Im building a MPPT Solar Charger for a LiPo battery (2 Cells, 7.4V, 910 mAh).
My design is using a Synchronous Buck Converter, that transform the 20 Voc and 0.33 A Isc from the Solar Cell Panel to charge the battery. While I didnt test the design in real situation, the simulation in PSpice is giving me some troubles when I insert a load that has to be powered from the battery.
Arduino will be also powered from the battery, because the Solar Panel will be used just for charging the battery.
Can anyone help me to understand how to power the load while the battery is charing?
Since I cannot find the schematic, maybe it did not post. I will take a SWAG and say connect the load to the battery. You need to be aware in your design of the charger that not all power is going into the battery.
Buck convertors don't work well with a solar panel, because solar panels are primarily current sources, with the current proportional to the illumination. The combination tends to oscillate or fail completely.
By far the simplest approach is to just have the solar panel directly charge the battery, with cutoffs or current limiting to control the charge as required by the battery chemistry. Then you draw current from the battery.
You need to look carefully how lipo’s are charged - there are some power management chips about for this purpose that will allow charging and supplying a load - but not easy to use .
The requirement is that the battery has to supply always the power for the loads, and the solar panel has to charge the battery when the Cubesat is on the sun side.
