the aim of my project is to measure the heart rate. I currently have a heart sensor, LCD screen and I need to add a buzzer, but I don't know what code to use and where it goes in the breadboard and the Arduino Uno. I need the buzzer to make a sound when the heart rate is higher than normal which is 60-90BMP.
This is the code that I have right now:
#include <LiquidCrystal.h>
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int pulsePin = A0; // Pulse Sensor purple wire connected to analog pin A0
int blinkPin = 13; // pin to blink led at each beat
// Volatile Variables, used in the interrupt service routine!
volatile int BPM; // int that holds raw Analog in 0. updated every 2mS
volatile int Signal; // holds the incoming raw data
volatile int IBI = 300; // int that holds the time interval between beats! Must be seeded!
volatile boolean Pulse = false; // "True" when User's live heartbeat is detected. "False" when not a "live beat".
volatile boolean QS = false; // becomes true when Arduoino finds a beat.
static boolean serialVisual = true; // Set to 'false' by Default. Re-set to 'true' to see Arduino Serial Monitor ASCII Visual Pulse
volatile int rate[10]; // array to hold last ten IBI values
volatile unsigned long sampleCounter = 0; // used to determine pulse timing
volatile unsigned long lastBeatTime = 0; // used to find IBI
volatile int P = 512; // used to find peak in pulse wave, seeded
volatile int T = 512; // used to find trough in pulse wave, seeded
volatile int thresh = 525; // used to find instant moment of heart beat, seeded
volatile int amp = 100; // used to hold amplitude of pulse waveform, seeded
volatile boolean firstBeat = true; // used to seed rate array so we startup with reasonable BPM
volatile boolean secondBeat = false; // used to seed rate array so we startup with reasonable BPM
pinMode(blinkPin,OUTPUT); // pin that will blink to your heartbeat!
Serial.begin(115200); // we agree to talk fast!
interruptSetup(); // sets up to read Pulse Sensor signal every 2mS
// IF YOU ARE POWERING The Pulse Sensor AT VOLTAGE LESS THAN THE BOARD VOLTAGE,
// UN-COMMENT THE NEXT LINE AND APPLY THAT VOLTAGE TO THE A-REF PIN
// analogReference(EXTERNAL);
lcd.begin(16, 2);
lcd.clear();
// Where the Magic Happens
serialOutput();
if (QS == true) // A Heartbeat Was Found
// BPM and IBI have been Determined
// Quantified Self "QS" true when arduino finds a heartbeat
serialOutputWhenBeatHappens(); // A Beat Happened, Output that to serial.
QS = false; // reset the Quantified Self flag for next time
delay(10); // take a break
void interruptSetup()
// Initializes Timer2 to throw an interrupt every 2mS.
TCCR2A = 0x02; // DISABLE PWM ON DIGITAL PINS 3 AND 11, AND GO INTO CTC MODE
TCCR2B = 0x06; // DON'T FORCE COMPARE, 256 PRESCALER
OCR2A = 0X7C; // SET THE TOP OF THE COUNT TO 124 FOR 500Hz SAMPLE RATE
TIMSK2 = 0x02; // ENABLE INTERRUPT ON MATCH BETWEEN TIMER2 AND OCR2A
sei(); // MAKE SURE GLOBAL INTERRUPTS ARE ENABLED
void serialOutput()
{ // Decide How To Output Serial.
if (serialVisual == true)
arduinoSerialMonitorVisual('-', Signal); // goes to function that makes Serial Monitor Visualizer
sendDataToSerial('S', Signal); // goes to sendDataToSerial function
void serialOutputWhenBeatHappens()
if (serialVisual == true) // Code to Make the Serial Monitor Visualizer Work
Serial.print(" Heart-Beat Found "); //ASCII Art Madness
Serial.print("BPM: ");
Serial.println("BPM");
lcd.print("Heart-Beat Found ");
lcd.setCursor(1,1);
lcd.print("BPM: ");
lcd.setCursor(5,1);
lcd.print(BPM);
delay(300);
lcd.clear();
sendDataToSerial('B',BPM); // send heart rate with a 'B' prefix
sendDataToSerial('Q',IBI); // send time between beats with a 'Q' prefix
void arduinoSerialMonitorVisual(char symbol, int data )
const int sensorMin = 0; // sensor minimum, discovered through experiment
const int sensorMax = 1024; // sensor maximum, discovered through experiment
int sensorReading = data; // map the sensor range to a range of 12 options:
int range = map(sensorReading, sensorMin, sensorMax, 0, 11);
// do something different depending on the
// range value:
void sendDataToSerial(char symbol, int data )
Serial.print(symbol);
Serial.println(data);
ISR(TIMER2_COMPA_vect) //triggered when Timer2 counts to 124
cli(); // disable interrupts while we do this
Signal = analogRead(pulsePin); // read the Pulse Sensor
sampleCounter += 2; // keep track of the time in mS with this variable
int N = sampleCounter - lastBeatTime; // monitor the time since the last beat to avoid noise
// find the peak and trough of the pulse wave
if(Signal < thresh && N > (IBI/5)*3) // avoid dichrotic noise by waiting 3/5 of last IBI
if (Signal < T) // T is the trough
T = Signal; // keep track of lowest point in pulse wave
if(Signal > thresh && Signal > P)
{ // thresh condition helps avoid noise
P = Signal; // P is the peak
} // keep track of highest point in pulse wave
// NOW IT'S TIME TO LOOK FOR THE HEART BEAT
// signal surges up in value every time there is a pulse
if (N > 250)
{ // avoid high frequency noise
if ( (Signal > thresh) && (Pulse == false) && (N > (IBI/5)*3) )
Pulse = true; // set the Pulse flag when we think there is a pulse
digitalWrite(blinkPin,HIGH); // turn on pin 13 LED
IBI = sampleCounter - lastBeatTime; // measure time between beats in mS
lastBeatTime = sampleCounter; // keep track of time for next pulse
if(secondBeat)
{ // if this is the second beat, if secondBeat == TRUE
secondBeat = false; // clear secondBeat flag
for(int i=0; i<=9; i++) // seed the running total to get a realisitic BPM at startup
rate *= IBI; *
- if(firstBeat) // if it's the first time we found a beat, if firstBeat == TRUE*
- firstBeat = false; // clear firstBeat flag*
- secondBeat = true; // set the second beat flag*
- sei(); // enable interrupts again*
- return; // IBI value is unreliable so discard it*
- // keep a running total of the last 10 IBI values*
- word runningTotal = 0; // clear the runningTotal variable *
- for(int i=0; i<=8; i++)*
- { // shift data in the rate array*
_ rate = rate[i+1]; // and drop the oldest IBI value_
_ runningTotal += rate*; // add up the 9 oldest IBI values*
rate[9] = IBI; // add the latest IBI to the rate array*
* runningTotal += rate[9]; // add the latest IBI to runningTotal*
* runningTotal /= 10; // average the last 10 IBI values*
* BPM = 30000/runningTotal;
QS = true;
// QS FLAG IS NOT CLEARED INSIDE THIS ISR*
if (Signal < thresh && Pulse == true)
{ // when the values are going down, the beat is over
* digitalWrite(blinkPin,LOW);
Pulse = false;
amp = P - T;
thresh = amp/2 + T;
P = thresh;
T = thresh;
if (N > 2500)
thresh = 512;
P = 512;
T = 512;
firstBeat = true;
secondBeat = false;
sei();
}_
