How to compare two arrays
Hi .
I'm doing some tests on how to compare two arrays but I'm not succeeding, I've read a lot about arrays and a lot of research I found nothing that could help me!
Hope you can help me please.
Thank you very much in Advance
Here is the code I have been testing but unsuccessfully
int array1[6] = {0,1,2,3,4,5}; // sample arrays
int array2[6] = {0,1,2,3,4,5};
int test2,test1;
static boolean result;  // this variable will hold the compare result
     Serial.begin(9600); // stablish serial communication
  void loop(){
  for (int x=0; x<6; x++){
   test1 = array1[x];// asign each index of arrays to test, one by one and compare
   test2= array2[x];
  if(test1!= test2){ // if any index comparison is not equal, then the arrays are not equal and result will be 0.
   result = false;
  }else{
   result = true;
  Serial.println(result);
  delay(100);
The test must be done within the loop braces.
For example:
   test2= array2[x];
   if (test1 != test2) do_something();
Thanks for answering !
I made this change but it didn't work
int array1[6] = {0,10,2,3,4,5}; // sample arrays
int test2,test1;
  void loop(){
   test2= array2[x];
      result = false;
      }else{
      result = true;
  delay(100);
Try:
int array1[6] = {0, 1, 2, 3, 4, 5}; // sample arrays
int array2[6] = {0, 1, 2, 3, 4, 5};
int test2, test1;
  int result = 0;
  for (int x = 0; x < 6; x++)
    test2 = array2[x];
    if (test1 != test2) // if any index comparison is not equal, then the arrays are not equal and result will be 0.
      //found a bad one
      result++;
  delay(100);
} //END of loop()
Hi Guys.
Better not let spycatcher2k read this! :zipper_mouth_face:
Already changed
Thanks for answering but still without making the comparison!
What I really want the code to do is if the arrays are equal it returns number 1 otherwise it returns 0
You can invert things as needed:
int test2, test1;
bool result;            //this variable will hold the compare result
  Serial.begin(9600);   //establish serial communication
  result = false;
    test1 = array1[x];  //asign each index of arrays to test, one by one and compare
    test2 = array2[x];
    if (test1 != test2) //if any index comparison is not equal, then the arrays are not equal and result will be 0.
      //found a bad one
      result = true;
  delay(100);
} //END of loop()
If you are only interested in an overall match, and don't care about specific position of any mismatches, you can use memcmp which compares two blocks of memory. memcmp returns 0 if there is a match, so you will need to invert the result.
int array1[6] = {0, 10, 2, 3, 4, 5}; // sample arrays
int test2, test1;
byte result;  // this variable will hold the compare result
  Serial.begin(9600); // establish serial communication
  if (memcmp(array1, array2, sizeof(array1)) == 0)
    result = 1;
    result = 0;
Thanks larryd for the help
But I would like you to explain why this code does not work I do not understand the reason, because logically it should work
int test2, test1;
  //result = false;
    test2 = array2[x];
     result = true;}
      else {
      result = false;}
  delay(100);
} //END of loop()
You overwrite the value of result with each iteration of the for loop.
cattledog:
Thanks for helping
Fiasgardone:
Your code, as well as larry's shouldn't work. You need to break out of the loop as soon as you find a mismatch, otherwise the result would just be overwritten by the last computation.
if (test1 != test2)
  result = true;
  result = false;
Look at what your 'else' section does.
larryd:
if (test1 != test2)
 result = true;
 result = false;
By logic after the test"if (test1 != test2)" , if true returns 1 otherwise returns 0
   test1 = array1[x];
    test2 = array2[x];
    if (test1 != test2)
     result = true;}
      else {
      result = false;}
arduino_new:
I could understand your explanation, can you give more details of what you mean?
Thank you very much in advance
Get rid of all of the "else" clause.
If you get rid of just the 'else"... Well, let's leave that as an exercise for the reader :smiley:
it is difficult to understand comparisons for me but let's see if I can understand
Just use memcmp; why reinvent the wheel?
TheMemberFormerlyKnownAsAWOL:
yes, but it is always good to know all the features offered by the C language.
