How to connect multiple DS20B18 sensors with Arduino MEGA
Hi guys,
I want to make a data logger. i am using 8 probe sensors.
The problem is when i connect 8 sensors and while the operation i disconnect one of them the Arduino still working and give a value for it!.
Also if any problem happen to one of them ( water leakage inside a sensor) all reads become -127 why is that?
i connect all sensors to one digital pin. and this is my code.
#include <OneWire.h>
#include <DallasTemperature.h>
#include <SD.h>
#include <SPI.h>
#include <DS1302.h>
// RST,DAT,CLK
DS1302 rtc(31, 30, 33 );
File myFile;
int pinCS = 53; // Pin 10 on Arduino Uno
// Data wire is plugged into digital pin 2 on the Arduino
#define ONE_WIRE_BUS 10
// Setup a oneWire instance to communicate with any OneWire device
OneWire oneWire(ONE_WIRE_BUS);
// Pass oneWire reference to DallasTemperature library
DallasTemperature sensors(&oneWire);
int deviceCount = 0;
float tempC;
void setup(void)
sensors.begin(); // Start up the library
if (SD.begin())
Serial.println("SD card is ready to use.");
} else
Serial.println("SD card initialization failed");
return; }
rtc.halt(false);
rtc.writeProtect(false);
pinMode(pinCS, OUTPUT);
// SD Card Initialization
Serial.print("Locating devices...");
Serial.print("Found ");
deviceCount = sensors.getDeviceCount();
Serial.print(deviceCount, DEC);
Serial.println(" devices.");
Serial.println("");
sensors.requestTemperatures();
rtc.setTime(2, 36, 00); // Set the time to 12:00:00 (24hr format)
rtc.setDate(22, 12, 2020); // Set the date to August 6th, 2010
void loop(void)
// Send command to all the sensors for temperature conversion
for (int j=0; j<1; j++)
Serial.print(rtc.getDateStr());
Serial.print(",");
Serial.print(rtc.getTimeStr());
Serial.print(",");
if (SD.begin())
myFile = SD.open("TestT9.txt", FILE_WRITE);
if (myFile) {
myFile.println(" ");
myFile.print(rtc.getDateStr());
myFile.print(",");
myFile.print(rtc.getTimeStr());
myFile.print(",");
myFile.close(); // close the file
else {
Serial.println("error opening test.txt");
} else
return; }
// Display temperature from each sensor
for (int i = 0; i < deviceCount; i++)
tempC = sensors.getTempCByIndex(i);
Serial.print(tempC);
Serial.print(" , ");
if (SD.begin())
if (myFile) {
myFile.print(tempC);
myFile.print(",");
else {
} else
return; }
delay(5000);
Serial.println("");
You retrieve the temperature "by index". However, in this situation I prefer to use the unique ID of the temperature sensors. You need an array to store them.
The disadvantage is that when you replace a sensor, then you have to add the new ID in the sketch.
You have to give them a good name in the sketch, and put a label with that name on each DS18B20 sensor.
I made an example in 2016. Is this helpful ? multiple temp sensors ds18b20 - #6 by Koepel - Sensors - Arduino Forum.
Please use code-tags for the sketch instead of a quote. The </> button is for code-tags.
If water gets into your circuit, yes you have a problem! Water can conduct, then corrode and
electrolyze away parts of the circuit. Water and electricity should never mix!
I've never understood why people use the by-index method
-127 means no connection.
Koepel:
You are a hero man. i used it and added RTC and SDcard it working very well.
but i have some questions:
1- some time the vaule become -127 for different sensors and returned back quickly why is that happening?
2- What is the resolution? is your code the value is 10
MarkT:
Yes but the value for the 8 sensors become -127 if anyone of them have a water inside.
Nick_Pyner:
Arduino 1-Wire Tutorial
Thank you so much.
hamzatay:
They're all connected to the same bus. If that bus is messed with by one sensor, you can't read any of the others either.
The sensors you buy as “ water proof” are not - the metal end is waterproof but where the cable exits is not - so if you submerge them , they will fail.
You can probably improve them with the right silicone sealant though. The other problem is that the
cheap one on eBay are probably fake anyway.
wvmarle:
So how can i fix this problem?
hammy:
Yes you are right.
if i immerged it vertically can the water get inside the probe?
hamzatay:
Make sure no water gets into the sensors.
MarkT:
Thank you
wvmarle:
There is water inside how can i dry it?
Maybe in an oven... but then the inside may have corroded already, and drying may not fix it.
Easiest and most reliable> replace the offending sensor. And make sure it doesn't get wet inside again.
If it got wet , probably best to bin it .
If you want to measure under a liquid you need a thermowell - you can make something from a length of copper tube with sealed end - push the sensor down the tube and make sure the open end is well above the surface .
hammy:
Yes i want to put the sensor inside the wet concrete and take the values until it drk what do you suggest?
wvmarle:
Thank you.
I’d suggest you use the tube approach I mentioned - you could flatten the end and solder it up
