How to connect two TCN75A temperature sensors with Arduino ?
Hello arduino enthusiasts :),
I recently bought Arduino Uno and I am trying to create a thermal regulator device. For this purpose I also bought two TCN75A thermal sensors. I am able to connect one of the sensors, and get the temperature readings, but I am not sure how to connect the second one. Here is what I have done so far:
Schematics:
  • SDA -> ?4
  • SCL -> ?5
  • Vcc -> 5V
  • GND -> GND
Code:
#include <Wire.h>
int reading = 0;
float temperature = 0;
void setup(){
Wire.begin();
///// sets resolution for the measurement
Wire.beginTransmission(B1001000);
Wire.send(0x01);
Wire.send(0x60);
Wire.endTransmission();
Wire.send(0x00);
void loop(){
Wire.requestFrom(B1001000, 2);
reading = Wire.receive();
reading = reading << 8;
reading |= Wire.receive();
reading = reading >> 4;
temperature = (float)reading/16; // ??????? ?? 16 ?????????? ????
Serial.println(temperature,3); // ????? ???????? ? ?? ??? ???
// ? 3 ????? ???? ?????????
Thanks is advance.
Best regards
It's a I2C (2 - Wire) device, so you need to arrange for them to be at different bus addresses, by wiring pins 5, 6 and 7 on the chip differently.
You should be able to have up to eight of them on a single bus - refer to the datasheet of the Microbot module.
I do not see the pullup resistors. This will become more important as you add more devices.
I suggest some background reading, for example:
It's working :). Thanks for the help guys !
