Hello,
I have created PHP pages that connected MySQL and Arduino can use GET request from PHP. I want the UID data from GET request that displayed on Arduino console can comparison? someone said use Serial.read, but I don't know how to do, please give me example, thanks.
PHP code
<?php
include("db.php");
$uid = $_GET['uid'];
$result = mysqli_query($conn, "select * FROM user WHERE uid = '$uid'");
while($row = mysqli_fetch_array($result,MYSQLI_ASSOC)) {
$posts[] = $row['uid'];
echo "$uid";
Ardunio code
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
char server[] = "xxxx.com"; // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 1, 177);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// start the Ethernet connection:
Ethernet.begin(mac, ip);
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected");
// Make a HTTP request:
client.print("GET /getdata.php?");
client.print("uid=");
client.print("F070AAAA");
client.println(" HTTP/1.1");
client.println("Host: xxxx.com");
client.println("Connection: close");
client.println();
// if you didn't get a connection to the server:
Serial.println("connection failed");
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
while (true);
Console displayed
connecting...
connected
HTTP/1.1 200 OK
Server: nginx/1.12.2
Date: Tue, 30 Jan 2018 03:36:00 GMT
Content-Type: text/html; charset=UTF-8
Transfer-Encoding: chunked
Connection: close
f
F070AAAA
0
disconnecting.
