How to add sensor to my project?
Hey guys, newbie in arduino here, I'm following this guide on making an alarm clock (https://marobotic.com/2023/12/09/real-time-clock-with-alarm-using-arduino-and-rtc-ds3231/) but I wanted to add my own spin to it by including a motion sensor to deactivate the alarm by waving my hand. Any suggestions on how I can do that?
I'm planning to use the hc-sr04 ultrasonic sensor
You can modify the code in Arduino and ultrasonic sensor triggers LED tutorial
Hello, I'm following this guide on making an alarm clock (https://marobotic.com/2023/12/09/real-time-clock-with-alarm-using-arduino-and-rtc-ds3231/) but I'm adding an ultrasonic sensor (HC-SR04) so I can deactivate the alarm buzzer when it rings by covering the sensor with my hand.
The sensor is placed on a separate arduino uno board and connected by pins 11(Input), 12(Output), and GRD to the clock arduino uno board.
I have codes for both boards and they work fine independently but I have no idea how to connect the codes to make them work together. Can someone take a look at my code and guide me on what to do?
Alarm Clock Code: Upload files for free - AlarmClockCode.ino - ufile.io
Ultrasonic Sensor Code: Upload files for free - SensorCode.ino - ufile.io
Your two topics on the same subject have been merged. Cross posting wastes peoples time.
Please post your code in a post; do not use a link forcing people to download from some site. You're also missing out on the knowledge of people that are using cell phones.
If your code is more than 120kB, attaching a file here is acceptable.
Sorry I'm still new to this website. Couldn't load my original post so I made another one.
Thanks for merging them! Also, apologies for posting a link, the file isn't big its just a lot of lines of code so I thought people would prefer to download it instead.
Anyways, here is the code for the Alarm Clock:
#include <DS3231.h>         // RTC DS3231 Library
#include <Wire.h>           // I2C Connection Library
#include <LiquidCrystal.h>  // LCD Library
#include <EEPROM.h>         // Memory Library
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);  // Arduino pins to LCD
#define bt_time   A0
#define bt_up     A1
#define bt_down   A2
#define bt_alarm  A3
#define buzzer    8
// Notes for music
#define C4   262
#define CS4  277
#define D4   294
#define DS4  311
#define E4   330
#define F4   349
#define FS4  370
#define G4   392
#define GS4  415
#define A4   440
#define AS4  466
#define B4   494
#define C5   523
#define CS5  554
#define D5   587
#define DS5  622
#define E5   659
#define F5   698
#define FS5  740
#define G5   784
#define GS5  831
#define A5   880
#define AS5  932
#define B5   988
#define C6   1047
#define CS6  1109
#define D6   1175
#define DS6  1245
#define E6   1319
#define F6   1397
#define FS6  1480
#define G6   1568
#define GS6  1661
#define A6   1760
#define AS6  1865
#define B6   1976
// Init DS3231
DS3231 rtc(SDA, SCL);
// Init a Time-data structure
Time t;
int hh = 0, mm = 0, ss = 0, dd = 0, bb = 0, set_day;
int yy = 0;
String Day = "  ";
int AlarmHH = 21, AlarmMM = 22, AlarmSS = 23, setMode = 0, setAlarm = 0, alarmMode = 0;
int stop = 0, mode = 0, flag = 0;
// EEPROM Store Variable
uint8_t HH;
uint8_t MM;
byte bell_symbol[8] = {
    B00100,
    B01110,
    B01110,
    B01110,
    B01110,
    B11111,
    B01000,
    B00100
byte thermometer_symbol[8] = {
    B00100,
    B01010,
    B01010,
    B01110,
    B01110,
    B11111,
    B11111,
    B01110
    // Setup Serial connection
    rtc.begin();
    pinMode(bt_time, INPUT_PULLUP);
    pinMode(bt_up, INPUT_PULLUP);
    pinMode(bt_down, INPUT_PULLUP);
    pinMode(bt_alarm, INPUT_PULLUP);
    pinMode(buzzer, OUTPUT);
    lcd.createChar(1, thermometer_symbol);
    lcd.createChar(2, bell_symbol);
    lcd.begin(16, 2);  // Configura LCD numero columnas y filas
    lcd.setCursor(0, 0);  // Show "TIME" on the LCD
    lcd.print(" Real Time Clock ");
    lcd.setCursor(0, 1);
    lcd.print("   With Alarm ");
    delay(2000);
    lcd.clear();
    stop = EEPROM.read(50);
    if (stop == 0) {
