First of all I'll have to say that I don't know much about RF other than the stuff I Googled so bear with me...
I Brought this of Ebay:
http://www.ebay.com/itm/251174142265?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
It works very well, but I would like to extend the range of these two units (by placing the receivers antenna on the opposite side of a brick wall). I have already tried to extend the Remote control antenna but without any good results, therefore my goal now is to extend the build in antenna of the receiver unit. The frequency is 315MHz and I calculated that my antenna should have a length of 23,81cm for everything to be right.
This is the receiver unit, I've marked the antennas, the white coil-like antenna is approx 23cm when streched which is right according to my calculated antenna length.
I've already red this well documented PDF about RF Antennas:
http://www.hoperf.com/upload/rf/antennas_module.pdf
But still I can't figure out which antenna would be the best fit for me and my application?
How do I know which antenna would be the best fit, I don't really know the difference of which can and which can't be used between the ones described in the PDF.
I already tried building a simple antenna with just a piece of wire (23cm) but with my little knowledge I don't know if I've done it correctly and the best way. I soldered the piece of insulated wire to a pretty heavy coaxial cable and soldered the coax screen to the Receiver units ground. I all seemed to work, and it extended the distance by 30m.
-According to the PDF there is something called a "Groundplane" what exactly is that, and where/how should I use it?
-does it matter how thick the coaxial cable is?
-does it matter how thick the antenna wire (23cm) is? what is the best
I think that must be more than enough questions for you to answer first, for me to supply you with more information. I really hope that some of you RF guys would take a little time trying to help me out, I would appreciate that. Thank you.
regards
Johannes
