Hi all,
The following code supposed to send an ADXL345 Buffer (32 levels) data over MQTT from my ESP32 board to the PC.
I am using wireshark to see the sent data .If I commented Line 127 my packet will be fragmented and I see packets of 1490 Byte and 235 Bytes although my actual packet Size (msg) is 860 Bytes.
If I use line 127 with the disconnect order then every thing is okay and in wireshark I see the 860 Bytes as it supposed to be.
Can anyone please tell me why I am seeing 1490 Bytes although I am sending only 860 Bytes?
Here is my code:
#include <WiFi.h>
#include <PubSubClient.h>
#include<ADXL345_WE.h>
#include<SPI.h>
#define CS_PIN 5 // Chip Select Pin
bool spi = true; // flag that SPI shall be used
const int int2Pin = 4;
volatile bool event = false;
String FifoData;
String myStrings[32];
String data;
xyzFloat g;
const char* ssid = "NETGEAR61";
const char* password = "classyflute500";
const char* mqtt_server = "192.168.1.4";
WiFiClient espClient;
PubSubClient client(espClient);
char msg[1000];
ADXL345_WE myAcc = ADXL345_WE(CS_PIN, spi);
void eventISR() {
event = true;
delay (500);
pinMode(int2Pin, INPUT_PULLDOWN);
if (!myAcc.init()) {
Serial.println("ADXL345 not connected!");
myAcc.setDataRate(ADXL345_DATA_RATE_3200);
delay(100);
Serial.print("Data rate: ");
Serial.print(myAcc.getDataRateAsString());
myAcc.setRange(ADXL345_RANGE_8G);
Serial.print(" / g-Range: ");
Serial.println(myAcc.getRangeAsString());
setup_wifi();
client.setServer(mqtt_server, 1883);
myAcc.setMeasureMode(false);
attachInterrupt(digitalPinToInterrupt(int2Pin), eventISR, RISING);
myAcc.setInterruptPolarity(ADXL345_ACT_HIGH);
myAcc.setInterrupt(ADXL345_WATERMARK, INT_PIN_2); // Interrupt when FIFO is full
myAcc.setFifoParameters(ADXL345_TRIGGER_INT_1, 32);
myAcc.setFifoMode(ADXL345_FIFO);
void setup_wifi() {
delay(10);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
void reconnect() {
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
if (client.connect(mqtt_server)) {
Serial.println("connected");
client.subscribe("esp32/output");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
delay(5000);
if (!client.connected()) {
reconnect();
client.loop();
long rssi = WiFi.RSSI();
event = false;
myAcc.readAndClearInterrupts();
myAcc.setMeasureMode(true); // this is the actual start
while(!event){} // wait until the fifo get full //event = true means WATERMARK interrupt triggered -> means FIFO is full
myAcc.setMeasureMode(false); // stop measuring
//Serial.println("FiFo full");
for(int i=0; i<32; i++){ // when i > 32 samples, the values do not change because the FIFO is full
g = myAcc.getGValues();
myStrings[i]= "x: " + String(g.x) + " y: " + String(g.y) + " z: " + String(g.z) + "\n";
data = data + myStrings[i];
data= " RSSI: " + String(rssi) + "dB" + data;
Serial.println(data.length());
data.toCharArray(msg , data.length() + 1);
client.publish("test1", msg);
//client.disconnect();
//emptying the strings for the next FIFO set.
data="";
for( int i = 0; i < MQTT_Size; ++i ){
msg[i] = (char)0;
