I am trying to follow this tutorial and I can't seem to get it to work, the only difference that I can see between what I am doing and the tutorial is that I am using an Arduino MEGA2560 (Elegoo Clone), and the tutorial calls for an UNO, is my MEGA2560 unable to perform the same functions as the UNO when it comes to being used as an ISP.
Any help you can give will be greatly appreciated.
thank you for your help, I don't know what changed but when I plugged the Arduino into my laptop in again this morning and tried to burn the bootloader it worked. the only thing that was different was showing the verbose output during upload box was checked.
In some cases it's necessary to put a 10 uF capacitor on the Arduino as ISP board (the Mega2560 in this case) between the reset and ground pins in order to prevent it from getting reset when you're using it to do an upload.
