i am having a byte array let us say
byte arr[7]={123456};
how to compare this array with a list of of other array like this for example
byte buffers[5][7] = {123456,654321,987654,456789,765432};
if this method is wrong how can i declare that ?
any help?
You could use two for loops to compare your 5x7 array to your 7 array
the outer for loop would go from 0 to 4 and the control variable would be i
the inner loop would go from 0 to 6 and the control variable would be j
for (i=0; i <4; i++)
for (j=0; j<6 ; j++)
if array[j] !=buffer[i,j]
else (j=6){
success=1;
print('its a match);println(buffer[i,j]); //or whatever you want to do
if (success==0)
println("not a match");
noweare:
else (j=6){
success=1;
if (success==0)
will try it
thank u
Kind of sticks-and-stones but it seems to work:
#define NUM_COMPARES 5
#define NUM_ELEMENTS 6
byte arr[NUM_ELEMENTS]={1,2,3,4,5,6};
byte buffers[NUM_COMPARES][NUM_ELEMENTS] =
{7,6,5,4,3,2},
{9,8,7,6,5,4},
{1,2,3,4,5,6},
{4,5,6,7,8,9},
{7,6,5,4,3,2}
bool
bMatch;
int
i, j;
i = 0;
do
bMatch = true;
for( j=0; j<NUM_ELEMENTS; j++ )
if( arr[j] != buffers[i][j] )
bMatch = false;
if( !bMatch )
i++;
}while( i < NUM_COMPARES && !bMatch );
if( bMatch )
Serial.print( "Match found at buffer[" );
Serial.print(i);
Serial.println( "]" );
Serial.println( "No match found." );
}//setup
(I see I'm a little slow at typing. Will post anyway...)
You don't say what you want to compare exactly. That if any of the arrays in the buffer match with the array? For that you could do:
bool is_match=false;
for(unsigned i=0; i<5; ++i)
if(memcmp(arr, buffers[i], sizeof(arr))==0)
is_match=true;
JarkkoL:
You don't say what you want to compare exactly. That if any of the arrays in the buffer match with the array? For that you could do:bool is_match=false;
is_match=true;
yes this is what i want to do
thank u very much
Blackfin:
Kind of sticks-and-stones but it seems to work:#define NUM_COMPARES 5
{7,6,5,4,3,2},
{9,8,7,6,5,4},
{1,2,3,4,5,6},
{4,5,6,7,8,9},
{7,6,5,4,3,2}
bool
bMatch;
int
i, j;
i = 0;
do
bMatch = true;
bMatch = false;
if( !bMatch )
i++;
if( bMatch )
Serial.print(i);
}//setup
very nice code
it is working perfectly !!!
thank u very much for ur help
thank u very much to all of u
this is the final code that i used
bool bMatch;
int i, j;
byte arr[NUM_ELEMENTS]={7,2,3,4,5,6};
{7,6,5,4,3,2},
{9,8,7,6,5,4},
{4,5,6,7,8,9},
{7,6,5,4,3,2},
{7,2,3,4,5,6}
{ i = 0;
do
bMatch = true;
bMatch = false;
if( !bMatch )
i++;
if( bMatch )
Serial.print(i);