        // Do nothing
        WriteEeprom();
    EEPROM.write(50, 0);
    ReadEeprom();
    // Set RTC for the first time
    // rtc.setDOW(2);     // Set Day-of-Week to SUNDAY
    // rtc.setTime(00, 9, 50);
    // rtc.setDate(12, 11, 2017);
    t = rtc.getTime();
    Day = rtc.getDOWStr(1);
    if (setMode == 0) {
        hh = t.hour, DEC;
        mm = t.min, DEC;
        ss = t.sec, DEC;
        dd = t.date, DEC;
        bb = t.mon, DEC;
        yy = t.year, DEC;
    if (hh >= 5 && hh < 12) {
        digitalWrite(11, 1);
        digitalWrite(13, 0);
    if (hh >= 12 && hh < 18) {
        digitalWrite(11, 0);
        digitalWrite(13, 1);
    if (hh >= 18 && hh < 24) {
    if (hh >= 0 && hh < 5) {
    if (setAlarm == 0) {
        lcd.print((hh / 10) % 10);
        lcd.print(hh % 10);
        lcd.print(":");
        lcd.print((mm / 10) % 10);
        lcd.print(mm % 10);
        lcd.print(":");
        lcd.print((ss / 10) % 10);
        lcd.print(ss % 10);
        lcd.print(" ");
        if (mode == 1) {
            lcd.write(2);
            lcd.print(" ");
        lcd.print(" ");
        lcd.write(1);
        lcd.print(rtc.getTemp(), 0);
        lcd.write(223);
        lcd.print("C");
        lcd.print("  ");
        lcd.setCursor(1, 1);
        lcd.print(Day);
        lcd.print(" ");
        lcd.print((dd / 10) % 10);
        lcd.print(dd % 10);
        lcd.print("/");
        lcd.print((bb / 10) % 10);
        lcd.print(bb % 10);
        lcd.print("/");
        lcd.print((yy / 1000) % 10);
        lcd.print((yy / 100) % 10);
        lcd.print((yy / 10) % 10);
        lcd.print(yy % 10);
    setupClock();
    setTimer();
    delay(100);
    blinking();
    // Alarm
    if (alarmMode == 1 && mode == 1 && hh == AlarmHH && mm == AlarmMM && ss >= AlarmSS) {
        digitalWrite(buzzer, HIGH);
        tone(8, B4);
        delay(300);
        tone(8, E5);
        delay(600);
        tone(8, G5);
        delay(120);
        tone(8, FS5);
        delay(230);
        tone(8, E5);
        delay(600);
        tone(8, B5);
        delay(300);
        tone(8, A5);
        delay(900);
        tone(8, FS5);
        delay(900);
        tone(8, E5);
        delay(600);
        tone(8, G5);
        delay(130);
        tone(8, FS5);
        delay(200);
        tone(8, DS5);
        delay(600);
        tone(8, E5);
        delay(300);
        tone(8, B4);
        delay(1530);
        tone(8, B4);
        delay(300);
        tone(8, E5);
        delay(600);
        tone(8, G5);
        delay(120);
        tone(8, FS5);
        delay(230);
        tone(8, E5);
        delay(600);
        tone(8, B5);
        delay(300);
        tone(8, D6);
        delay(700);
        tone(8, CS6);
        delay(300);
        tone(8, C6);
        delay(600);
        tone(8, GS5);
        delay(300);
        tone(8, C6);
        delay(600);
        tone(8, B5);
        delay(130);
        tone(8, AS5);
        delay(190);
        tone(8, AS4);
        delay(700);
        tone(8, G5);
        delay(230);
        tone(8, E5);
        delay(600);
        tone(8, G4);
        delay(300);
        tone(8, B4);
        delay(900);
        digitalWrite(buzzer, LOW);
    delay(100);
void blinking() {
    // BLINKING SCREEN
    if (setAlarm < 2 && setMode == 1) {
        lcd.print("  ");
    if (setAlarm < 2 && setMode == 2) {
        lcd.setCursor(3, 0);
        lcd.print("  ");
    if (setAlarm < 2 && setMode == 3) {
        lcd.setCursor(6, 0);
        lcd.print("  ");
    if (setAlarm < 2 && setMode == 4) {
        lcd.print("   ");
    if (setAlarm < 2 && setMode == 5) {
        lcd.setCursor(5, 1);
        lcd.print("  ");
    if (setAlarm < 2 && setMode == 6) {
        lcd.setCursor(8, 1);
        lcd.print("  ");
    if (setAlarm < 2 && setMode == 7) {
        lcd.setCursor(11, 1);
        lcd.print("    ");
    // Alarm
    if (setMode == 0 && setAlarm == 1) {
        lcd.print("           ");
    if (setMode == 0 && setAlarm == 2) {
        lcd.setCursor(4, 1);
        lcd.print("  ");
    if (setMode == 0 && setAlarm == 3) {
        lcd.setCursor(7, 1);
