How to Connect Arduino Uno to ESP 8266 ESP-12E
hello everyone! i am in a huge dillema on how i can use ESP 8266 ESP12-E together with Arduino Uno in a RFID attendance System with Database Connected from pycharm database code to xampp php/my sql database. my question is how can i connect them for them to properly log data or log the students that will be registered to the ID so that it can be shown in the database? i will be using a SD card module, RTC module, Servo, and LCD display here is my code for arduino IDE.
thanks everyone! your help is appreciated!
#include <SPI.h>
#include <MFRC522.h> //library for rfid sensor
#include <RTClib.h> //library for rtc module
#include <SD.h> //library for sd card module
#include <Wire.h>
#include <LiquidCrystal_I2C.h> //library for i2c module
#include <Servo.h> //library for servo moter
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
const char* ssid = "WifiSSID";
const char* password = "this is hidden haha Wifi Pass";
const char* server = "192.168.0.1";
const int serverPort = 80;
//define pins for rfid sensor
#define SS_PIN 10
#define RST_PIN 9
//define select pin for SD card module
#define CS_SD 4
Servo myservo;  // create servo object to control a servo.
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
RTC_DS3231 rtc;// Instance of the class for RTC
LiquidCrystal_I2C lcd(0x27, 20, 4); // Initialize for a 20x4 LCD display
const int numOfCards = 5;//the nuber of cards used. this can change as you want
byte cards[numOfCards][4] = {{0x69, 0x38, 0xFD, 0x6E},{0x29, 0xCE, 0xE2, 0x6E},{0xD9, 0x45, 0xE5, 0x6E},{0xA9, 0x76, 0x47, 0xB8},{0x59, 0x3F, 0x16, 0x98}}; // array of UIDs of rfid cards
int n = 0;//n is for the total number of students//j is for to detect the card is valid or not
int numCard[numOfCards]; //this array content the details of cards that already detect or not .
String names[numOfCards] = {"Tristan Silva","Andrei DeGuzman","Bill Gatan","Henrick Cadano","Zoren Antalan"};//student names
long sNumbers[numOfCards] = {2021011286,201500221,2022030385,2021011635,2021011904};//student sNumbers
  Serial.begin(9600); // Initialize serial communications with the PC
  SPI.begin();  // Init SPI bus
  mfrc522.PCD_Init(); // Init MFRC522 card
  //setup for lcd screen
  lcd.begin(20,4);// initialize the lcd
  myservo.attach(6);  // attaches the servo on pin 9 to the servo object
  //setup for RTC module
  #ifndef ESP8266
  while (!Serial);
  #endif
  if (! rtc.begin()) {
    Serial.println(F("Couldn't find RTC"));
    while (1);
  else{
      rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));//time will set auto when it compiles
    //rtc.adjust(DateTime(2020, 1, 9, 16, 59, 45));// manually set time
  if (rtc.lostPower()) {
    Serial.println(F("RTC lost power, lets set the time!"));
  //setup for display option (serial monitor)
  Serial.println(F("\t\t\t<<<< Library Attendance >>>>\n")); // introduction
  Serial.println(F("COUNT\tRegNO\tNAME\t\tDATE\t\tARRIVAL\t\tDEPARTURE"));// make four columns
  //setup sd card
//  Serial.print(F("Initializing SD card..."));
  digitalWrite(CS_SD,LOW);
//  if (!SD.begin(4)) {//checks the sd card inserted and if it not the program will not working.
//    Serial.println(F("initialization failed!"));
//    while (1);
//  Serial.println(F("initialization done."));
 File  myFile = SD.open("test.txt", FILE_WRITE);
  if (myFile) {
    myFile.print(F("  \t**** Library Attendance ****\n"));
    myFile.println(F("COUNT\tRegNO\tNAME\t\tDATE\t\tARRIVAL\t\tDEPARTURE"));
    // close the file:
    myFile.close();
    Serial.println(F("done."));
    // Serial.println(F("error opening test.txt"));
  myFile = SD.open("test.txt");
  if (myFile) {
    Serial.println(F("test.txt:"));
    while (myFile.available()) {
      Serial.write(myFile.read());
    myFile.close();
  digitalWrite(CS_SD,HIGH);
void sendPostRequest() {
  WiFiClient client;
  if (!client.connect(server, serverPort)) {
    Serial.println("Connection failed");
    return;
  // HTTP POST request body
  String postData = "RegistrationNumber=123456&Name=John&RFID_UID=ABC123";
  // Send HTTP POST request to server
  client.println("POST /attendance.php HTTP/1.1");
  client.println("Host: " + String(server));
  client.println("Content-Type: application/x-www-form-urlencoded");
  client.print("Content-Length: ");
  client.println(postData.length());
  client.println();
  client.print(postData);
  // Wait for server response
  while (client.connected()) {
    if (client.available()) {
      String response = client.readStringUntil('\r');
      Serial.println(response);
  client.stop();
void readRFID(){
  int j = -1;
  byte card_ID[4];//card UID size 4byte
  if ( ! mfrc522.PICC_IsNewCardPresent()) {//look for new card
    return;//got to start of loop if there is no card present
  if ( ! mfrc522.PICC_ReadCardSerial()) {// Select one of the cards
    return;//if read card serial(0) returns 1, the uid struct contians the ID of the read card.
