How to code a multi remote without original
Hi there I hope someone can help me. I'm trying to make a program to discover all IR codes for an old amplifier that i dont have remote for anymore .
Like you can do with most multi remotes where it sends out one code after another until the device turns off then you press a button and then by magic all most buttons work...
I wanna do something similar as in send all possible hex commands taken from some known woking codes I know the code for power and mute and volume. im sure it cant be to hard to make it do maths to work out what possible combinations would work if a small multi remote can do it....
Ive use the IR record and the ir send examples along with some other sources to get me started.
here is what i got so far.
#include <IRremote.h>
int RECV_PIN = 4;
//int BUTTON_PIN = 12;
//int STATUS_PIN = 13;
IRrecv irrecv(RECV_PIN);
IRsend irsend;
decode_results results;
  irrecv.enableIRIn(); // Start the receiver
//  pinMode(BUTTON_PIN, INPUT);
//  pinMode(STATUS_PIN, OUTPUT);
// Storage for the recorded code
int codeType = -1; // The type of code
unsigned long codeValue; // The code value if not raw
unsigned int rawCodes[RAWBUF]; // The durations if raw
int codeLen; // The length of the code
int toggle = 0; // The RC5/6 toggle state
// Stores the code for later playback
// Most of this code is just logging
void storeCode(decode_results *results) {
  codeType = results->decode_type;
  int count = results->rawlen;
  if (codeType == UNKNOWN) {
    Serial.println("Received unknown code, saving as raw");
    codeLen = results->rawlen - 1;
    // To store raw codes:
    // Drop first value (gap)
    // Convert from ticks to microseconds
    // Tweak marks shorter, and spaces longer to cancel out IR receiver distortion
    for (int i = 1; i <= codeLen; i++) {
      if (i % 2) {
        // Mark
        rawCodes[i - 1] = results->rawbuf[i]*USECPERTICK - MARK_EXCESS;
        Serial.print(" m");
      else {
        // Space
        rawCodes[i - 1] = results->rawbuf[i]*USECPERTICK + MARK_EXCESS;
        Serial.print(" s");
      Serial.print(rawCodes[i - 1], DEC);
    Serial.println("");
  else {
    if (codeType == NEC) {
      Serial.print("Received NEC: ");
      if (results->value == REPEAT) {
        // Don't record a NEC repeat value as that's useless.
        Serial.println("repeat; ignoring.");
        return;
    else if (codeType == SONY) {
      Serial.print("Received SONY: ");
    else if (codeType == PANASONIC) {
      Serial.print("Received PANASONIC: ");
    else if (codeType == JVC) {
      Serial.print("Received JVC: ");
    else if (codeType == RC5) {
      Serial.print("Received RC5: ");
    else if (codeType == RC6) {
      Serial.print("Received RC6: ");
    else {
      Serial.print("Unexpected codeType ");
      Serial.print(codeType, DEC);
      Serial.println("");
    Serial.println(results->value, HEX);
    codeValue = results->value;
    codeLen = results->bits;
void sendCode(int repeat) {
    if (repeat) {
      irsend.sendNEC(REPEAT, codeLen);
      Serial.println("Sent NEC repeat");
    else {
      irsend.sendNEC(codeValue, codeLen);
      Serial.print("Sent NEC ");
      Serial.println(codeValue, HEX);
    irsend.sendSony(codeValue, codeLen);
    Serial.print("Sent Sony ");
    irsend.sendPanasonic(codeValue, codeLen);
    Serial.print("Sent Panasonic");
    irsend.sendJVC(codeValue, codeLen, false);
    Serial.print("Sent JVC");
  else if (codeType == RC5 || codeType == RC6) {
    if (!repeat) {
      // Flip the toggle bit for a new button press
      toggle = 1 - toggle;
    // Put the toggle bit into the code to send
    codeValue = codeValue & ~(1 << (codeLen - 1));
    codeValue = codeValue | (toggle << (codeLen - 1));
      Serial.print("Sent RC5 ");
      irsend.sendRC5(codeValue, codeLen);
    else {
      irsend.sendRC6(codeValue, codeLen);
      Serial.print("Sent RC6 ");
  else if (codeType == UNKNOWN /* i.e. raw */) {
    // Assume 38 KHz
    irsend.sendRaw(rawCodes, codeLen, 38);
    Serial.println("Sent raw");
int lastButtonState;
  if (Serial.read() != -1) {
    Serial.println("SENDING IR SIGNAL");
    sendCode(&results);
//    for (int i = 0; i < 1; i++) {
//      Serial.println("SENDING IR SIGNAL");
//      sendCode(&results);
  else if (irrecv.decode(&results)) {
    storeCode(&results);
    irrecv.resume(); // resume receiver
//  lastButtonState = irrecv.decode;
Have a look on the Arduino home page at
community - playground: Arduino Playground - LibraryList
and then Communications - IRremote.
In my IDE 1.8.10 there is a library called IRremote. I can't remember if I installed this library or if it was part of the IDE installation. Just have a look there.
SupArdu:
I have already installed IRremote by ken Shirriff.
I need help with writing the c code not installing libraries but thanks any way
The library IRremote contains a lot of example code. Perhaps you can learn from it how to write your code.
