And I'm interesting in buying a strong NEMA with more than 270oz and up to 425oz. Unfortunately I'm a noob in this area and I have no idea on how to check if the motor will fit to one of my drivers or not.
The list of motors that I found suitable (Budget/OZ/etc) for my project(s) are:
Assuming the 3a and 4.4A in your motor descriptions represents the number of amps that the motor requires then I suggest you get a driver than can provide at least 1 amp more than the motor needs and preferably has a 50% margin.
On that basis the A4988 and DRV8825 are completely unsuitable. The TB6600 might be marginally OK for the 3amp motors - but you would need to check the driver datasheet.
As you have not provided links to the datasheets for the other drivers I cannot comment.
For the future it is always a good idea to provide links to the motor datasheets as there is such a wide variety of motors. Arduino folk are probably familiar with the A4988 and DRV8825 and, to a lesser extent the TB66xx drivers.
eldad87:
I just modified my original post, each motor model is a link to the actual eBay page with the relevant data-sheet.
Let me know if its sufficient.
I am prepared to take your word for it that the amps needed by each motor is correct. If you look at Reply #1 you will see that my problem was a lack of datasheets for the drivers.
BTW, How can it be that a smaller motor require more AMPs (23HS2430 112mm 3A vs j-5718hb3401 76mm 4.4A)?
That is a question for the manufacturers. Perhaps the higher amperage motor has fewer turns of thicker wire. Or maybe the manufacturer thinks its OK to run hotter.
The BTS7960 seems to be a board with h-bridge drivers which are really intended for DC motors and not stepper motors so I would rule it out completely. Specialized stepper drivers can limit the current to protect the motor so that you can use a higher voltage power supply for better performance.
The DM542 has a max current of 4.5 amps so I would consider it suitable for the 3 amp motors but not the 4.4amp motor.
Robin2:
Thank you for you reply!
What about the, TB6600? According to the specs it can handle 4A - its not sufficient to handle 3A motor?
Even something like this one?
Robin2:
And I provided a link to the eBay page which contain the relevant (I hope) information: TB6600, Anyway, I just ordered the TB6600HG which is rated at 4.5A.
I also wrote "I suggest you get a driver than can provide at least 1 amp more than the motor needs and preferably has a 50% margin." and it seems that the TB6600 meets my first criterion.
MorganS:
Unlike regular motor drivers, you don't need to over-rate a stepper driver. A 4.4A driver is just fine for a 4.5A motor.
I don't believe that is true for an A4988 or DRV8825 (at their own current limits, of course) and, in general, I do not like operating electronic devices close to their limit.
Robin2:
...R
I have several options to go with, based on your previews responses, you recommend using the 5A drivers.
How can I check if the motors I got can work properly with my drivers?
M5256 - which is rated as 5A with max of 8A
I mean, how can I make sure that the drivers/motors function as expected and no more power is needed?
I'm not interesting in spending over than 15$ on a driver, anything above 6A just seems too expensive and cost around 50$.
I rather buy 2x2.5A steppers+drivers instead of a single 4.4-6A stepper + HBS86H/CW8060/DM556 driver.
Robin2:
I just said it so you would have a good reason to ask more questions.
Feel free to ignore my rule of thumb.
...R
I'm not trying to ignore your rule, I really thank you for it - but my budget won't allow me to get a 6A driver.
So I wondered what could be the consequences of using a 5A instead of a 6A driver. Just to know what to expect for...
