I am new to using the Arduino Uno, but I know that it can help with the project I am working on. I need to create a batter operated UV led strip to place inside a shadow box picture frame. It needs to fade on and run for 10 minutes, and then fade off for 10. (I got the coding figured out already and it is posted below.) I purchased a 2m, 5v Uv LED strip. It has 120 units, the voltage is described as 5 DC volts and 12 watts. I have seen schematics on how to connect it addressable LEDs, but I couldn't find anything on non-addressable 5v LEDs. I am not sure if it needs a resistor, and if it does, I am not sure how many ohms it needs.
When I tested my code briefly (10 second on 10 seconds off) I connected the positive wire from the led to pin 9, and the negative wire to ground, but I am not sure if this is right (or safe). Any advice would help!
Coding:
int ledPin = 9; // LED connected to digital pin 9
// fade in from min to max in increments of 5 points:
Sorry I new to this, so I am to exactly sure if this is what you were asking for. This is the only data sheet I could find. Please let me know if this was not what you meant!
I work with a glow in the dark pigment called strontium aluminate mixed with acrylic paint. It glows best when charged with UV light. The gallery that I am installing in wanted the painting's lighting on a timer, but they wanted the lights to fade on and off. That is why I am working with them, and why I needed a programmable microcontroller. Otherwise, I would just use a standard looping timer.
When setting up the MOSFET, is it the same type of setup that you would do with 12v LED strips?
Before you commit to those leds be sure you can fade them. The usual way is to rapidly turn them on and off and change that ratio. Be sure they will function that way.
Paul
