How to button LED Interrupt
const int BUTTONPin = 2;
const int ledPin = 9;
volatile bool ButtonPressed = false;
int i = 0;
char receivedChar;
//interupt funtion to check if button has been pressed
void ButtonInterupt() {
  ButtonPressed = true;
  pinMode(ledPin, OUTPUT);
  attachInterrupt(digitalPinToInterrupt(BUTTONPin), ButtonInterupt, SHIFT);
  Serial.begin(800);
  if (Serial.available() > 0) {
    receivedChar = Serial.read()
    if (receivedChar == 'a'){
      Serial.println("");
    else if (receivedChar == 'b') {
      // do something
    else  {
volatile bool buttonInterruptTriggered = false;
bool buttonMode = false;
bool ledState = false;
  pinMode(BUTTONPin, INPUT);
  attachInterrupt(digitalPinToInterrupt(BUTTONPin), ButtonPress, RISING);
  Serial.println("Type 1 or 2 to select mode.");
  // Handle serial input
    char receivedChar = Serial.read();
    if (receivedChar == '\n' || receivedChar == '\r') return;
    if (receivedChar == '1') {
      Serial.println("Mode 1");
      buttonMode = false;
    for (int i = 0; i < 5; i++) {
    digitalWrite(ledPin, HIGH);
    delay(250);
    digitalWrite(ledPin, LOW);
    delay(250);
    else if (receivedChar == '2') {
      Serial.println("Mode 2");
      buttonMode = true;
    else {
      Serial.println("Invalid character");
      buttonMode = false;
  // Handle button press from interrupt
  if (buttonInterruptTriggered && buttonMode) {
    ledState = !ledState;
    digitalWrite(ledPin, ledState);
// Interrupt service routine
void ButtonPress() {
  static unsigned long lastInterruptTime = 0;
  unsigned long interruptTime = millis();
  // Simple debounce: ignore triggers within 200ms
  if (interruptTime - lastInterruptTime > 200) {
    buttonInterruptTriggered = true;
    lastInterruptTime = interruptTime;
Posted code has two loop() , so I suspect cut and paste oops.
Go to IDE, ctrl-t for format, then "copy for forum" and paste into new message here.
Voce postou seu tópico na categoria International Portugues, mas escreveu o titulo em Ingles.
Escreva também uma breve descrição de como deveria funcionar on seu projeto e o que não está funcionando.
Olá orangerat34
A que se destina o programa na vida real?
I suspect you're an English-speaking person.
If so, please change the category of your post to the appropriate language category.