  for (byte i = 0; i < mfrc522.uid.size; i++) {
    card_ID[i] = mfrc522.uid.uidByte[i];
  for (int i = 0; i < numOfCards; i++) {
    if (card_ID[0] == cards[i][0] && card_ID[1] == cards[i][1] && card_ID[2] == cards[i][2] && card_ID[3] == cards[i][3]) {
      j = i;
  if(j == -1) {//check the card validity
    invalid();
  else if (numCard[j] == 1) { //to check if the card already detect
    alreadyRead(names[j], sNumbers[j], j);
  else {
    //send data to display and save
    logCardData(names[j], sNumbers[j], j);
  sendPostRequest();
void servo(){//method for servo motor
  int pos = 0;    // variable to store the servo position
   for (pos = 90; pos >= 0; pos -= 1) { // goes from 0 degrees to 90 degrees
    // in steps of 1 degree
    myservo.write(pos);
    delay(5);
  delay(5000);
   for (pos = 0; pos <= 90; pos += 1) {// goes from 90 degrees to 0 degrees
    myservo.write(pos);
    delay(5);
void logCardData(String name, long sNumber, int j){
  displayAllow(name,sNumber);
  DateTime now = rtc.now();
  numCard[j] = 1;//put 1 in the numCard array : numCard[j]={1,1} to let the arduino know if the card was detecting
  n++;//to get the count
  //display details to the console (serial monitor)
  Serial.print(n);//print number
  Serial.print(F("\t"));
  Serial.print(sNumber); //print name of student
  Serial.print(name); //print name of student
  Serial.print(now.year(),DEC); //print year
  Serial.print(F("-"));
  if(now.month()<10){Serial.print("0");Serial.print(now.month(),DEC);}
  else Serial.print(now.month(),DEC); //print month
  if(now.day()<10){Serial.print("0");Serial.print(now.day(),DEC);} //if the day is one digit this will display it with zero in front as two digits.
  else Serial.print(now.day(),DEC);
  if(now.hour()<10){Serial.print("0");Serial.print(now.hour(),DEC);}
  else Serial.print(now.hour(),DEC);
  Serial.print(F(":"));
  if(now.minute()<10){Serial.print("0");Serial.print(now.minute(),DEC);}
  else Serial.print(now.minute(),DEC);
  if(now.second()<10){Serial.print("0");Serial.print(now.second(),DEC);}
  else Serial.print(now.second(),DEC);
  Serial.println(F("--:--:-- "));
  File  myFile = SD.open("test.txt", FILE_WRITE);//record the data to the sd card
  if (myFile) {
      myFile.print(n);//print number
      myFile.print(F("\t"));
      myFile.print(sNumber); //print name of student
      myFile.print(name); //print name of student
      myFile.print(now.year(),DEC); //print year
      myFile.print(F("-"));
      if(now.month()<10){myFile.print("0");myFile.print(now.month(),DEC);}
      else myFile.print(now.month(),DEC); //print month
      if(now.day()<10){myFile.print("0");myFile.print(now.day(),DEC);}
      else myFile.print(now.day(),DEC);
      if(now.hour()<10){myFile.print("0");myFile.print(now.hour(),DEC);}
      else myFile.print(now.hour(),DEC);
      myFile.print(F(":"));
      if(now.minute()<10){myFile.print("0");myFile.print(now.minute(),DEC);}
      else myFile.print(now.minute(),DEC);
      if(now.second()<10){myFile.print("0");myFile.print(now.second(),DEC);}
      else myFile.print(now.second(),DEC);
      myFile.println(F("--:--:--"));
      myFile.close();
void invalid(){
  Serial.println(F("Invalid Card."));
  if (myFile) {
    myFile.println(F("Invalid Card."));
    myFile.close();
  lcd.home ();
  lcd.clear();
  lcd.setCursor (6, 0 );// go home
  lcd.print(F("Warning!"));
