How to Code LED light Set
So im making a device to measure salinity for science olympiad detector build. But I need 3 leds to turn on when the value of the salinity (ppm) hits a certain number and must turn off and turn there other led when it does hit the next range of values. How do i Code this?
Right Now my code is :
#define TdsSensorPin A0
#define VREF 5.0 // analog reference voltage(Volt) of the ADC
#define SCOUNT 30 // sum of sample point
int analogBuffer[SCOUNT]; // store the analog value in the array, read from ADC
int analogBufferTemp[SCOUNT];
int analogBufferIndex = 0;
int copyIndex = 0;
float averageVoltage = 0;
float tdsValue = 0;
float temperature = 16; // current temperature for compensation
// median filtering algorithm
int getMedianNum(int bArray[], int iFilterLen){
int bTab[iFilterLen];
for (byte i = 0; i<iFilterLen; i++)
bTab[i] = bArray[i];
int i, j, bTemp;
for (j = 0; j < iFilterLen - 1; j++) {
for (i = 0; i < iFilterLen - j - 1; i++) {
if (bTab[i] > bTab[i + 1]) {
bTemp = bTab[i];
bTab[i] = bTab[i + 1];
bTab[i + 1] = bTemp;
if ((iFilterLen & 1) > 0){
bTemp = bTab[(iFilterLen - 1) / 2];
else {
bTemp = (bTab[iFilterLen / 2] + bTab[iFilterLen / 2 - 1]) / 2;
return bTemp;
void setup(){
pinMode(TdsSensorPin,INPUT);
void loop(){
static unsigned long analogSampleTimepoint = millis();
if(millis()-analogSampleTimepoint > 40U){ //every 40 milliseconds,read the analog value from the ADC
analogBuffer[analogBufferIndex] = analogRead(TdsSensorPin); //read the analog value and store into the buffer
analogBufferIndex++;
if(analogBufferIndex == SCOUNT){
static unsigned long printTimepoint = millis();
if(millis()-printTimepoint > 800U){
for(copyIndex=0; copyIndex<SCOUNT; copyIndex++){
analogBufferTemp[copyIndex] = analogBuffer[copyIndex];
  // read the analog value more stable by the median filtering algorithm, and convert to voltage value
  averageVoltage = getMedianNum(analogBufferTemp,SCOUNT) * (float)VREF / 1024.0;
  //temperature compensation formula: fFinalResult(25^C) = fFinalResult(current)/(1.0+0.02*(fTP-25.0));
  float compensationCoefficient = 1.0+0.02*(temperature-25.0);
  float compensationVoltage=averageVoltage/compensationCoefficient;
  //convert voltage value to tds value
  tdsValue=(133.42*compensationVoltage*compensationVoltage*compensationVoltage - 255.86*compensationVoltage*compensationVoltage + 857.39*compensationVoltage)*0.5;
  Serial.print("voltage:");
  Serial.print(averageVoltage,2);
  Serial.print("V   ");
  Serial.print("TDS Value:");
  Serial.print(tdsValue,0);
  Serial.println("ppm");
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
In loop() measure salinity, turn all the LEDS off then turn on the LEDs that you want to indicate the salinity level. The LEDs will be off for such a short time that you cannot see that they are all off and only they right ones will be on.
