There is useful info about burning bootloader, but no enough info about changes had to do in ArduinoISP sketch. For example, It is not clear frequancyof programmer or target must be entered in the sketch.
Could anyone tell what exactly to do for burning UNO with MEGA 2560?
I'v seen wiring in the link above, just exact coding and steps (is two or one steps).
shimidan:
That's because no changes are necessary. Just leave the ArduinoISP sketch alone. It's configured correctly just as it is when Arduino provides it.
shimidan:
I think it's fairly well documented in the tutorial already, but here you go:
Connect your Mega 2560 to your computer with the USB cable.
Tools > Board > Arduino/Genuino Mega or Mega 2560
Tools > Port > select the port of your Mega 2560
File > Examples > 11.ArduinoISP > ArduinoISP
Sketch > Upload
Wait for the upload to finish successfully.
Unplug the Mega 2560 from your computer.
Wire the Mega 2560 to your Uno following this diagram:
Tools > Board > Arduino/Genuino Uno
Tools > Programmer > Arduino as ISP
Tools > Burn Bootloader
Wait for the Burn Bootloader process to finish successfully.
Thank pert, it was useful, but maybe i have some fault. I'v used 47 micF instead of 10 micF.
however, i got error:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x38
avrdude: Yikes! Invalid device signature.
- Double check connections and try again, or use -F to override*
- this check.*
Error while burning bootloader.
Please do this:
- (In the Arduino IDE) File > Preferences
- Check the checkbox next to "Show verbose output during: upload
- Click "OK"
- Tools > Burn Bootloader
- After the Burn Bootloader process fails, you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
- In a forum reply here, click on the reply field.
- Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
- Press "Ctrl + V". This will paste the Burn Bootloader output between the code tags.
- Move the cursor outside of the code tags before you add any additional text to your reply.
Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Uno"
D:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CD:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "D:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x000000 (retrying)
Reading | ################################################## | 100% 0.01s
this check.
avrdude done. Thank you.
option enabled in File -> Preferences.
I had done Loop-Back Test before burning. It was OK.
