I need a power source for my robot
Hello, I’m currently developing a robot arm, using an Arduino nano and a Pca9685, connected to the Pca9685 is a hiwonder 20kg servo motor. How do I power this motor, I understand that it needs 6 to 8 volts to run but I don’t have any thing that has that many volt I had the rest of my servos connected to a elegloo power supply. I also have a question that I’m too scared to test, if I were to put a 12 V into the elegloo power supply, could I use the VIN pin to power, the servo? I need a fast way to power the servo without buying anything new because I don’t have enough money for my project at the moment.
Thank you for reading
You don't want to power the Servo through the arduino.
The safe way is to either use a proper 6–8 V power source capable of 2–5 A (depending on the servo load) or temporarily power the servo from a battery pack with the correct voltage and capacity.
Never try to run it through the Nano or PCA9685 logic pins, and never put 12 V into the servo directly
What is the current requirement for the motor? Saying it is 20kg doesn't say anything about its power consumption.
How much can you afford? I did a quick search on Amazon and got 6V and similar power supplies for £10 to £20 (I am in the UK). Is this outside your budget? Do make sure that if you buy a power supply it is capable of maybe at least 50% more current than the maximum the servo needs.
Maybe too late for this project but I suggest you make a habit of collecting old power supplies from used electronic equipment. If you do that you'll probably never need to buy a power supply again.
You can try but it will not work unless you have some shorts on the Arduino. VIN (Voltage IN) is a power input to the board before the onboard regulator, not an output.
This web page shows "5V" as their power source for their servos, but you will use your "6v to 8v" power supply for your servos.
