I want to connect my NRF24 module to my uno but also I want to use the pins 13,12,11,10 (which I know a little are used for SPI ) for digital outputs to LEDs.
where do I connect my NRF24 to??
There is a Software based SPI library out there, but quite slow.
But you cannot re-direct the hardware SPI pins on a UNO.
Are the analog pins currently used ?
I am not using the analog pins, but can I use ICSP header on arduino board and use 9,8 for CE and CSN respectively?
You might want to check the pinout diagram of the UNO ?
The ICSP header used the pin 13,12,11 SPI connections ...............
You could use the analog pins as digital outputs to LEDs and free 13,12,11,10 pins.
Thank you!
Will definitely do this
