I'm using an ADC shield attached with Arduino Uno to increase the precision. The link is below.
However, the sample rate is not high enough so I want to change the prescaler to increase the sample rate. I just can't find any way to change the prescaler of the external ADC. Is it possible to do that?
The link also shows the ADC used on the boards - might be worth a look at the manufactures data sheet .
Also why do you need such high speed and precision - you could be producing a lot of data that the Arduino can’t handle. There may be another way ; what is the project ?
hammy:
Hi Hammy!
Thanks for the reply! Actually, I want to gather the manufacturing data (especially the acoustic data is up to more than 100Hz) using a small board. Now I change an ADC that can have higher speed, but the limitation comes to that the baud rate of Arduino is not high enough to transmit so many data. I think you are right that the Arduino might not handle this. Is there any board can transmit such a huge number of data to my computer?
I think you are right because I also can't find any information about it. The reason leads me to ask this is because the ADC inside the Arduino can change the prescaler to increase the speed. So I am wondering if there is any way to do with the external ADC.