  lcd.setCursor (4, 2 );
  lcd.print(F("Invalid Card!"));
  lcd.setCursor (3, 3 );
  lcd.print(F("Access Denied!"));
  delay(3000);
  lcd.clear();
void alreadyRead(String name, long sNumber, int j){
  numCard[j] = 0;//put 1 in the numCard array : numCard[j]={1,1} to let the arduino know if the card was detecting
  n--;//to get the count
  Serial.print(F("--:--:--"));
  if(now.second()<10){Serial.print("0");Serial.println(now.second(),DEC);}
  Serial.println(" ");
    if (myFile) {
      myFile.print(F("--:--:--"));
      else myFile.println(now.second(),DEC);
      myFile.close();
  lcd.home ();
  lcd.clear();
  lcd.setCursor (5, 1 );// go home
  lcd.print(F("Thank You"));
  lcd.print(F("Come Again!"));
  delay(3000);
  servo();
  lcd.clear();
void printLoopLCD(){//method for display date and time and number of students attendance to the lcd dislpay
  lcd.home ();// go home
  lcd.setCursor (1, 0);
  lcd.print(F("Welcome to Library"));
  lcd.setCursor (0, 1 );
  lcd.print(now.year(),DEC); //print year+
  lcd.print(F("-"));
  if(now.month()<10){lcd.print("0");lcd.print(now.month(),DEC);}
  else lcd.print(now.month(),DEC); //print month
  lcd.print(F("-"));
  if(now.day()<10){lcd.print("0");lcd.print(now.day(),DEC);}
  else lcd.print(now.day(),DEC);
  //lcd.print(now.day(),DEC); //print date
  lcd.setCursor (12, 1 );
  if(now.hour()<10){lcd.print("0");lcd.print(now.hour(),DEC);}
  else lcd.print(now.hour(),DEC);
  //lcd.print(now.hour(),DEC);
  lcd.print(F(":"));
  if(now.minute()<10){lcd.print("0");lcd.print(now.minute(),DEC);}
  else lcd.print(now.minute(),DEC);
  //lcd.print(now.minute(),DEC);
  lcd.print(F(":"));
  if(now.second()<10){lcd.print("0");lcd.print(now.second(),DEC);}
  else lcd.print(now.second(),DEC);
  //lcd.print(now.second(),DEC);
  lcd.setCursor (0, 3 );
  lcd.print(F("No of Students:"));
  lcd.setCursor (16, 3 );
  lcd.print(n);
void displayAllow(String name,long sNumber){
  lcd.home ();
  lcd.clear();
  lcd.print(F("Welcome!"));
  lcd.setCursor (1, 1 );
  lcd.print(F("Authorized Access!"));
  lcd.setCursor (0, 2 );
  lcd.print(F("Name:"));
  lcd.setCursor (5, 2 );
  lcd.print(name);
  lcd.print(F("SNo :S"));
  lcd.setCursor (6, 3 );
  lcd.print(sNumber);
  delay(3000);
  servo();
  lcd.clear();
void checkTime(){
  //check the time if the time is 6pm the system will stop working (time out)
    lcd.home ();
    lcd.clear();
    if(n != 0){ //check the nuber of student is 0 or not
      Serial.println(F("Warning!"));
      Serial.print(F("Count not zero!"));
      lcd.setCursor (6, 1 );
      lcd.setCursor (3, 2 );
      lcd.print(F("Count not zero!"));
      delay(5000);
     //else{
      Serial.println(F("Session has expired!"));
      Serial.print(F("No of students :"));
      Serial.println(n);
      lcd.home ();
      lcd.clear();
      lcd.print(F("Library"));
      lcd.print(F("Session has expired!"));
      lcd.print(F("No of students :"));
      lcd.print(n);
    delay(46800000);//delay for 12 hours
    lcd.clear();
  if (now.hour() < 7 || now.hour() >= 18) {
    checkTime();
  printLoopLCD();//print details on lcd screen(loop)
  readRFID();
and here is my code for pycharm database
import mysql.connector
def create_connection():
    try:
        connection = mysql.connector.connect(host="localhost", user="root", password="", database="attendancesys")
        print("Connected to MySQL database successfully!")
