Example: people want to entered the web sever need to key in SSID and password to entered.
you just create a log in web page same way you'd in web designs, when the log ins match with those pre defined in your sketch....
Check out ArduinoOTA
Deva_Rishi:
i am tried
#include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
#include <ArduinoOTA.h>
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
ESP8266WebServer server(80);
const char* www_username = "admin";
const char* www_password = "esp8266";
ArduinoOTA.begin();
server.on("/", []() {
if (!server.authenticate(www_username, www_password)) {
return server.requestAuthentication();
server.send(200, "text/plain", "Login ok");
server.begin();
Serial.println("Open http://192.168.4.1");
Serial.println("/ in your browser to see it working");
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
//reset saved settings
wifiManager.resetSettings();
//set custom ip for portal
//wifiManager.setAPStaticIPConfig(IPAddress(10,0,1,1), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
//fetches ssid and pass from eeprom and tries to connect
//if it does not connect it starts an access point with the specified name
//here "AutoConnectAP"
//and goes into a blocking loop awaiting configuration
wifiManager.autoConnect("AutoConnectAP");
//or use this for auto generated name ESP + ChipID
//wifiManager.autoConnect();
//if you get here you have connected to the WiFi
Serial.println("HTTP SERVER CONNECTED:)");
ArduinoOTA.handle();
i added in the user name and password for my esp8266 web sever .but now i cant go in 192.168.4.1 pages
you forgot to also addserver.handleClient();to your loop() {}
Deva_Rishi:
</ in your browser to see it working
*WM: settings invalidated
*WM: THIS MAY CAUSE AP NOT TO START UP PROPERLY. YOU NEED TO COMMENT IT OUT AFTER ERASING THE DATA.
*WM:
*WM: AutoConnect
*WM: Connecting as wifi client...
*WM: Using last saved values, should be faster
*WM: Connection result:
*WM: 0
*WM:
*WM: Configuring access point...
*WM: AutoConnectAP
*WM: AP IP address:
*WM: 192.168.4.1
*WM: HTTP server started>
yes.After i added this shown on my serial monitor but i still cant login 192.168.4.1 web page throw my browser.
The issue is caused by the combination of OTA and wifimanager (which i never use, and this a pretty good reason not to), wifimanager handles the root of the AP (so you can't access and use that anymore, and takes care of any wifi connection to station made, i got this working by changing the order up a bit
#include <ESP8266mDNS.h>
//WiFiManager
server.begin();
ArduinoOTA.begin();
after which i could access the page with the ESP in station mode using the wifi network i connected to. unfortunately i had to guess what the new IP address would be (but i tried the ones it has shown up in previously) but found it.
the standard sketch for the OTA makes it a little easier to understand (and leaves the access point for common use)
const char* ssid = "ESPap";
const char* password = "";
WiFi.softAP(ssid, password);
IPAddress myIP = WiFi.softAPIP();
/*WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
if(WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("WiFi Connect Failed! Rebooting...");
ESP.restart();
ArduinoOTA.begin();
server.on("/", [](){
if(!server.authenticate(www_username, www_password))
server.send(200, "text/plain", "Login OK");
server.begin();
/*Serial.print("Open http://");
Serial.print(WiFi.localIP());
Serial.println("/ in your browser to see it working");*/
Deva_Rishi:
The issue is caused by the combination of OTA and wifimanager (which i never use, and this a pretty good reason not to), wifimanager handles the root of the AP (so you can't access and use that anymore, and takes care of any wifi connection to station made, i got this working by changing the order up a bit#include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
#include <WiFiManager.h> //GitHub - tzapu/WiFiManager: ESP8266 WiFi Connection manager with web captive portal
//WiFiManager
server.on("/", {
server.begin();
ArduinoOTA.begin();
after which i could access the page with the ESP in station mode using the wifi network i connected to. unfortunately i had to guess what the new IP address would be (but i tried the ones it has shown up in previously) but found it. the standard sketch for the OTA makes it a little easier to understand (and leaves the access point for common use)#include <ESP8266WiFi.h>
/WiFi.mode(WIFI_STA);
ESP.restart();
ArduinoOTA.begin();
server.on("/", {
server.begin();
/Serial.print("Open http://");
Serial.println("/ in your browser to see it working");/
sorry.i had tried this coding the serial monitor shown "^Ep⸮4@H⸮L⸮i|H⸮" i was using esp8266 WEMOS D1 R2 mini board
and you have the BAUD rate of the Serial monitor set correctly ?
