I'm following this instructables Frequency Counter, but the result is very noisy, it jumps up and down too much. I've been reading some average tutorial but doesnt understand at all. How do I still make the arduino to calculate the frequency every 500ms, but only shows the average on LCD every 1000ms? Or is that not how it works? Any help would be very appreciated. Thank you
#include <LiquidCrystal.h>
LiquidCrystal lcd(11, 7, 5, 4, 3, 2);
const int pulsePin = 12; // Input signal connected to Pin 12 of Arduino
int pulseHigh; // Integer variable to capture High time of the incoming pulse
int pulseLow; // Integer variable to capture Low time of the incoming pulse
float pulseTotal; // Float variable to capture Total time of the incoming pulse
float frequency; // Calculated Frequency
pinMode(pulsePin, INPUT);
lcd.begin(16, 2);
lcd.setCursor(0, 0);
lcd.print("Instructables");
lcd.setCursor(0, 1);
lcd.print(" Freq Counter ");
delay(5000);
lcd.print("Frequency is ");
lcd.print(" ");
pulseHigh = pulseIn(pulsePin, HIGH);
pulseLow = pulseIn(pulsePin, LOW);
pulseTotal = pulseHigh + pulseLow; // Time period of the pulse in microseconds
frequency = 1000000/ pulseTotal; // Frequency in Hertz (Hz)
lcd.print(frequency);
lcd.print(" Hz");
