Hello again i would like to know how to use the arduino as a pulse generator... i mean we all know the Blink Example and also de Button Example...
the blink one turn on an off a led placing a HIGH and a LOW in pin 13
the button one read the state of pin 2 and if is HIGH turn HIGH pin 13 else turn it LOW
how can i mix this two examples?
this is what i want to do
first as pin 8 Turn HIGH i want Pin 13 turn on an off (forever)
an meanwhile
i want the arduino from the beginning start reading the state of pin 2 and if is HIGH turn Pin 3 LOW else turn it HIGH
Button
Turns on and off a light emitting diode(LED) connected to digital
pin 13, when pressing a pushbutton attached to pin 2.
The circuit:
* LED attached from pin 13 to ground
* pushbutton attached to pin 2 from +5V
* 10K resistor attached to pin 2 from ground
* Note: on most Arduinos there is already an LED on the board
attached to pin 13.
created 2005
by DojoDave <http://www.0j0.org>
modified 30 Aug 2011
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/Button
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 2; // the number of the pushbutton pin
const int restart = 4; // the number of the LED pin
const int pulso = 13;
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
// wait
// initialize the LED pin as an output:
pinMode(restart, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
pinMode(pulso, OUTPUT);
void loop(){
digitalWrite(pulso, HIGH); // turn the LED on (HIGH is the voltage level)
delay(200); // wait for a second
digitalWrite(pulso, LOW); // turn the LED off by making the voltage LOW
delay(200);
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn LED on:
digitalWrite(restart, LOW);
else {
// turn LED off:
digitalWrite(restart, HIGH);
You need the same thing here:
delay(200);
Don't you agree?
BTW, look to what Robin2 wrote:
Robin2:
Probably a good idea to get rid of delay() and use millis() for timing. (...)
