I have 3 TCA9548A I2C Multiplexers connected to a NodeMCU (ESP8266). Also connected 6 I2C sensors with same addresses to each of the TC9548A on different channels. How do I call each of the TCA9548A I2C MUX with their address to read the sensor data continuously in a loop?
So far I can only read the sensors off one TCA9548A MUX. But unable to do so off the three MUX's.
Any help regarding this would be much appreciated.
I have attached the code for your reference.
//Libraries*******************
#include "Wire.h"
#include <Wire.h>
#include <SPI.h>
#include "SparkFun_SCD30_Arduino_Library.h" //Click here to get the library: http://librarymanager/All#SparkFun_SCD30
#include <Adafruit_BMP280.h>
#include <Adafruit_INA219.h>
//*********************************************** R1 SCD30 sensor ******************************************************
SCD30 airSensor;
//SCD30 airSensor;
//SCD30 airSensor_R3;
//SCD30 airSensor_R4;
//SCD30 airSensor_R5;
//SCD30 airSensor_R6;
//float co2 = 0;
//float co2hum = 0;
//float co2temp = 0;
////*********************************************** R1 BMP280 sensor ******************************************************
Adafruit_BMP280 bmp; // use I2C interface
//Adafruit_BMP280 bmp; // use I2C interface
//Adafruit_BMP280 bmp_R3; // use I2C interface
//Adafruit_BMP280 bmp_R4; // use I2C interface
//Adafruit_BMP280 bmp_R5; // use I2C interface
//Adafruit_BMP280 bmp_R6; // use I2C interface
Adafruit_Sensor *bmp_temp = bmp.getTemperatureSensor();
Adafruit_Sensor *bmp_pressure = bmp.getPressureSensor();
//Adafruit_Sensor *bmp_temp = bmp_R2.getTemperatureSensor();
//Adafruit_Sensor *bmp_pressure = bmp_R2.getPressureSensor();
//Adafruit_Sensor *bmp_R1_temp = bmp_R1.getTemperatureSensor();
//Adafruit_Sensor *bmp_R1_pressure = bmp_R1.getPressureSensor();
////*********************************************** R1 INA219 sensor ******************************************************
Adafruit_INA219 ina219;
//Adafruit_INA219 ina219;
////Adafruit_INA219 ina219_R3;
////Adafruit_INA219 ina219_R4;
////Adafruit_INA219 ina219_R5;
////Adafruit_INA219 ina219_R6;
float shuntvoltage = 0;
float busvoltage = 0;
float current_mA = 0;
float power_mW = 0;
float loadvoltage=0;
float array1[3];
void setup(){
setupMux1();
setupMux2();
setupMux3();
void loop(){
loopMux1();
loopMux2();
loopMux3();
//**************************************** MUX 1 **********************************************
#define TCAADDR Mux1 0x70
#define TCAADDR Mux2 0x71
//#define TCAADDR 0x72
void tcaselect(uint8_t i) {
if (i > 7) return;
Wire.beginTransmission(TCAADDR);
Wire.write(1 << i);
Wire.endTransmission();
void setupMux1() {
Wire.beginTransmission(0x70); // join i2c bus (address optional for master)
Serial.begin(115200); // start serial for output
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("Connecting to Wi-Fi");
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
delay(300);
Serial.print("Connected with IP: ");
Serial.println(F("##############################"));
Serial.println(F("Starting Initialization"));
//*************INITIALIZING MUX 1 SENSORS *******************************
tcaselect(0);
Serial.println("Channel 0 of Mux");
Serial.println("R1 SCD30 Example");
Wire.begin();
if (airSensor.begin() == false)
Serial.println("R1 Air sensor not detected. Please check wiring. Freezing...");
while (1)
tcaselect(2); // channel 7 --> BMP280
Serial.println("Channel 1 of Mux");
Serial.println("R2 SCD30 Example");
