I have ESP32. My code is working with the alexa. But i am facing one problem. When light turn off my device come to old setting. I live in Pakistan and there is load-shedding problem. So device always goes back to old state.
int device1 = 23;
int device2 = 22;
int device3 = 19;
int device4 = 18;
int device5 = 5;
int device6 = 17;
int device7 = 16;
int device8 = 4;
#include <Arduino.h>
#include <WiFi.h>
#include <WiFiMulti.h>
#include <WebSocketsClient.h> // get it from https://github.com/Links2004/arduinoWebSockets/releases
#include <ArduinoJson.h> // get it from https://arduinojson.org/ or install via Arduino library manager
#include <StreamString.h>
WiFiMulti WiFiMulti;
WebSocketsClient webSocket;
WiFiClient client;
#define MyApiKey "34af406e-6244-4663-997c-34b5f56ddb8a" // TODO: Change to your sinric API Key. Your API Key is displayed on sinric.com dashboard
#define MySSID "Home" // TODO: Change to your Wifi network SSID
#define MyWifiPassword "53883098" // TODO: Change to your Wifi network password
#define HEARTBEAT_INTERVAL 300000 // 5 Minutes
uint64_t heartbeatTimestamp = 0;
bool isConnected = false;
void setPowerStateOnServer(String deviceId, String value);
void setTargetTemperatureOnServer(String deviceId, String value, String scale);
// deviceId is the ID assgined to your smart-home-device in sinric.com dashboard. Copy it from dashboard and paste it here
void turnOn(String deviceId) {
if (deviceId == "5c35ed05010d8c32b5565580") // Device ID of device 1
Serial.print("Turnevice id: ");
Serial.println(deviceId);
digitalWrite(device1, LOW);
else if (deviceId == "5c35ed93010d8c32b5565588") // Device ID of device 2
digitalWrite(device2, LOW);
else if (deviceId == "5c35ee0e010d8c32b556558b") // Device ID of device 3
digitalWrite(device3, LOW);
else if (deviceId == "5c35ee59010d8c32b556558d") // Device ID of device 4
digitalWrite(device4, LOW);
else if (deviceId == "5c36e5b304018c4adb252073") // Device ID of device 5
digitalWrite(device5, LOW);
else if (deviceId == "5c36e5be04018c4adb252075") // Device ID of device 6
digitalWrite(device6, LOW);
else if (deviceId == "5c36e5c804018c4adb252077") // Device ID of device 7
digitalWrite(device7, LOW);
else if (deviceId == "5c36e5d204018c4adb252079") // Device ID of device 8
digitalWrite(device8, LOW);
Serial.print("Turnor unknown device id: ");
void turnOff(String deviceId) {
Serial.print("TurnDevice ID: ");
digitalWrite(device1, HIGH);
digitalWrite(device2, HIGH);
digitalWrite(device3, HIGH);
digitalWrite(device4, HIGH);
digitalWrite(device5, HIGH);
digitalWrite(device6, HIGH);
digitalWrite(device7, HIGH);
digitalWrite(device8, HIGH);
Serial.print("Turnfor unknown device id: ");
void webSocketEvent(WStype_t type, uint8_t * payload, size_t length) {
switch(type) {
case WStype_DISCONNECTED:
Serial.printf("[WSc] Webservice disconnected from sinric.com!\n");
case WStype_CONNECTED: {
isConnected = true;
Serial.printf("[WSc] Service connected to sinric.com at url: %s\n", payload);
Serial.printf("Waiting for commands from sinric.com ...\n");
case WStype_TEXT: {
Serial.printf("[WSc] get text: %s\n", payload);
// Example payloads
// For Switch or Light device types
// {"deviceId": xxxx, "action": "setPowerState", value: "ON"} // https://developer.amazon.com/docs/device-apis/alexa-powercontroller.html
// For Light device type
// Look at the light example in github
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject((char*)payload);
String deviceId = json ["deviceId"];
String action = json ["action"];
if(action == "setPowerState") { // Switch or Light
String value = json ["value"];
if(value == "ON") {
turnOn(deviceId);
turnOff(deviceId);
else if (action == "SetTargetTemperature") {
else if (action == "test") {
Serial.println("[WSc] received test command from sinric.com");
case WStype_BIN:
Serial.printf("[WSc] get binary length: %u\n", length);
pinMode(device1, OUTPUT);
pinMode(device2, OUTPUT);
pinMode(device3, OUTPUT);
pinMode(device4, OUTPUT);
pinMode(device5, OUTPUT);
pinMode(device6, OUTPUT);
pinMode(device7, OUTPUT);
pinMode(device8, OUTPUT);
WiFiMulti.addAP(MySSID, MyWifiPassword);
Serial.print("Connectingifi: ");
Serial.println(MySSID);
// Waiting for Wifi connect
while(WiFiMulti.run() != WL_CONNECTED) {
Serial.print(".");
if(WiFiMulti.run() == WL_CONNECTED) {
Serial.println("");
Serial.print("WiFiected. ");
Serial.print("IPess: ");
// server address, port and URL
webSocket.begin("iot.sinric.com",80,"/");
// event handler
webSocket.onEvent(webSocketEvent);
webSocket.setAuthorization("apikey", MyApiKey);
// try again every 5000ms if connection has failed
webSocket.setReconnectInterval(5000); // If you see 'class WebSocketsClient' has no member named 'setReconnectInterval' error update arduinoWebSockets
webSocket.loop();
if(isConnected) {
uint64_t now = millis();
// Send heartbeat in order to avoid disconnections during ISP resetting IPs over night. Thanks @MacSass
if((now - heartbeatTimestamp) > HEARTBEAT_INTERVAL) {
heartbeatTimestamp = now;
webSocket.sendTXT("H");
// If you are going to use a push button to on/off the switch manually, use this function to update the status on the server
// so it will reflect on Alexa app.
// eg: setPowerStateOnServer("deviceid", "ON")
void setPowerStateOnServer(String deviceId, String value) {
JsonObject& root = jsonBuffer.createObject();
root["deviceId"] = deviceId;
root["action"] = "setPowerState";
root["value"] = value;
StreamString databuf;
root.printTo(databuf);
webSocket.sendTXT(databuf);
//eg: setPowerStateOnServer("deviceid", "CELSIUS", "25.0")
void setTargetTemperatureOnServer(String deviceId, String value, String scale) {
root["action"] = "SetTargetTemperature";
JsonObject& valueObj = root.createNestedObject("value");
JsonObject& targetSetpoint = valueObj.createNestedObject("targetSetpoint");
targetSetpoint["value"] = value;
targetSetpoint["scale"] = scale;