        return connection
    except mysql.connector.Error as err:
        print("Error:", err)
def create_tables(connection):
    try:
        cursor = connection.cursor()
        create_students_table = """
        CREATE TABLE Students (StudentID INT AUTO_INCREMENT PRIMARY KEY, RegistrationNumber BIGINT NOT NULL,
            Name VARCHAR(255) NOT NULL,
            RFID_UID VARCHAR(8) NOT NULL
        create_attendance_log_table = """
        CREATE TABLE AttendanceLog (LogID INT AUTO_INCREMENT PRIMARY KEY, StudentID INT NOT NULL, LogDate DATE NOT NULL,
            ArrivalTime TIME NOT NULL,
            DepartureTime TIME
        create_attendance_sessions_table = """
        CREATE TABLE AttendanceSessions (SessionID INT AUTO_INCREMENT PRIMARY KEY, SessionStart DATETIME NOT NULL,
            SessionEnd DATETIME
        create_invalid_cards_table = """
        CREATE TABLE InvalidCards ( InvalidID INT AUTO_INCREMENT PRIMARY KEY, RFID_UID VARCHAR(8) NOT NULL,
            DetectedDateTime DATETIME NOT NULL
        create_settings_table = """
        CREATE TABLE Settings ( SettingID INT AUTO_INCREMENT PRIMARY KEY, SettingName VARCHAR(255) NOT NULL,
            SettingValue VARCHAR(255) NOT NULL
        cursor.execute(create_students_table)
        cursor.execute(create_attendance_log_table)
        cursor.execute(create_attendance_sessions_table)
        cursor.execute(create_invalid_cards_table)
        cursor.execute(create_settings_table)
        print("Tables created successfully!")
        connection.commit()
        cursor.close()
def main():
    connection = create_connection()
    if connection is not None:
        connection.close()
        print("Connection closed.")
if __name__ == "__main__":
    main()
i wil also attach the setup for the database + the customize php connection code.
attendance.php
<?php
// Database configuration
$servername = "localhost";
$username = "root";
$password = "";
$database = "attendancesys";
// Create connection
$conn = new mysqli($servername, $username, $password, $database);
// Check connection
if ($conn->connect_error) {
    die("Connection failed: " . $conn->connect_error);
// Handle POST request to insert data into the Students table
if ($_SERVER['REQUEST_METHOD'] === 'POST' && isset($_POST['RegistrationNumber']) && isset($_POST['Name']) && isset($_POST['RFID_UID'])) {
    $registrationNumber = $_POST['RegistrationNumber'];
    $name = $_POST['Name'];
    $rfidUID = $_POST['RFID_UID'];
    $sql = "INSERT INTO Students (RegistrationNumber, Name, RFID_UID) VALUES ('$registrationNumber', '$name', '$rfidUID')";
    if ($conn->query($sql) === TRUE) {
        echo "New record created successfully";
        echo "Error: " . $sql . "<br>" . $conn->error;
// Handle POST request to insert data into the AttendanceLog table
if ($_SERVER['REQUEST_METHOD'] === 'POST' && isset($_POST['StudentID']) && isset($_POST['LogDate']) && isset($_POST['ArrivalTime']) && isset($_POST['DepartureTime'])) {
    $studentID = $_POST['StudentID'];
    $logDate = $_POST['LogDate'];
    $arrivalTime = $_POST['ArrivalTime'];
    $departureTime = $_POST['DepartureTime'];
    $sql = "INSERT INTO AttendanceLog (StudentID, LogDate, ArrivalTime, DepartureTime) VALUES ('$studentID', '$logDate', '$arrivalTime', '$departureTime')";
// Handle GET request to fetch data from the Students table
if ($_SERVER['REQUEST_METHOD'] === 'GET' && isset($_GET['action']) && $_GET['action'] === 'getStudents') {
    $sql = "SELECT * FROM Students";
    $result = $conn->query($sql);
    if ($result->num_rows > 0) {
        $data = array();
        while ($row = $result->fetch_assoc()) {
            $data[] = $row;
        echo json_encode($data);
        echo "0 results";
$conn->close();
Since you have the parts show an annotated schematic, be sure all connections, power sources, grounds, etc are there. If the wire length is over 10"/25cm note that as well.
Explain what your code does, I do not want to spend time figuring it out.
Draw a map showing how all of these things interconnect.
This sounds like a method to validate class attendance. If so you might want to take a picture of the person logging in. Also is it a simple project or is it to be implemented over more then one or two units?