Wire.begin();
Serial.println("R2 Air sensor not detected. Please check wiring. Freezing...");
while (1)
Wire.endTransmission(0x70);
void loopMux1() {
tcaselect(0); // channel 0 --> SCD30
if (airSensor.dataAvailable())
Serial.print("R1 co2(ppm):");
Serial.print(airSensor.getCO2());
// co2=airSensor.getCO2();
Serial.print(" R1 temp(C):");
Serial.print(airSensor.getTemperature(), 1);
// co2temp=airSensor.getTemperature();
Serial.print(" R1 humidity(%):");
Serial.print(airSensor.getHumidity(), 1);
// co2hum=airSensor.getHumidity();
// Serial.println("R1 Waiting for new data");
// delay(500);
tcaselect(2); // channel 1 --> SCD30
Serial.print("R2 co2(ppm):");
Serial.print(" R2 temp(C):");
Serial.print(" R2 humidity(%):");
// Serial.println("R2 Waiting for new data");
//******************************************** MUX 2 *********************************
void setupMux2() {
Wire.beginTransmission(0x71); // join i2c bus (address optional for master)
Serial.print(".");
delay(300);
tcaselect(0);
////////pressure///////////////
Serial.println(F("R1 BMP280 Sensor event test"));
if (!bmp.begin()) {
Serial.println(F("Could not find a valid R1 BMP280 sensor, check wiring!"));
delay(10);
bmp.setSampling(Adafruit_BMP280::MODE_NORMAL, /* Operating Mode. */
Adafruit_BMP280::SAMPLING_X2, /* Temp. oversampling */
Adafruit_BMP280::SAMPLING_X16, /* Pressure oversampling */
Adafruit_BMP280::FILTER_X16, /* Filtering. */
Adafruit_BMP280::STANDBY_MS_500); /* Standby time. */
bmp_temp->printSensorDetails();
tcaselect(1); // channel 1 --> BMP280
Serial.println(F("R2 BMP280 Sensor event test"));
if (!bmp.begin()) {
Serial.println(F("Could not find a valid R2 BMP280 sensor, check wiring!"));
delay(10);
Wire.endTransmission(0x71);
void loopMux2() {
tcaselect(0); // channel 0 --> BMP
sensors_event_t temp_event, pressure_event;
bmp_temp->getEvent(&temp_event);
bmp_pressure->getEvent(&pressure_event);
Serial.print(F("R1 Temperature = "));
Serial.print(temp_event.temperature);
Serial.println(" *C");
Serial.print(F("R1 Pressure = "));
Serial.print(pressure_event.pressure);
Serial.println(" hPa");
//float pressure_pascal=pressure_event.pressure/1000 - 0.90883;
// array3[1] = temp_event.temperature;
// delay(1000);
// sensors_event_t temp_event, pressure_event;
Serial.print(F("R2 Temperature = "));
Serial.print(F("R2 Pressure = "));
//******************************************** MUX 3 *********************************
void setupMux3() {
Wire.beginTransmission(0x72); // join i2c bus (address optional for master)
Serial.print(".");
delay(300);
tcaselect(0);
ina219.begin();
ina219.setCalibration_16V_400mA(); // set measurement range to 16V, 400mA
ina219.begin();
Wire.endTransmission(0x72);
void loopMux3() {
tcaselect(0); // channel 0 --> INA219
shuntvoltage = ina219.getShuntVoltage_mV();
busvoltage = ina219.getBusVoltage_V();
current_mA = ina219.getCurrent_mA();
power_mW = ina219.getPower_mW();
loadvoltage = busvoltage + (shuntvoltage / 1000);
Serial.print("R! Load Voltage: "); Serial.print(loadvoltage); Serial.println(" V");
Serial.print("R1 Current: "); Serial.print(current_mA); Serial.println(" mA");
Serial.println("");
array1[0] = busvoltage;
array1[1] = shuntvoltage;
array1[2] =loadvoltage;
array1[3] = current_mA;
tcaselect(1); // channel 1 --> INA219
Serial.print("R2 Load Voltage: "); Serial.print(loadvoltage); Serial.println(" V");
Serial.print("R2 Current: "); Serial.print(current_mA); Serial.println(" mA");
Serial.println("");
