal, gyro_y_cal, gyro_z_cal;
boolean set_gyro_angles;
long acc_x, acc_y, acc_z, acc_total_vector;
float angle_roll_acc, angle_pitch_acc;
float angle_pitch, angle_roll;
int angle_pitch_buffer, angle_roll_buffer;
float angle_pitch_output, angle_roll_output;
long loop_timer;
int temp;
// divide by 1000 to get avarage offset
gyro_x_cal /= 1000;
gyro_y_cal /= 1000;
gyro_z_cal /= 1000;
loop_timer = micros(); //Reset the loop timer
read_mpu_6050_data(b);
//Subtract the offset values from the raw gyro values
gyro_x -= gyro_x_cal;
gyro_y -= gyro_y_cal;
gyro_z -= gyro_z_cal;
//Gyro angle calculations . Note 0.0000611 = 1 / (250Hz x 65.5)
angle_pitch += gyro_x * 0.0000611; //Calculate the traveled pitch angle and add this to the angle_pitch variable
angle_roll += gyro_y * 0.0000611; //Calculate the traveled roll angle and add this to the angle_roll variable
//0.000001066 = 0.0000611 * (3.142(PI) / 180degr) The Arduino sin function is in radians
angle_pitch += angle_roll * sin(gyro_z * 0.000001066); //If the IMU has yawed transfer the roll angle to the pitch angel
angle_roll -= angle_pitch * sin(gyro_z * 0.000001066); //If the IMU has yawed transfer the pitch angle to the roll angel
//Accelerometer angle calculations
acc_total_vector = sqrt((acc_x*acc_x)+(acc_y*acc_y)+(acc_z*acc_z)); //Calculate the total accelerometer vector
//57.296 = 1 / (3.142 / 180) The Arduino asin function is in radians
angle_pitch_acc = asin((float)acc_y/acc_total_vector)* 57.296; //Calculate the pitch angle
angle_roll_acc = asin((float)acc_x/acc_total_vector)* -57.296; //Calculate the roll angle
angle_pitch_acc -= 0.0; //Accelerometer calibration value for pitch
angle_roll_acc -= 0.0; //Accelerometer calibration value for roll
if(set_gyro_angles){ //If the IMU is already started
angle_pitch = angle_pitch * 0.9996 + angle_pitch_acc * 0.0004; //Correct the drift of the gyro pitch angle with the accelerometer pitch angle
angle_roll = angle_roll * 0.9996 + angle_roll_acc * 0.0004; //Correct the drift of the gyro roll angle with the accelerometer roll angle
else{ //At first start
angle_pitch = angle_pitch_acc; //Set the gyro pitch angle equal to the accelerometer pitch angle
angle_roll = angle_roll_acc; //Set the gyro roll angle equal to the accelerometer roll angle
set_gyro_angles = true; //Set the IMU started flag
//To dampen the pitch and roll angles a complementary filter is used
angle_pitch_output = angle_pitch_output * 0.9 + angle_pitch * 0.1; //Take 90% of the output pitch value and add 10% of the raw pitch value
angle_roll_output = angle_roll_output * 0.9 + angle_roll * 0.1; //Take 90% of the output roll value and add 10% of the raw roll value
Serial.println(angle_pitch_output);
while(micros() - loop_timer < 4000); //Wait until the loop_timer reaches 4000us (250Hz) before starting the next loop
loop_timer = micros();//Reset the loop timer
void setup_mpu_6050_registers(){
//Activate the MPU-6050
Wire.beginTransmission(0x68); //Start communicating with the MPU-6050
Wire.write(0x6B); //Send the requested starting register
Wire.write(0x00); //Set the requested starting register
Wire.endTransmission();
//Configure the accelerometer (+/-8g)
Wire.write(0x1C); //Send the requested starting register
Wire.write(0x10); //Set the requested starting register
//Configure the gyro (500dps full scale)
Wire.write(0x1B); //Send the requested starting register
Wire.write(0x08); //Set the requested starting register
void read_mpu_6050_data(){ //Subroutine for reading the raw gyro and accelerometer data
Wire.write(0x3B); //Send the requested starting register
Wire.endTransmission(); //End the transmission
Wire.requestFrom(0x68,14); //Request 14 bytes from the MPU-6050
while(Wire.available() < 14); //Wait until all the bytes are received
acc_x = Wire.read()<<8|Wire.read();
acc_y = Wire.read()<<8|Wire.read();
acc_z = Wire.read()<<8|Wire.read();
temp = Wire.read()<<8|Wire.read();
gyro_x = Wire.read()<<8|Wire.read();
gyro_y = Wire.read()<<8|Wire.read();
gyro_z = Wire.read()<<8|Wire.read();
