how to connect a phone-camera to a PC via USB?
I guys,
I am working on a robot should have a hi-quality camera and should take a transfer pictures on demand to a computer via a USB cable.
The first and obvious thing would be to use a webcam, but even with the best webcam image quality was rather poor.
So I thought about using a replacement camera from an iPhone or Galaxy, as they are cheap ( <30$ ) and produce very good pictures.
Now the question - are there any boards that allow connecting such cameras to USB?
Or at least do this cameras use some standard protocol or do they have their own one?
Thanks )
Well I don't know what part the Arduino plays in this, I don't think it has a place.
The Raspberry Pi has a high def camera that is quite cheap and perhaps is a more suitable platform for this project.
What about his…
https://www.sparkfun.com/search/results?term=camera
Artem85:
I don't know what you consider 'the best' web cam but web cams are available with relatively good resolution. What image resolution are you looking for?
I think low light performance may be an issue. Webcams are available in 1080p resolution.
Here's a quality I was able to get from a webcam and galaxy s3 ( scaled down by half ).
I am looking for something that would be able to produce pictures of the s3 quality.
There are a few "5mp camera modules" on aliexpress and such, but since they are not showing any sample photos, I doubt that their quality is any better then of a webcam...
So the only solution is to try to use a camera module from a phone.
P.S.
Another option might be finding a photo camera that can be controlled via the usb...
Unfortunately, you won't be able to use a camera module from a cellphone, unless you have this:
  • Full datasheet for the sensor
  • In-depth knowledge of Cellphone-camera protocol
    decoding (SMIA)
  • A fast enough ARM processor/FPGA with subLVDS (CCP/CCI) interface & enough fast SRAM to store the data
Good luck!
// Per.
Artem85:
There's no grounds for that doubt. As a general rule the greater the number of pixels the better the image quality will be. Since you only showed a composite of the two images and not the raw images I have no way to know what the resolution of the webcam images was. The 'web cam' part was obviously much poorer quality and presumably came from a low resolution camera. The S3 has an 8MP camera so a 5MP web cam will not be quite as good resolution but it should be close. The camera resolution (and optical quality) is what matters - not the way that it is connected to the PC. Once you get close, note that camera settings can have a significant impact on the image quality.
The camera I spoke of earlier is a 5 Mega pixel camera
Applications and examples:-
http://www.raspberrypi.org/archives/tag/camera-board
Actually there is a way to do this. I'm surprised no one here knows this. There are apps for android that can make android phone act as a web cam.
Some of them are "Droid cam" and the open source "Smart cam". Use can use bluetooth, Wifi or USB.
Ufoguy, the idea was to use the cam without the phone. :slight_smile:
Anyway, I found out that Canon has SKD fot C#, so I guess using some cheap PowerShot camera would be the best solution.
Oh, you came to my solution. I was just thinking I've used both Canon PowerShot (S45) and now Canon DSLR, both came with remote shooting software, and the SDK gets you in.