Deva_Rishi:
yeah i tried 9600 and 115200 both the same.
Oh eh, the standard example (2nd sketch) actually doesn't send anything to the Serial port (it is commented out ) Also due to an inaccuracy in the sketch un-commenting stuff does not quite work as you'd hope (it doesn't show the Ip address correctly since it is not actually in full connection status when it is read) though the AP (ESPap) shows up in your network list and you can connect to it and go to the standard IP 192.168.4.1 and you'll be asked for your credential.
this sketch works fully (if you set the proper ssid & password for your network) and prints out plenty in the Serial monitor for you.
const char* network = "yourSSID";
const char* networkpassword = "yourPASS";
Serial.println("----------HttpBasicAuth------------");
Serial.println("Access Point started.");
Serial.print("ssid : ");
Serial.println(ssid);
Serial.print("password ");
Serial.println(password);
WiFi.begin(network, networkpassword);
ESP.restart();
Serial.print("Connected to Network : ");
Serial.println(network);
Serial.println("Reconnecting AP");
WiFi.reconnect();
uint8_t elapsed=0;
while (WiFi.status()!=WL_CONNECTED) {
Serial.print(".");
delay (500);
elapsed++;
if (elapsed>30) {
Serial.println("Unable to reconnect, Rebooting");
ESP.restart();
Serial.println("Starting Authentication server");
ArduinoOTA.begin();
server.begin();
Deva_Rishi:
Oh eh, the standard example (2nd sketch) actually doesn't send anything to the Serial port (it is commented out ) Also due to an inaccuracy in the sketch un-commenting stuff does not quite work as you'd hope (it doesn't show the Ip address correctly since it is not actually in full connection status when it is read) though the AP (ESPap) shows up in your network list and you can connect to it and go to the standard IP 192.168.4.1 and you'll be asked for your credential.this sketch works fully (if you set the proper ssid & password for your network) and prints out plenty in the Serial monitor for you.
ESP.restart();
WiFi.reconnect();
uint8_t elapsed=0;
Serial.print(".");
delay (500);
elapsed++;
if (elapsed>30) {
ESP.restart();
ArduinoOTA.begin();
server.on("/", {
server.begin();
thx i will try it
Hi everybody. I have implemented an a solution for authentication and automatic logout from webserver. It is based on cookies, same as Github arduino-esp "SimpleAutenthification.ino" example
Hi, everybody
I run web server on ESP8266 and using SPIFFS to serv HTML file!
but i need Authentication on some page, How can i do that?
my code in setup is like this:
server.on("/", handleRoot);
server.on("/changewifipass", HTTP_POST, wifichangePass);
server.on("/connecttowifi", HTTP_POST, connectToWiFi);
server.on("/deviceconfig", deviceConfig);
server.on("/resetfactory", resetFactory);
server.on("/adminconfig", adminConfig);
and in method:
void wifichangePass()
String currentWiFiPassArg = "";
String wifiPassArg = "";
String confirmWiFiPassArg = "";
currentWiFiPassArg = server.arg("currentWiFiPass");
wifiPassArg = server.arg("wifiPass");
confirmWiFiPassArg = server.arg("confirmWiFiPass");
if (currentWiFiPassArg == "" or wifiPassArg == "")
server.send(400, "application/json", "{\"result\":\"Bad Request! Please send correct Information.\"}");
if (currentWiFiPassArg == apPass and wifiPassArg == confirmWiFiPassArg)
apPass = wifiPassArg;
writeConfig();
server.send(200, "application/json", "{\"result\":\"WiFi Password Changed!\"}");
How can i do that?
By starting your own topic for starters, rather than highjacking an old topic.
