Hello:
I am trying to connect leds from TPIC6B595 with resistors in two pins screw connectors I've attached an schema with my connection, is this OK or do I have to change anything?
many thanks to all of you.
Hello:
Hello:
Why do I have a glasses in the forum?
Am I not welcome to this forum?
thank you
The glasses next to your name is to let you know you are watching this forum
You do need to explain your problem adequately in order to get answers.
We really have no idea what you are asking.
I want to change the connections of the leds made in my breadboards to a two pin screw connectors like you can see in the attached image.
The schema 1 is how I have in my breadboard the connection of leds, the schema 2 I am asking if is correct to put the leds in this way. I want to connect leds into two pin screw connectors.
thank you.
Yes those two schemas are equivalent (at least they would be if you had the same number of LEDs and the pin numbering was the same).
Steve
Yes, are the same.
Thank you very much
What is puzzling, is your conflation of screw connectors and breadboards. You really need to explain what it is you are trying to put together using what pieces.
I won't use breadboard I will make a PCB, so why, I need to know the connections of 2 pin screw.
Many thanks
