Hello, I want to connect this 12V ANNIMOS 150KG servo (https://amzn.eu/d/gj097pm) to UNO R4.
Any pointers how to do it as this one is 12V and not the standard 5V servo.
Thank you
Thank you
The link does not work.
Works for me
Power required may be almost 9 Amps when fully loaded. So your power supply will need to supply up to that much depending on how you use the device.
For control, it is identical to any other hobby servo.
Hi Paul,
Thanks for the quick reply. Can I connect the ground to the UNO R4 GHD pin or will the 9 Amps burn it? Any alternative options for that case?
Thanks
The grounds need to be connected together but use a single point grounding method and return all ground connections to the large power supply ground. Under NO circumstance should the servo current pass through the Arduino and its PCB.
Yes
Thank you!
You got it, always follow that rule and it will save you $$$, the more projects the more $$$ you can save.
Sorry to barge in late, but do you have any exact recommendations for the power supply? eg the lifepo4 12v 5a or others
minimum 8-9A otherwise lifepo 12V or any other 12V source should be fine