        lcd.print("  ");
    if (setMode == 0 && setAlarm == 4) {
        lcd.setCursor(10, 1);
        lcd.print("  ");
void setupClock() {
    if (setMode == 8) {
        lcd.print(F("Set Date Finish "));
        lcd.print(F("Set Time Finish "));
        rtc.setTime(hh, mm, ss);
        rtc.setDate(dd, bb, yy);
        lcd.clear();
        setMode = 0;
    if (setAlarm == 5) {
        lcd.print(F("Set Alarm Finish"));
        lcd.print(F("-EEPROM Updated-"));
        WriteEeprom();
        delay(2000);
        lcd.clear();
        setAlarm = 0;
        alarmMode = 1;
    if (setAlarm > 0) {
        alarmMode = 0;
    if (digitalRead(bt_time) == 0 && flag == 0) {
        flag = 1;
        if (setAlarm > 0) {
            setAlarm = 5;
            setMode = setMode + 1;
    if (digitalRead(bt_alarm) == 0 && flag == 0) {
        flag = 1;
        if (setMode > 0) {
            setMode = 8;
            setAlarm = setAlarm + 1;
        lcd.clear();
    if (digitalRead(bt_time) == 1 && digitalRead(bt_alarm) == 1) {
        flag = 0;
    if (digitalRead(bt_up) == 0) {
        if (setAlarm < 2 && setMode == 1) hh = hh + 1;
        if (setAlarm < 2 && setMode == 2) mm = mm + 1;
        if (setAlarm < 2 && setMode == 3) ss = ss + 1;
        if (setAlarm < 2 && setMode == 4) set_day = set_day + 1;
        if (setAlarm < 2 && setMode == 5) dd = dd + 1;
        if (setAlarm < 2 && setMode == 6) bb = bb + 1;
        if (setAlarm < 2 && setMode == 7) yy = yy + 1;
        // Alarm
        if (setMode == 0 && setAlarm == 1) mode = 1;
        if (setMode == 0 && setAlarm == 2 && AlarmHH < 23) AlarmHH = AlarmHH + 1;
        if (setMode == 0 && setAlarm == 3 && AlarmMM < 59) AlarmMM = AlarmMM + 1;
        if (setMode == 0 && setAlarm == 4 && AlarmSS < 59) AlarmSS = AlarmSS + 1;
        if (hh > 23) hh = 0;
        if (mm > 59) mm = 0;
        if (ss > 59) ss = 0;
        if (set_day > 7) set_day = 0;
        if (dd > 31) dd = 0;
        if (bb > 12) bb = 0;
        if (yy > 2030) yy = 2000;
        rtc.setDOW(set_day);
    if (digitalRead(bt_down) == 0) {
        if (setAlarm < 2 && setMode == 1) hh = hh - 1;
        if (setAlarm < 2 && setMode == 2) mm = mm - 1;
        if (setAlarm < 2 && setMode == 3) ss = ss - 1;
        if (setAlarm < 2 && setMode == 4) set_day = set_day - 1;
        if (setAlarm < 2 && setMode == 5) dd = dd - 1;
        if (setAlarm < 2 && setMode == 6) bb = bb - 1;
        if (setAlarm < 2 && setMode == 7) yy = yy - 1;
        // Alarm
        if (setMode == 0 && setAlarm == 1) mode = 0;
        if (setMode == 0 && setAlarm == 2 && AlarmHH > 0) AlarmHH = AlarmHH - 1;
        if (setMode == 0 && setAlarm == 3 && AlarmMM > 0) AlarmMM = AlarmMM - 1;
        if (setMode == 0 && setAlarm == 4 && AlarmSS > 0) AlarmSS = AlarmSS - 1;
        if (hh < 0) hh = 23;
        if (mm < 0) mm = 59;
        if (ss < 0) ss = 59;
        if (set_day < 0) set_day = 7;
        if (dd < 0) dd = 31;
        if (bb < 0) bb = 12;
        if (yy < 0) yy = 2030;
void setTimer() {
    // Alarm
    if (setMode == 0 && setAlarm > 0) {
        lcd.print("Alarm ");
        if (mode == 0) {
            lcd.print("Deactivate");
            lcd.print("Activated ");
        lcd.print((AlarmHH / 10) % 10);
        lcd.print(AlarmHH % 10);
        lcd.print(":");
        lcd.print((AlarmMM / 10) % 10);
        lcd.print(AlarmMM % 10);
        lcd.print(":");
        lcd.print((AlarmSS / 10) % 10);
        lcd.print(AlarmSS % 10);
void ReadEeprom() {
    AlarmHH = EEPROM.read(1);
    AlarmMM = EEPROM.read(2);
    AlarmSS = EEPROM.read(3);
    mode = EEPROM.read(4);
void WriteEeprom() {
    EEPROM.write(1, AlarmHH);
    EEPROM.write(2, AlarmMM);
    EEPROM.write(3, AlarmSS);
    EEPROM.write(4, mode);
And here is the code for the sensor:
const int trig = 9;
const int echo = 10;
  pinMode(trig, OUTPUT);
  pinMode(echo, INPUT);
  digitalWrite(trig, LOW);
  delayMicroseconds(2);
  digitalWrite(trig, HIGH);
  delayMicroseconds(10);
  int Duration = pulseIn(echo, HIGH);
  int Distance = (0.0343 * Duration) / 2;
  Serial.println(Distance);
